[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Mark Adams
mfadams at lbl.gov
Sat Mar 13 11:30:29 CST 2021
On Sat, Mar 13, 2021 at 8:50 AM Pierre Jolivet <pierre at joliv.et> wrote:
> -pc_hypre_boomeramg_relax_type_all Jacobi =>
> Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 3
FYI, You need to use Chebyshev "KSP" with jacobi.
> -pc_hypre_boomeramg_relax_type_all l1scaled-Jacobi =>
> OK, independently of the architecture it seems (Eric Docker image with 1
> or 2 threads or my macOS), but contraction factor is higher
> Linear solve converged due to CONVERGED_RTOL iterations 8
> Linear solve converged due to CONVERGED_RTOL iterations 24
> Linear solve converged due to CONVERGED_RTOL iterations 26
> v. currently
> Linear solve converged due to CONVERGED_RTOL iterations 7
> Linear solve converged due to CONVERGED_RTOL iterations 9
> Linear solve converged due to CONVERGED_RTOL iterations 10
> Do we change this? Or should we force OMP_NUM_THREADS=1 for make test?
The default smoother is pretty good so I'd keep it in the test.
> Thanks,
> Pierre
> On 13 Mar 2021, at 2:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Hypre uses a multiplicative smoother by default. It has a chebyshev
> smoother. That with a Jacobi PC should be thread invariant.
> Mark
> On Sat, Mar 13, 2021 at 8:18 AM Pierre Jolivet <pierre at joliv.et> wrote:
>> On 13 Mar 2021, at 9:17 AM, Pierre Jolivet <pierre at joliv.et> wrote:
>> Hello Eric,
>> I’ve made an “interesting” discovery, so I’ll put back the list in c/c.
>> It appears the following snippet of code which uses Allreduce() + lambda
>> function + MPI_IN_PLACE is:
>> - Valgrind-clean with MPICH;
>> - Valgrind-clean with OpenMPI 4.0.5;
>> - not Valgrind-clean with OpenMPI 4.1.0.
>> I’m not sure who is to blame here, I’ll need to look at the MPI
>> specification for what is required by the implementors and users in that
>> case.
>> In the meantime, I’ll do the following:
>> - update config/BuildSystem/config/packages/OpenMPI.py to use OpenMPI
>> 4.1.0, see if any other error appears;
>> - provide a hotfix to bypass the segfaults;
>> I can confirm that splitting the single Allreduce with my own MPI_Op into
>> two Allreduce with MAX and BAND fixes the segfaults with OpenMPI (*).
>> - look at the hypre issue and whether they should be deferred to the
>> hypre team.
>> I don’t know if there is something wrong in hypre threading or if it’s
>> just a side effect of threading, but it seems that the number of threads
>> has a drastic effect on the quality of the PC.
>> By default, it looks that there are two threads per process with your
>> Docker image.
>> If I force OMP_NUM_THREADS=1, then I get the same convergence as in the
>> output file.
>> Thanks,
>> Pierre
>> (*) https://gitlab.com/petsc/petsc/-/merge_requests/3712
>> Thank you for the Docker files, they were really useful.
>> If you want to avoid oversubscription failures, you can edit the file
>> /opt/openmpi-4.1.0/etc/openmpi-default-hostfile and append the line:
>> localhost slots=12
>> If you want to increase the timeout limit of PETSc test suite for each
>> test, you can add the extra flag in your command line TIMEOUT=180 (default
>> is 60, units are seconds).
>> Thanks, I’ll ping you on GitLab when I’ve got something ready for you to
>> try,
>> Pierre
>> <ompi.cxx>
>> On 12 Mar 2021, at 8:54 PM, Eric Chamberland <
>> Eric.Chamberland at giref.ulaval.ca> wrote:
>> Hi Pierre,
>> I now have a docker container reproducing the problems here.
