[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Mon Mar 15 10:31:59 CDT 2021
Reported timeout bugs to SuperLU_dist too:
https://github.com/xiaoyeli/superlu_dist/issues/69
Eric
On 2021-03-14 2:18 p.m., Eric Chamberland wrote:
> Done:
> https://github.com/hypre-space/hypre/issues/303
> Maybe I will need some help about PETSc to answer their questions...
> Eric
> On 2021-03-14 3:44 a.m., Stefano Zampini wrote:
>> Eric
>> You should report these HYPRE issues upstream
>> <https://github.com/hypre-space/hypre/issues>
>>> On Mar 14, 2021, at 3:44 AM, Eric Chamberland
>>> <Eric.Chamberland at giref.ulaval.ca
>>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>>> For us it clearly creates problems in real computations...
>>> I understand the need to have clean test for PETSc, but for me, it
>>> reveals that hypre isn't usable with more than one thread for now...
>>> Another solution:  force single-threaded configuration for hypre
>>> until this is fixed?
>>> Eric
>>> On 2021-03-13 8:50 a.m., Pierre Jolivet wrote:
>>>> -pc_hypre_boomeramg_relax_type_all Jacobi =>
>>>>   Linear solve did not converge due to DIVERGED_INDEFINITE_PC
>>>> iterations 3
>>>> -pc_hypre_boomeramg_relax_type_all l1scaled-Jacobi =>
>>>> OK, independently of the architecture it seems (Eric Docker image
>>>> with 1 or 2 threads or my macOS), but contraction factor is higher
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 8
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 24
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 26
>>>> v. currently
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 7
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 9
>>>>   Linear solve converged due to CONVERGED_RTOL iterations 10
>>>> Do we change this? Or should we force OMP_NUM_THREADS=1 for make test?
>>>> Thanks,
>>>> Pierre
>>>>> On 13 Mar 2021, at 2:26 PM, Mark Adams <mfadams at lbl.gov
>>>>> <mailto:mfadams at lbl.gov>> wrote:
>>>>> Hypre uses a multiplicative smoother by default. It has a
>>>>> chebyshev smoother. That with a Jacobi PC should be thread invariant.
>>>>> Mark
>>>>> On Sat, Mar 13, 2021 at 8:18 AM Pierre Jolivet <pierre at joliv.et
>>>>> <mailto:pierre at joliv.et>> wrote:
>>>>>>     On 13 Mar 2021, at 9:17 AM, Pierre Jolivet <pierre at joliv.et
>>>>>>     Hello Eric,
>>>>>>     I’ve made an “interesting” discovery, so I’ll put back the
>>>>>>     list in c/c.
>>>>>>     It appears the following snippet of code which uses
>>>>>>     Allreduce() + lambda function + MPI_IN_PLACE is:
>>>>>>     - Valgrind-clean with MPICH;
>>>>>>     - Valgrind-clean with OpenMPI 4.0.5;
>>>>>>     - not Valgrind-clean with OpenMPI 4.1.0.
>>>>>>     I’m not sure who is to blame here, I’ll need to look at the
>>>>>>     MPI specification for what is required by the implementors
>>>>>>     and users in that case.
>>>>>>     In the meantime, I’ll do the following:
>>>>>>     - update config/BuildSystem/config/packages/OpenMPI.py to use
>>>>>>     OpenMPI 4.1.0, see if any other error appears;
>>>>>>     - provide a hotfix to bypass the segfaults;
>>>>>     I can confirm that splitting the single Allreduce with my own
>>>>>     MPI_Op into two Allreduce with MAX and BAND fixes the
>>>>>     segfaults with OpenMPI (*).
>>>>>>     - look at the hypre issue and whether they should be deferred
>>>>>>     to the hypre team.
>>>>>     I don’t know if there is something wrong in hypre threading or
>>>>>     if it’s just a side effect of threading, but it seems that the
>>>>>     number of threads has a drastic effect on the quality of the PC.
>>>>>     By default, it looks that there are two threads per process
>>>>>     with your Docker image.
>>>>>     If I force OMP_NUM_THREADS=1, then I get the same convergence
>>>>>     as in the output file.
