[petsc-dev] MatTransposeMatMult() bug
Pierre Jolivet pierre at joliv.et
Thu Mar 18 10:08:44 CDT 2021
Thanks for the suggestion Hong.
I’ve been somehow putting on hold edits in the documentation (src/docs/website/documentation/changes/dev.html notwithstanding) because I’m not sure yet of what will be migrated or not.
But I’ll edit the page according to Patrick’s comment.
Pierre
> On 18 Mar 2021, at 4:00 PM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> Sorry about the current mess but that page is halfway migrated, so any updates should go here:
> https://docs.petsc.org/en/main/install/externalsoftware_documentation/ <https://docs.petsc.org/en/main/install/externalsoftware_documentation/>
>> Am 18.03.2021 um 15:22 schrieb Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>:
>> Pierre,
>> This is an external package to petsc. Shall it be listed at
>> https://www.mcs.anl.gov/petsc/miscellaneous/external.html <https://www.mcs.anl.gov/petsc/miscellaneous/external.html>?
>> PETSc: External Software - anl.gov <https://www.mcs.anl.gov/petsc/miscellaneous/external.html>
>> PETSc interfaces to the following optional external software (installing packages) (manual pages):. AMD - Approximate minimum degree orderings.; BLAS and LAPACK; Chaco - a graph partitioning package.; ESSL - IBM's math library for fast sparse direct LU factorization. FFTW - Fastest Fourier Transform in the West, developed at MIT by Matteo Frigo and Steven G. Johnson.
>> www.mcs.anl.gov <http://www.mcs.anl.gov/>
>> Hong
>> From: Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>
>> Sent: Thursday, March 18, 2021 1:16 AM
>> To: Zhang, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>>
>> Cc: For users of the development version of PETSc <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>> Subject: Re: [petsc-dev] MatTransposeMatMult() bug
>> https://www.sciencedirect.com/science/article/abs/pii/S0898122121000055 <https://www.sciencedirect.com/science/article/abs/pii/S0898122121000055>
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPHPDDM.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPHPDDM.html>
>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHPDDM.html <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHPDDM.html>
>> I need to update the PETSc user manual though, specifically with respect to systems with multiple right-hand sides.
>> But don’t worry, Stefano has sorted the bug out, which was due to a faulty MatSetFromOptions() in MatMAIJ, used by MatTransposeMatMult().
>> Thanks,
>> Pierre
>>> On 17 Mar 2021, at 11:21 PM, Zhang, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>> wrote:
>>> What is hpddm? I do not see its document.
>>> Hong
>>> From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>
>>> Sent: Wednesday, March 17, 2021 2:49 PM
>>> Cc: Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>; For users of the development version of PETSc <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>>> On Wed, Mar 17, 2021 at 3:27 PM Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>>> Pierre,
>>> Do you mean a possible bug in C=AtB MatTransposeMatMult()?
>>> Can you provide a stand-alone test without hpddm that reproduces this error?
>>> Hong, you should be able to just configure with --download-hpddm and then run that ex76 test.
>>>   Thanks,
>>>      Matt
>>> Hong
>>> From: petsc-dev <petsc-dev-bounces at mcs.anl.gov <mailto:petsc-dev-bounces at mcs.anl.gov>> on behalf of Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>>
>>> Sent: Wednesday, March 17, 2021 4:31 AM
>>> To: For users of the development version of PETSc <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>>> Subject: [petsc-dev] MatTransposeMatMult() bug
>>> Hello,
>>> While trying out Stefano’s PCApplyMat_MG() code (*), we stumbled upon weird numerical errors when reusing a Mat for both MatProduct_AB and MatProduct_AtB.
>>> This reminded me that there has been a long-standing issue with MatTransposeMatMult(), see https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/pc/impls/hpddm/hpddm.cxx.html#line608 <https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/pc/impls/hpddm/hpddm.cxx.html#line608>, that I never looked into.
>>> I’ve now been trying to figure this out, because this has side effects in multiple places (PCMG and PCHPDDM at least), and thus could impact user-code as well?
>>> With this commit: https://gitlab.com/petsc/petsc/-/commit/03d8bd538039defc2fcc3e37d523735c4aaceba0 <https://gitlab.com/petsc/petsc/-/commit/03d8bd538039defc2fcc3e37d523735c4aaceba0>
>>> $ mpirun -n 4 src/ksp/ksp/tutorials/ex76 -ksp_converged_reason -pc_type hpddm -pc_hpddm_levels_1_eps_nev 20 -ksp_type preonly -mat_type aij -load_dir ${DATAFILESPATH}/matrices/hpddm/GENEO -rhs 2 -pc_hpddm_coarse_correction balanced -C_input_mattransposematmult -D_output_mattransposematmult
>>> I’m seeing that C is nonzero, but D is full of zeros.
>>> Mat Object: 4 MPI processes
>>>   type: mpidense
>>> 5.7098316584361917e-08 1.0159399260517841e-07
>>> 1.5812349976211856e-07 2.0688121715350138e-07
>>> 2.4887556933361981e-08 4.8111092300772958e-08
>>> 1.4606298643602107e-07 1.7213611729839211e-07
>>>   type: mpidense
>>> 0.0000000000000000e+00 0.0000000000000000e+00
>>> If one switches to a MatType which has no MatProduct_AtB implementation with B of type MPIDense (reminder: in that case, the product is computed column-by-column), e.g., -mat_type sbaij, one gets the expected result.
>>>   type: mpidense
>>> 7.2003197398135299e-01 9.5191869895699011e-01
>>> 6.1793966541680234e-02 9.3884397585488877e-01
>>> 1.0022337823233585e-02 2.4653068080134588e-01
>>> 1.4463931936094099e-01 8.6111517670701687e-01
>>> Is there a bug somewhere with the MatAIJ implementation, or am I doing something which is not allowed by the MatProduct() machinery?
>>> Thanks,
>>> Pierre
>>> (*) https://gitlab.com/petsc/petsc/-/merge_requests/3717 <https://gitlab.com/petsc/petsc/-/merge_requests/3717>
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210318/4ba2a29a/attachment.html>
