[petsc-dev] Test harness + PETSC_HAVE_DEFINED
Pierre Jolivet
pierre at joliv.et
Mon Mar 22 15:24:03 CDT 2021
Hello,
My make check is skipping tests which have a “requires: defined(PETSC_USE_SHARED_LIBRARIES)” with the message "SKIP PETSC_HAVE_DEFINED(PETSC_USE_SHARED_LIBRARIES) requirement not met" even though in configure.log I have:
2021-03-22T16:17:43.1626452Z #define PETSC_USE_SHARED_LIBRARIES 1
Is this expected?
Here is an ever more puzzling behavior.
https://gitlab.com/petsc/petsc/-/jobs/1118286502/artifacts/browse/arch-ci-freebsd-pkgs-opt/tests/ <https://gitlab.com/petsc/petsc/-/jobs/1118286502/artifacts/browse/arch-ci-freebsd-pkgs-opt/tests/>
ok ksp_ksp_tests-ex6_3_skip_pipegcr # SKIP Null requirement not met: define(PETSC_USE_AVX512_KERNELS)
#PIPEGCR generates nans on linux-knl
test:
requires: !define(PETSC_USE_AVX512_KERNELS)
suffix: 3_skip_pipegcr
Why is this test skipped (on a worker other than linux-knl)?
Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210322/aa741303/attachment.html>