>>>>>     Thanks,
>>>>>     Pierre
>>>>>     (*) https://gitlab.com/petsc/petsc/-/merge_requests/3712
>>>>>     <https://gitlab.com/petsc/petsc/-/merge_requests/3712>
>>>>>>     Thank you for the Docker files, they were really useful.
>>>>>>     If you want to avoid oversubscription failures, you can edit
>>>>>>     the file /opt/openmpi-4.1.0/etc/openmpi-default-hostfile and
>>>>>>     append the line:
>>>>>>     localhost slots=12
>>>>>>     If you want to increase the timeout limit of PETSc test suite
>>>>>>     for each test, you can add the extra flag in your command
>>>>>>     line TIMEOUT=180 (default is 60, units are seconds).
>>>>>>     Thanks, I’ll ping you on GitLab when I’ve got something ready
>>>>>>     for you to try,
>>>>>>     Pierre
>>>>>>     <ompi.cxx>
>>>>>>>     On 12 Mar 2021, at 8:54 PM, Eric Chamberland
>>>>>>>     Hi Pierre,
>>>>>>>     I now have a docker container reproducing the problems here.
>>>>>>>     Actually, if I look at
>>>>>>>     snes_tutorials-ex12_quad_singular_hpddm it fails like this:
>>>>>>>     not ok snes_tutorials-ex12_quad_singular_hpddm # Error code: 59
>>>>>>>     #       Initial guess
>>>>>>>     #       L_2 Error: 0.00803099
>>>>>>>     #       Initial Residual
>>>>>>>     #       L_2 Residual: 1.09057
>>>>>>>     #       Au - b = Au + F(0)
>>>>>>>     #       Linear L_2 Residual: 1.09057
>>>>>>>     # [d470c54ce086:14127] Read -1, expected 4096, errno = 1
>>>>>>>     # [d470c54ce086:14128] Read -1, expected 4096, errno = 1
>>>>>>>     # [d470c54ce086:14129] Read -1, expected 4096, errno = 1
>>>>>>>     #       [3]PETSC ERROR:
>>>>>>>     #       [3]PETSC ERROR: Caught signal number 11 SEGV:
>>>>>>>     Segmentation Violation, probably memory access out of range
>>>>>>>     #       [3]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>     -on_error_attach_debugger
>>>>>>>     #       [3]PETSC ERROR: or see
>>>>>>>     https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>     <https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
>>>>>>>     #       [3]PETSC ERROR: or try http://valgrind.org
>>>>>>>     <http://valgrind.org/> on GNU/linux and Apple Mac OS X to
>>>>>>>     find memory corruption errors
>>>>>>>     #       [3]PETSC ERROR: likely location of problem given in
>>>>>>>     stack below
>>>>>>>     #       [3]PETSC ERROR: --------------------- Stack Frames
>>>>>>>     #       [3]PETSC ERROR: Note: The EXACT line numbers in the
>>>>>>>     stack are not available,
>>>>>>>     #       [3]PETSC ERROR:       INSTEAD the line number of the
>>>>>>>     start of the function
>>>>>>>     #       [3]PETSC ERROR:       is given.
>>>>>>>     #       [3]PETSC ERROR: [3] buildTwo line 987
>>>>>>>     /opt/petsc-main/include/HPDDM_schwarz.hpp
>>>>>>>     #       [3]PETSC ERROR: [3] next line 1130
>>>>>>>     #       [3]PETSC ERROR: --------------------- Error Message
>>>>>>>     #       [3]PETSC ERROR: Signal received
>>>>>>>     #       [3]PETSC ERROR: [0]PETSC ERROR:
>>>>>>>     also ex12_quad_hpddm_reuse_baij fails with a lot more "Read
>>>>>>>     -1, expected ..." which I don't know where they come from...?
>>>>>>>     Hypre (like in diff-snes_tutorials-ex56_hypre) is also
>>>>>>>     having DIVERGED_INDEFINITE_PC failures...
>>>>>>>     Please see the 3 attached docker files:
>>>>>>>     1) fedora_mkl_and_devtools : the DockerFile which install
>>>>>>>     fedore 33 with gnu compilers and MKL and everything to develop.
