[petsc-dev] Argonne GPU Virtual Hackathon - Accepted
Barry Smith
bsmith at petsc.dev
Fri Mar 12 20:06:19 CST 2021
> On Mar 12, 2021, at 6:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at petsc.dev> writes:
>> I think we should start porting the PetscFE infrastructure, numerical integrations, vector and matrix assembly to GPUs soon. It is dog slow on CPUs and should be able to deliver higher performance on GPUs.
> IMO, this comes via interfaces to libCEED, not rolling yet another way to invoke quadrature routines on GPUs.
I am not talking about matrix-free stuff, that definitely belongs in libCEED, no reason to rewrite.
But does libCEED also support the traditional finite element construction process where the matrices are built explicitly? Or does it provide some of the code, integration points, integration formula etc. that could be shared and used as a starting point? If it includes all of these "traditional" things then we should definitely get it all hooked into PetscFE/DMPLEX and go to town. (But yes not so much need for the GPU hackathon since it is wiring more than GPU code). The way I have always heard about libCEED was as a matrix-free engine, so I may have miss understood. It is definitely not my intention to start a project that reproduces functionality that we can just use.
We do need solid support for traditional finite element assembly on GPUs, matrix-free finite elements alone is not enough.
> DMPlex setup and distribution could conceivably be ported to GPUs, but it would be a monumental task and that stuff is usually done once and intermediate structures don't necessarily fit in device memory even when they fit comfortably in DRAM. Way too big of a task for one hackathon.
I am not talking about the setup and distribution, I don't see that as a priority.
