[petsc-dev] integrate petsc4py tarball generation with petsc tarball generation
Lisandro Dalcin
dalcinl at gmail.com
Mon Mar 15 04:22:54 CDT 2021
On Mon, 15 Mar 2021 at 07:06, Satish Balay <balay at mcs.anl.gov> wrote:
> Lisandro,
> For the upcoming release its best to update lib/petsc/bin/maint/builddist
> to also build petsc4py tarball in sync with petsc tarball.
> What is the current process to generate petsc4py tarball?
> BTW: I stumbled into a couple of issues with building petsc4py docs
> 1. the docs build process requires petsc library to be built?
> python setup.py build_src
> running build_src
> cythonizing 'petsc4py.PETSc.pyx' -> 'petsc4py.PETSc.c'
> cythonizing 'libpetsc4py/libpetsc4py.pyx' -> 'libpetsc4py/libpetsc4py.c'
> mkdir -p docs/apiref
> env CFLAGS=-O0 python2 setup.py -q build --build-lib build/lib.py2
> /usr/bin/ld: cannot find -lpetsc
> collect2: error: ld returned 1 exit status
> error: command 'gcc' failed with exit status 1
> make[2]: *** [makefile:110: epydoc-html] Error 1
> gmake[1]: [makefile:422: sphinx-docs-all] Error 2 (ignored)
> 2. Any particular reason it needs python2? I see it requires
> docutils,epydoc - but I see python3 is able to install them.
It requires petsc4py to be installed in Python 2, such that epydoc can
build the API reference.
I have not found a nice replacement for epydoc-generated documentation.
If Python 2 is an annoyance, then just remove, comment-out anything related
to epydoc in "makefile", and run "make sdist".
But this way the tarball will miss the API reference.
PS: All this could be converted to a script that installs petsc4py and
epydoc in a Python 2 virtual environment, and next users another venv for
the Python 3 Sphinx stuff.
Lisandro Dalcin
Senior Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210315/8f5a3d30/attachment.html>