>>>>>>>     2) openmpi: the DockerFile to bluid OpenMPI
>>>>>>>     3) petsc: The las DockerFile that build/install and test PETSc
>>>>>>>     I build the 3 like this:
>>>>>>>     docker build -t fedora_mkl_and_devtools -f
>>>>>>>     fedora_mkl_and_devtools .
>>>>>>>     docker build -t openmpi -f openmpi .
>>>>>>>     docker build -t petsc -f petsc .
>>>>>>>     Disclaimer: I am not a docker expert, so I may do things
>>>>>>>     that are not docker-stat-of-the-art but I am opened to
>>>>>>>     suggestions... ;)
>>>>>>>     I have just ran it on my portable (long) which have not
>>>>>>>     enough cores, so many more tests failed (should force
>>>>>>>     --oversubscribe but don't know how to). I will relaunch on
>>>>>>>     my workstation in a few minutes.
>>>>>>>     I will now test your branch! (sorry for the delay).
>>>>>>>     Thanks,
>>>>>>>     Eric
>>>>>>>     On 2021-03-11 9:03 a.m., Eric Chamberland wrote:
>>>>>>>>     Hi Pierre,
>>>>>>>>     ok, that's interesting!
>>>>>>>>     I will try to build a docker image until tomorrow and give
>>>>>>>>     you the exact recipe to reproduce the bugs.
>>>>>>>>     Eric
>>>>>>>>     On 2021-03-11 2:46 a.m., Pierre Jolivet wrote:
>>>>>>>>>>     On 11 Mar 2021, at 6:16 AM, Barry Smith <bsmith at petsc.dev
>>>>>>>>>>     <mailto:bsmith at petsc.dev>> wrote:
>>>>>>>>>>       Eric,
>>>>>>>>>>      Sorry about not being more immediate. We still have this
>>>>>>>>>>     in our active email so you don't need to submit
>>>>>>>>>>     individual issues. We'll try to get to them as soon as we
>>>>>>>>>>     can.
>>>>>>>>>     Indeed, I’m still trying to figure this out.
>>>>>>>>>     I realized that some of my configure flags were different
>>>>>>>>>     than yours, e.g., no --with-memalign.
>>>>>>>>>     I’ve also added SuperLU_DIST to my installation.
>>>>>>>>>     Still, I can’t reproduce any issue.
>>>>>>>>>     I will continue looking into this, it appears I’m seeing
>>>>>>>>>     some valgrind errors, but I don’t know if this is some
>>>>>>>>>     side effect of OpenMPI not being valgrind-clean (last time
>>>>>>>>>     I checked, there was no error with MPICH).
>>>>>>>>>     Thank you for your patience,
>>>>>>>>>     Pierre
>>>>>>>>>     /usr/bin/gmake -f gmakefile test test-fail=1
>>>>>>>>>     Using MAKEFLAGS: test-fail=1
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_baij.counts
>>>>>>>>>      ok snes_tutorials-ex12_quad_hpddm_reuse_baij
>>>>>>>>>      ok diff-snes_tutorials-ex12_quad_hpddm_reuse_baij
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex33_superlu_dist_2.counts
>>>>>>>>>      ok ksp_ksp_tests-ex33_superlu_dist_2
>>>>>>>>>      ok diff-ksp_ksp_tests-ex33_superlu_dist_2
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex49_superlu_dist.counts
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0
>>>>>>>>>      ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1
>>>>>>>>>      ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex50_tut_2.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex50_tut_2
>>>>>>>>>      ok diff-ksp_ksp_tutorials-ex50_tut_2
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex33_superlu_dist.counts
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_hypre.counts
>>>>>>>>>      ok snes_tutorials-ex56_hypre
>>>>>>>>>      ok diff-snes_tutorials-ex56_hypre
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex56_2.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex56_2
>>>>>>>>>      ok diff-ksp_ksp_tutorials-ex56_2
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_elas.counts
>>>>>>>>>      ok snes_tutorials-ex17_3d_q3_trig_elas
>>>>>>>>>      ok diff-snes_tutorials-ex17_3d_q3_trig_elas
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij.counts
>>>>>>>>>      ok snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
