[petsc-dev] Argonne GPU Virtual Hackathon - Accepted
Jeremy Luke Thompson Jeremy.Thompson at colorado.edu
Sat Mar 13 00:54:41 CST 2021
I would potentially be interested in joining in on a libCEED + PETSc
integration effort for the hackathon.
On Fri, Mar 12, 2021, 10:17 PM Barry Smith <bsmith at petsc.dev> wrote:
> > On Mar 12, 2021, at 10:49 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at petsc.dev> writes:
> >>>>     I think we should start porting the PetscFE infrastructure,
> numerical integrations, vector and matrix assembly to GPUs soon. It is dog
> slow on CPUs and should be able to deliver higher performance on GPUs.
> >>> IMO, this comes via interfaces to libCEED, not rolling yet another way
> to invoke quadrature routines on GPUs.
> >>   I am not talking about matrix-free stuff, that definitely belongs in
> libCEED, no reason to rewrite.
> >>   But does libCEED also support the traditional finite element
> construction process where the matrices are built explicitly? Or does it
> provide some of the code, integration points, integration formula etc. that
> could be shared and used as a starting point? If it includes all of these
> "traditional" things then we should definitely get it all hooked into
> PetscFE/DMPLEX and go to town. (But yes not so much need for the GPU
> hackathon since it is wiring more than GPU code). The way I have always
> heard about libCEED was as a matrix-free engine, so I may have miss
> understood. It is definitely not my intention to start a project that
> reproduces functionality that we can just use.
> > MFEM wants this too and it's in a draft libCEED PR right now. My intent
> is to ensure it's compatible with Stefano's split-phase COO assembly.
>   Cool, would this be something that, in combination with perhaps some
> libCEED folk, could be incorporated in the Hackathon? Anyone can join our
> group Hackathon group, they don't have to have any financial connection
> with "PETSc".
> >>   We do need solid support for traditional finite element assembly on
> GPUs, matrix-free finite elements alone is not enough.
> > Agreed, and while libCEED could be further optimized for lowest order,
> even naive assembly will be faster than what's in DMPlex.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210312/f5315621/attachment-0001.html>
