[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
    Eric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Thu Mar 18 20:46:40 CDT 2021
Hi again,
ok, just saw that some matrices have lines of "0" in case of 3D hermite
DOFs (ex: du/dz derivatives) when used into a 2D plane mesh...
So, my last problem about hypre smoother is "normal".
However, just to play with one of this matrix, I tried to do a "LU" with
mumps icntl_24 option activated on the global system: fine it works.
Then I tried to switche to GAMG with mumps for the coarse_sub level, but
it seems my icntl_24 option is then ignored and I don't know why...
See my KSP:
KSP Object: (Options_ProjectionL2_0) 1 MPI processes
   type: bcgs
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-15, absolute=1e-15, divergence=1e+12
   left preconditioning
   using PRECONDITIONED norm type for convergence test
PC Object: (Options_ProjectionL2_0) 1 MPI processes
   type: gamg
     type is MULTIPLICATIVE, levels=2 cycles=v
       Cycles per PCApply=1
       Using externally compute Galerkin coarse grid matrices
       GAMG specific options
         Threshold for dropping small values in graph on each level =
         Threshold scaling factor for each level not specified = 1.
         AGG specific options
           Symmetric graph false
           Number of levels to square graph 1
           Number smoothing steps 1
         Complexity:    grid = 1.09756
   Coarse grid solver -- level -------------------------------
     KSP Object: (Options_ProjectionL2_0mg_coarse_) 1 MPI processes
       type: preonly
       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
       using NONE norm type for convergence test
     PC Object: (Options_ProjectionL2_0mg_coarse_) 1 MPI processes
       type: bjacobi
         number of blocks = 1
         Local solver is the same for all blocks, as in the following
KSP and PC objects on rank 0:
       KSP Object: (Options_ProjectionL2_0mg_coarse_sub_) 1 MPI processes
         type: preonly
         maximum iterations=1, initial guess is zero
       PC Object: (Options_ProjectionL2_0mg_coarse_sub_) 1 MPI processes
         type: lu
           out-of-place factorization
           tolerance for zero pivot 2.22045e-14
           using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
           matrix ordering: nd
           factor fill ratio given 0., needed 0.
             Factored matrix follows:
               Mat Object: 1 MPI processes
                 type: mumps
                 rows=8, cols=8
                 package used to perform factorization: mumps
                 total: nonzeros=64, allocated nonzeros=64
                   MUMPS run parameters:
                     SYM (matrix type):                   0
                     PAR (host participation):            1
                     ICNTL(1) (output for error):         6
                     ICNTL(2) (output of diagnostic msg): 0
                     ICNTL(3) (output for global info):   0
                     ICNTL(4) (level of printing):        0
                     ICNTL(5) (input mat struct):         0
                     ICNTL(6) (matrix prescaling):        7
                     ICNTL(7) (sequential matrix ordering):7
                     ICNTL(8) (scaling strategy):        77
                     ICNTL(10) (max num of refinements):  0
                     ICNTL(11) (error analysis):          0
                     ICNTL(12) (efficiency
control):                         1
                     ICNTL(13) (sequential factorization of the root
node):  0
                     ICNTL(14) (percentage of estimated workspace
increase): 20
                     ICNTL(18) (input mat
struct):                           0
                     ICNTL(19) (Schur complement
info):                      0
                     ICNTL(20) (RHS sparse
pattern):                         0
                     ICNTL(21) (solution
struct):                            0
                     ICNTL(22) (in-core/out-of-core
facility):               0
                     ICNTL(23) (max size of memory can be allocated
locally):0
                     ICNTL(24) (detection of null pivot
rows):               0
                     ICNTL(25) (computation of a null space
basis):          0
                     ICNTL(26) (Schur options for RHS or
solution):          0
                     ICNTL(27) (blocking size for multiple
RHS):             -32
                     ICNTL(28) (use parallel or sequential
ordering):        1
                     ICNTL(29) (parallel
ordering):                          0
                     ICNTL(30) (user-specified set of entries in
inv(A)):    0
                     ICNTL(31) (factors is discarded in the solve
phase):    0
                     ICNTL(33) (compute
determinant):                        0
                     ICNTL(35) (activate BLR based
factorization):           0
                     ICNTL(36) (choice of BLR factorization
variant):        0
                     ICNTL(38) (estimated compression rate of LU
factors):   333
                     CNTL(1) (relative pivoting threshold): 0.01
                     CNTL(2) (stopping criterion of refinement):
1.49012e-08
                     CNTL(3) (absolute pivoting threshold):      0.
                     CNTL(4) (value of static pivoting): -1.
                     CNTL(5) (fixation for null pivots):         0.
                     CNTL(7) (dropping parameter for BLR):       0.
                     RINFO(1) (local estimated flops for the elimination
after analysis):
                       [0] 308.
                     RINFO(2) (local estimated flops for the assembly
after factorization):
                       [0]  0.
                     RINFO(3) (local estimated flops for the elimination
                       [0]  0.
                     INFO(15) (estimated size of (in MB) MUMPS internal
data for running numerical factorization):
                     [0] 0
                     INFO(16) (size of (in MB) MUMPS internal data used
during numerical factorization):
                       [0] 0
                     INFO(23) (num of pivots eliminated on this
processor after factorization):
                       [0] 6
                     RINFOG(1) (global estimated flops for the
elimination after analysis): 308.