>>>>>>>>>      ok diff-snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist_3.counts
>>>>>>>>>     not ok ksp_ksp_tutorials-ex5_superlu_dist_3 # Error code: 1
>>>>>>>>>     #srun: error: Unable to create step for job 1426755: More
>>>>>>>>>     processors requested than permitted
>>>>>>>>>      ok ksp_ksp_tutorials-ex5_superlu_dist_3 # SKIP Command
>>>>>>>>>     failed so no diff
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex5f_superlu_dist # SKIP Fortran
>>>>>>>>>     required for this test
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_tri_parmetis_hpddm_baij.counts
>>>>>>>>>      ok snes_tutorials-ex12_tri_parmetis_hpddm_baij
>>>>>>>>>      ok diff-snes_tutorials-ex12_tri_parmetis_hpddm_baij
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_tut_3.counts
>>>>>>>>>      ok snes_tutorials-ex19_tut_3
>>>>>>>>>      ok diff-snes_tutorials-ex19_tut_3
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_vlap.counts
>>>>>>>>>      ok snes_tutorials-ex17_3d_q3_trig_vlap
>>>>>>>>>      ok diff-snes_tutorials-ex17_3d_q3_trig_vlap
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist_3.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex5f_superlu_dist_3 # SKIP Fortran
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_superlu_dist.counts
>>>>>>>>>      ok snes_tutorials-ex19_superlu_dist
>>>>>>>>>      ok diff-snes_tutorials-ex19_superlu_dist
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre.counts
>>>>>>>>>      ok
>>>>>>>>>      ok
>>>>>>>>>     diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex49_hypre_nullspace.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex49_hypre_nullspace
>>>>>>>>>      ok diff-ksp_ksp_tutorials-ex49_hypre_nullspace
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_superlu_dist_2.counts
>>>>>>>>>      ok snes_tutorials-ex19_superlu_dist_2
>>>>>>>>>      ok diff-snes_tutorials-ex19_superlu_dist_2
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist_2.counts
>>>>>>>>>     not ok ksp_ksp_tutorials-ex5_superlu_dist_2 # Error code: 1
>>>>>>>>>      ok ksp_ksp_tutorials-ex5_superlu_dist_2 # SKIP Command
>>>>>>>>>     failed so no diff
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre.counts
>>>>>>>>>      ok
>>>>>>>>>      ok
>>>>>>>>>     diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex64_1.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex64_1
>>>>>>>>>      ok diff-ksp_ksp_tutorials-ex64_1
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist.counts
>>>>>>>>>     not ok ksp_ksp_tutorials-ex5_superlu_dist # Error code: 1
>>>>>>>>>      ok ksp_ksp_tutorials-ex5_superlu_dist # SKIP Command
>>>>>>>>>     failed so no diff
>>>>>>>>>           TEST
>>>>>>>>>     arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist_2.counts
>>>>>>>>>      ok ksp_ksp_tutorials-ex5f_superlu_dist_2 # SKIP Fortran
>>>>>>>>>>      Barry
>>>>>>>>>>>     On Mar 10, 2021, at 11:03 PM, Eric Chamberland
>>>>>>>>>>>     Barry,
>>>>>>>>>>>     to get a some follow up on --with-openmp=1 failures,
>>>>>>>>>>>     shall I open gitlab issues for:
>>>>>>>>>>>     a) all hypre failures giving DIVERGED_INDEFINITE_PC
>>>>>>>>>>>     b) all superlu_dist failures giving different results
>>>>>>>>>>>     with initia and "Exceeded timeout limit of 60 s"
>>>>>>>>>>>     c) hpddm failures "free(): invalid next size (fast)" and
>>>>>>>>>>>     "Segmentation Violation"
>>>>>>>>>>>     d) all tao's "Exceeded timeout limit of 60 s"
>>>>>>>>>>>     I don't see how I could do all these debugging by myself...
>>>>>>>>>>>     Thanks,
>>>>>>>>>>>     Eric
>>>>>>>>     Eric Chamberland, ing., M. Ing
>>>>>>>>     Professionnel de recherche
>>>>>>>>     GIREF/Université Laval
>>>>>>>>     (418) 656-2131 poste 41 22 42
>>>>>>>     <fedora_mkl_and_devtools.txt><openmpi.txt><petsc.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210315/547f61a5/attachment-0001.html>