>> Actually, if I look at snes_tutorials-ex12_quad_singular_hpddm it fails
>> like this:
>> not ok snes_tutorials-ex12_quad_singular_hpddm # Error code: 59
>> # Initial guess
>> # L_2 Error: 0.00803099
>> # Initial Residual
>> # L_2 Residual: 1.09057
>> # Au - b = Au + F(0)
>> # Linear L_2 Residual: 1.09057
>> # [d470c54ce086:14127] Read -1, expected 4096, errno = 1
>> # [d470c54ce086:14128] Read -1, expected 4096, errno = 1
>> # [d470c54ce086:14129] Read -1, expected 4096, errno = 1
>> # [3]PETSC ERROR:
>> # [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>> Violation, probably memory access out of range
>> # [3]PETSC ERROR: Try option -start_in_debugger or
>> -on_error_attach_debugger
>> # [3]PETSC ERROR: or see
>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> # [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>> Apple Mac OS X to find memory corruption errors
>> # [3]PETSC ERROR: likely location of problem given in stack below
>> # [3]PETSC ERROR: --------------------- Stack Frames
>> # [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> # [3]PETSC ERROR: INSTEAD the line number of the start of the
>> function
>> # [3]PETSC ERROR: is given.
>> # [3]PETSC ERROR: [3] buildTwo line 987
>> /opt/petsc-main/include/HPDDM_schwarz.hpp
>> # [3]PETSC ERROR: [3] next line 1130
>> # [3]PETSC ERROR: --------------------- Error Message
>> # [3]PETSC ERROR: Signal received
>> # [3]PETSC ERROR: [0]PETSC ERROR:
>> also ex12_quad_hpddm_reuse_baij fails with a lot more "Read -1, expected
>> ..." which I don't know where they come from...?
>> Hypre (like in diff-snes_tutorials-ex56_hypre) is also having
>> DIVERGED_INDEFINITE_PC failures...
>> Please see the 3 attached docker files:
>> 1) fedora_mkl_and_devtools : the DockerFile which install fedore 33 with
>> gnu compilers and MKL and everything to develop.
>> 2) openmpi: the DockerFile to bluid OpenMPI
>> 3) petsc: The las DockerFile that build/install and test PETSc
>> I build the 3 like this:
>> docker build -t fedora_mkl_and_devtools -f fedora_mkl_and_devtools .
>> docker build -t openmpi -f openmpi .
>> docker build -t petsc -f petsc .
>> Disclaimer: I am not a docker expert, so I may do things that are not
>> docker-stat-of-the-art but I am opened to suggestions... ;)
>> I have just ran it on my portable (long) which have not enough cores, so
>> many more tests failed (should force --oversubscribe but don't know how
>> to). I will relaunch on my workstation in a few minutes.
>> I will now test your branch! (sorry for the delay).
>> Thanks,
>> Eric
>> On 2021-03-11 9:03 a.m., Eric Chamberland wrote:
>> Hi Pierre,
>> ok, that's interesting!
>> I will try to build a docker image until tomorrow and give you the exact
>> recipe to reproduce the bugs.
>> Eric
>> On 2021-03-11 2:46 a.m., Pierre Jolivet wrote:
>> On 11 Mar 2021, at 6:16 AM, Barry Smith <bsmith at petsc.dev> wrote:
>> Eric,
>> Sorry about not being more immediate. We still have this in our active
>> email so you don't need to submit individual issues. We'll try to get to
>> them as soon as we can.
>> Indeed, I’m still trying to figure this out.
>> I realized that some of my configure flags were different than yours,
>> e.g., no --with-memalign.
>> I’ve also added SuperLU_DIST to my installation.
>> Still, I can’t reproduce any issue.
>> I will continue looking into this, it appears I’m seeing some valgrind
>> errors, but I don’t know if this is some side effect of OpenMPI not being
>> valgrind-clean (last time I checked, there was no error with MPICH).
