[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Matthew Knepley
knepley at gmail.com
Fri Mar 19 12:42:49 CDT 2021
On Fri, Mar 19, 2021 at 11:52 AM Lawrence Mitchell <wence at gmx.li> wrote:
> > On 19 Mar 2021, at 15:20, Jed Brown <jed at jedbrown.org> wrote:
> >> I guess the only issue is now one needs to always remember to traverse
> cells in the reordered_cells order (although if you call DMPlexPermute that
> is automatic?).
> > Can DMPlexPermute handle a non-stratified permutation?
> I think the answer here is still no (as per your previous statement). The
> way we work around this in Firedrake is as I described above. Effectively
> we always traverse the cells in order specified by the RCM reordering. For
> traversal of facets and other entities we then build a traversal order once
> by traversing the cells and greedily ordering the facets/edges/etc...
> I think you could get this behaviour from dmplexpermute if one wrote it so
> that it permutes the cells with RCM and then compatibly permutes
> lower-dimensional entities. This would maintain stratification, but I think
> keep good cache locality for all entity traversals. But I do not understand
> the details of what dmplexpermute is doing at the moment.
I thought Plex already did that. Maybe I am wrong, it was a long time ago.
Matt
> Cheers,
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210319/35c06a24/attachment.html>