                     RINFOG(2) (global estimated flops for the assembly
after factorization): 0.
                     RINFOG(3) (global estimated flops for the
elimination after factorization): 0.
                     (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
(0.,0.)*(2^0)
                     INFOG(3) (estimated real workspace for factors on
all processors after analysis): 64
                     INFOG(4) (estimated integer workspace for factors
on all processors after analysis): 35
                     INFOG(5) (estimated maximum front size in the
complete tree): 8
                     INFOG(6) (number of nodes in the complete tree): 1
                     INFOG(7) (ordering option effectively use after
analysis): 2
                     INFOG(8) (structural symmetry in percent of the
permuted matrix after analysis): 100
                     INFOG(9) (total real/complex workspace to store the
matrix factors after factorization): 64
                     INFOG(10) (total integer space store the matrix
factors after factorization): 35
                     INFOG(11) (order of largest frontal matrix after
factorization): 8
                     INFOG(12) (number of off-diagonal pivots): 0
                     INFOG(13) (number of delayed pivots after
factorization): 0
                     INFOG(14) (number of memory compress after
factorization): 0
                     INFOG(15) (number of steps of iterative refinement
after solution): 0
                     INFOG(16) (estimated size (in MB) of all MUMPS
internal data for factorization after analysis: value on the most memory
consuming processor): 0
                     INFOG(17) (estimated size of all MUMPS internal
data for factorization after analysis: sum over all processors): 0
                     INFOG(18) (size of all MUMPS internal data
allocated during factorization: value on the most memory consuming
processor): 0
                     INFOG(19) (size of all MUMPS internal data
allocated during factorization: sum over all processors): 0
                     INFOG(20) (estimated number of entries in the
factors): 64
                     INFOG(21) (size in MB of memory effectively used
during factorization - value on the most memory consuming processor): 0
                     INFOG(22) (size in MB of memory effectively used
during factorization - sum over all processors): 0
                     INFOG(23) (after analysis: value of ICNTL(6)
effectively used): 0
                     INFOG(24) (after analysis: value of ICNTL(12)
effectively used): 1
                     INFOG(25) (after factorization: number of pivots
modified by static pivoting): 0
                     INFOG(28) (after factorization: number of null
pivots encountered): 0
                     INFOG(29) (after factorization: effective number of
entries in the factors (sum over all processors)): 0
                     INFOG(30, 31) (after solution: size in Mbytes of
memory used during solution phase): 0, 0
                     INFOG(32) (after analysis: type of analysis done): 1
                     INFOG(33) (value used for ICNTL(8)): 7
                     INFOG(34) (exponent of the determinant if
determinant is requested): 0
                     INFOG(35) (after factorization: number of entries
taking into account BLR factor compression - sum over all processors): 0
                     INFOG(36) (after analysis: estimated size of all
MUMPS internal data for running BLR in-core - value on the most memory
                     INFOG(37) (after analysis: estimated size of all
MUMPS internal data for running BLR in-core - sum over all processors): 0
                     INFOG(38) (after analysis: estimated size of all
MUMPS internal data for running BLR out-of-core - value on the most
                     INFOG(39) (after analysis: estimated size of all
MUMPS internal data for running BLR out-of-core - sum over all
processors): 0
         linear system matrix = precond matrix:
           type: seqaij
           rows=8, cols=8, bs=4
           total number of mallocs used during MatSetValues calls=0
             using I-node routines: found 2 nodes, limit used is 5
         type: seqaij
   Down solver (pre-smoother) on level 1 -------------------------------
     KSP Object: (Options_ProjectionL2_0mg_levels_1_) 1 MPI processes
       type: chebyshev
         eigenvalue estimates used:  min = 0., max = 0.
         eigenvalues estimate via gmres min 0., max 0.
         eigenvalues estimated using gmres with translations  [0. 0.1;
0. 1.1]
         KSP Object: (Options_ProjectionL2_0mg_levels_1_esteig_) 1 MPI
processes
           type: gmres
             restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
             happy breakdown tolerance 1e-30
           maximum iterations=10, initial guess is zero
           tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
         PC Object: (Options_ProjectionL2_0mg_levels_1_) 1 MPI processes
           type: sor
             type = local_symmetric, iterations = 1, local iterations =
1, omega = 1.
           Mat Object: (Options_ProjectionL2_0) 1 MPI processes
             type: seqaij
             rows=36, cols=36, bs=4
             total: nonzeros=656, allocated nonzeros=656
               using I-node routines: found 9 nodes, limit used is 5
         estimating eigenvalues using noisy right hand side
       maximum iterations=2, nonzero initial guess
       type: sor
         type = local_symmetric, iterations = 1, local iterations = 1,
omega = 1.
         type: seqaij
   Up solver (post-smoother) same as down solver (pre-smoother)
     type: seqaij
but I have this option left:
Option left:
name:-Options_ProjectionL2_0mg_coarse_sub_mat_mumps_icntl_24 value: 1
and as you can see above I end with:
rows):               0
which is fatal in my case...
Can you see where I did wrong?
Eric
