[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
    Jed Brown
    jed at jedbrown.org
    Fri Mar 19 21:23:10 CDT 2021
Matthew Knepley <knepley at gmail.com> writes:
>> PetscSectionSetUp currently calculates offsets by walking the points in
>> order. I'd like to be able to walk them in a different ordering, perhaps
>> specified via an IS permutation, which could be computed using
>> MATORDERINGRCM or directly via BFS of a closure (saves building a Mat).
> You can do this using
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PetscSection/PetscSectionSetPermutation.html
> This is what Lawrence is doing. He permutes the points so that interior
> points come first, then points that are not
> shared but touch shared points, then shared points.
Cool, this sounds easy enough now. What user interface would you like to use to have DMPlex apply an ordering when constructing a section after DMAddField()?
DMPlexSetDofOrderingType(DM, MatOrderingType)
To be set before DMSetUp with "natural" as default and "rcm" (or a new "bfs") taking a fast path that just walks the closure instead of building a matrix?
