[petsc-dev] Case TS005062693 - XLF: ICE in xlfentry compiling a module with 358 subroutines
    Satish Balay
    balay at mcs.anl.gov
    Tue Mar 16 12:56:22 CDT 2021
 Tue, 16 Mar 2021, Jacob Faibussowitsch wrote:
> Ok something I have gotten to work, but only doing things by hand in petscvecmod.F90:
> diff --git a/src/vec/f90-mod/petscvecmod.F90 b/src/vec/f90-mod/petscvecmod.F90
> index 0c447156b9..ef3e2e2e55 100644
> --- a/src/vec/f90-mod/petscvecmod.F90
> +++ b/src/vec/f90-mod/petscvecmod.F90
>  module petscisdef
>  use petscisdefdummy
>  interface operator(.ne.)
>  function isnotequal(A,B)
> -  use petscisdefdummy
> + import tIS
>    logical isnotequal
>    type(tIS), intent(in) :: A,B
generatefortranstubs.py has some hakey parsing code. I guess it can be updated to do this.
i.e - look for 'type(tIS)' and add 'import tIS'
>  end function isnotequal
> This works for everything wrapped in a module which contains an interface block. For dangling functions the following works:
Hm - maybe these are only on the custom side [and not ftn-auto side]
Satish
> + use petscisdef, only: tIs
>    logical isnotequal
>    isnotequal = (A%v .ne. B%v)
> Do our fortran stub generators have any notion of types? Specifically types that originate from petsc?
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
> > On Mar 16, 2021, at 11:11, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Tue, 16 Mar 2021, Jacob Faibussowitsch wrote:
> >>> My [partial] change is in branch balay/reorg-f90-for-xlf
> >> Satish is this branch pushed? I’d like to send it to the ibm folks to see if it works for them as well.
> > Sorry - pushed now. From what I remember - it didn't work.
> > Satish
> >> They also added this extra follow up:
> >> The change we did in the source files is to replace all the "use pet*" statements in all the Interface blocks with IMPORT statement.
> >> The nature of this workaround is to reduce the number of symbols that the compiler have to create, which exceeded the limitation and caused ICE.
> >> Every USE statement in an interface block opens up the module symbol file and reads all the symbols from it and creates an entity for each symbol in compiler. This is unnecessary when the module already has the same USE statement in the module scope. Instead, users can use IMPORT statement to make the module symbols accessible inside interface face blocks.
> >> With the change, the compiler would only read the module symbol file once and create one set of symbols where the old code reads the module symbol files as many times as the number of the USE statements in Interface blocks and create that many sets of duplicate symbols. Replacing those USE statements with IMPORT statements also shortens the compile time significantly.
> >> Best regards,
> >>> On Mar 3, 2021, at 13:43, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> >>> The only change I can get working (i.e avoid compile errors) is to split petscvecmod.F90 into 2 source files - but I don't know if this will help with xlf..
> >>> Satish
> >>>>> Sure - once any change works locally [for gcc and xlf]
> >>>>> When I try - I get a bunch of errors.. [yet to digest them.]
> >>>>>>>>> Can you please give the following source code workaround a try?
> >>>>>>>>> Since there is already "use petscvecdefdummy" at the module scope, one workaround might be to remove the unnecessary "use petscvecdefdummy" in vecnotequal and vecequals
> >>>>>>>>> and all similar procedures.
> >>>>>>>>> For example, the test case has:
> >>>>>>>>>      module petscvecdef
> >>>>>>>>>      function vecnotequal(A,B)
> >>>>>>>>>        logical vecnotequal
> >>>>>>>>>        type(tVec), intent(in) :: A,B
> >>>>>>>>>        vecnotequal = (A%v .ne. B%v)
> >>>>>>>>>      end function
> >>>> Ok - try this suggestion:
> >>>> index 0c447156b9..81968c7ca1 100644
> >>>> @@ -77,7 +77,6 @@
> >>>> -            use petscvecdefdummy
> >>>>            logical vecnotequal
> >>>>          end function
> >>>>         FC arch-linux-c-debug/obj/vec/f90-mod/petscvecmod.o
> >>>> /home/balay/petsc/src/vec/f90-mod/petscvecmod.F90:81:22:
> >>>>  81 |             type(tVec), intent(in) :: A,B
> >>>>     |                      1
> >>>> Error: Derived type ‘tvec’ at (1) is being used before it is defined
> >>>> /home/balay/petsc/include/../src/vec/f90-mod/ftn-auto-interfaces/petscis.h90:2:10:
> >>>>   2 |       use petscvecdef
> >>>>     |          1
> >>>> Fatal Error: Cannot open module file ‘petscvecdef.mod’ for reading at (1): No such file or directory
> >>>> Satish