>> Thank you for your patience,
>> Pierre
>> /usr/bin/gmake -f gmakefile test test-fail=1
>> Using MAKEFLAGS: test-fail=1
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_baij.counts
>> ok snes_tutorials-ex12_quad_hpddm_reuse_baij
>> ok diff-snes_tutorials-ex12_quad_hpddm_reuse_baij
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex33_superlu_dist_2.counts
>> ok ksp_ksp_tests-ex33_superlu_dist_2
>> ok diff-ksp_ksp_tests-ex33_superlu_dist_2
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex49_superlu_dist.counts
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0
>> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1
>> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex50_tut_2.counts
>> ok ksp_ksp_tutorials-ex50_tut_2
>> ok diff-ksp_ksp_tutorials-ex50_tut_2
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex33_superlu_dist.counts
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_hypre.counts
>> ok snes_tutorials-ex56_hypre
>> ok diff-snes_tutorials-ex56_hypre
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex56_2.counts
>> ok ksp_ksp_tutorials-ex56_2
>> ok diff-ksp_ksp_tutorials-ex56_2
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_elas.counts
>> ok snes_tutorials-ex17_3d_q3_trig_elas
>> ok diff-snes_tutorials-ex17_3d_q3_trig_elas
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij.counts
>> ok snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
>> ok diff-snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist_3.counts
>> not ok ksp_ksp_tutorials-ex5_superlu_dist_3 # Error code: 1
>> # srun: error: Unable to create step for job 1426755: More processors
>> requested than permitted
>> ok ksp_ksp_tutorials-ex5_superlu_dist_3 # SKIP Command failed so no diff
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist.counts
>> ok ksp_ksp_tutorials-ex5f_superlu_dist # SKIP Fortran required for this
>> test
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_tri_parmetis_hpddm_baij.counts
>> ok snes_tutorials-ex12_tri_parmetis_hpddm_baij
>> ok diff-snes_tutorials-ex12_tri_parmetis_hpddm_baij
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_tut_3.counts
>> ok snes_tutorials-ex19_tut_3
>> ok diff-snes_tutorials-ex19_tut_3
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_vlap.counts
>> ok snes_tutorials-ex17_3d_q3_trig_vlap
>> ok diff-snes_tutorials-ex17_3d_q3_trig_vlap
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist_3.counts
>> ok ksp_ksp_tutorials-ex5f_superlu_dist_3 # SKIP Fortran required for
>> this test
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_superlu_dist.counts
>> ok snes_tutorials-ex19_superlu_dist
>> ok diff-snes_tutorials-ex19_superlu_dist
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre.counts
>> ok snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
>> ok diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex49_hypre_nullspace.counts
>> ok ksp_ksp_tutorials-ex49_hypre_nullspace
>> ok diff-ksp_ksp_tutorials-ex49_hypre_nullspace
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_superlu_dist_2.counts
>> ok snes_tutorials-ex19_superlu_dist_2
>> ok diff-snes_tutorials-ex19_superlu_dist_2
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist_2.counts
>> not ok ksp_ksp_tutorials-ex5_superlu_dist_2 # Error code: 1
>> ok ksp_ksp_tutorials-ex5_superlu_dist_2 # SKIP Command failed so no diff
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre.counts
>> ok snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
>> ok diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex64_1.counts
>> ok ksp_ksp_tutorials-ex64_1
>> ok diff-ksp_ksp_tutorials-ex64_1
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist.counts
>> not ok ksp_ksp_tutorials-ex5_superlu_dist # Error code: 1
>> ok ksp_ksp_tutorials-ex5_superlu_dist # SKIP Command failed so no diff
>> TEST
>> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist_2.counts
>> ok ksp_ksp_tutorials-ex5f_superlu_dist_2 # SKIP Fortran required for
>> this test
>> Barry
>> On Mar 10, 2021, at 11:03 PM, Eric Chamberland <
>> Barry,
>> to get a some follow up on --with-openmp=1 failures, shall I open gitlab
>> issues for:
>> a) all hypre failures giving DIVERGED_INDEFINITE_PC
>> b) all superlu_dist failures giving different results with initia and
>> "Exceeded timeout limit of 60 s"
>> c) hpddm failures "free(): invalid next size (fast)" and "Segmentation
>> Violation"
>> d) all tao's "Exceeded timeout limit of 60 s"
>> I don't see how I could do all these debugging by myself...
>> Thanks,
>> Eric
>> Eric Chamberland, ing., M. Ing
>> Professionnel de recherche
>> GIREF/Université Laval
>> (418) 656-2131 poste 41 22 42
>> <fedora_mkl_and_devtools.txt><openmpi.txt><petsc.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210313/174a8af7/attachment-0001.html>
