[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Thu Mar 11 08:03:25 CST 2021
Hi Pierre,
ok, that's interesting!
I will try to build a docker image until tomorrow and give you the exact
recipe to reproduce the bugs.
Eric
On 2021-03-11 2:46 a.m., Pierre Jolivet wrote:
>> On 11 Mar 2021, at 6:16 AM, Barry Smith <bsmith at petsc.dev
>> <mailto:bsmith at petsc.dev>> wrote:
>> Eric,
>> Sorry about not being more immediate. We still have this in our
>> active email so you don't need to submit individual issues. We'll try
>> to get to them as soon as we can.
> Indeed, I’m still trying to figure this out.
> I realized that some of my configure flags were different than yours,
> e.g., no --with-memalign.
> I’ve also added SuperLU_DIST to my installation.
> Still, I can’t reproduce any issue.
> I will continue looking into this, it appears I’m seeing some valgrind
> errors, but I don’t know if this is some side effect of OpenMPI not
> being valgrind-clean (last time I checked, there was no error with MPICH).
> Thank you for your patience,
> Pierre
> /usr/bin/gmake -f gmakefile test test-fail=1
> Using MAKEFLAGS: test-fail=1
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_baij.counts
> ok snes_tutorials-ex12_quad_hpddm_reuse_baij
> ok diff-snes_tutorials-ex12_quad_hpddm_reuse_baij
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex33_superlu_dist_2.counts
> ok ksp_ksp_tests-ex33_superlu_dist_2
> ok diff-ksp_ksp_tests-ex33_superlu_dist_2
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex49_superlu_dist.counts
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0
> ok ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1
> ok diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex50_tut_2.counts
> ok ksp_ksp_tutorials-ex50_tut_2
> ok diff-ksp_ksp_tutorials-ex50_tut_2
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tests-ex33_superlu_dist.counts
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_hypre.counts
> ok snes_tutorials-ex56_hypre
> ok diff-snes_tutorials-ex56_hypre
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex56_2.counts
> ok ksp_ksp_tutorials-ex56_2
> ok diff-ksp_ksp_tutorials-ex56_2
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_elas.counts
> ok snes_tutorials-ex17_3d_q3_trig_elas
> ok diff-snes_tutorials-ex17_3d_q3_trig_elas
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij.counts
> ok snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
> ok diff-snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist_3.counts
> not ok ksp_ksp_tutorials-ex5_superlu_dist_3 # Error code: 1
> #srun: error: Unable to create step for job 1426755: More processors
> requested than permitted
> ok ksp_ksp_tutorials-ex5_superlu_dist_3 # SKIP Command failed so no diff
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist.counts
> ok ksp_ksp_tutorials-ex5f_superlu_dist # SKIP Fortran required for
> this test
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex12_tri_parmetis_hpddm_baij.counts
> ok snes_tutorials-ex12_tri_parmetis_hpddm_baij
> ok diff-snes_tutorials-ex12_tri_parmetis_hpddm_baij
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_tut_3.counts
> ok snes_tutorials-ex19_tut_3
> ok diff-snes_tutorials-ex19_tut_3
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex17_3d_q3_trig_vlap.counts
> ok snes_tutorials-ex17_3d_q3_trig_vlap
> ok diff-snes_tutorials-ex17_3d_q3_trig_vlap
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist_3.counts
> ok ksp_ksp_tutorials-ex5f_superlu_dist_3 # SKIP Fortran required for
> this test
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_superlu_dist.counts
> ok snes_tutorials-ex19_superlu_dist
> ok diff-snes_tutorials-ex19_superlu_dist
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre.counts
> ok snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
> ok diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex49_hypre_nullspace.counts
> ok ksp_ksp_tutorials-ex49_hypre_nullspace
> ok diff-ksp_ksp_tutorials-ex49_hypre_nullspace
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex19_superlu_dist_2.counts
> ok snes_tutorials-ex19_superlu_dist_2
> ok diff-snes_tutorials-ex19_superlu_dist_2
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist_2.counts
> not ok ksp_ksp_tutorials-ex5_superlu_dist_2 # Error code: 1
> ok ksp_ksp_tutorials-ex5_superlu_dist_2 # SKIP Command failed so no diff
> TEST
> arch-linux2-c-opt-ompi/tests/counts/snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre.counts
> ok snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
> ok diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex64_1.counts
> ok ksp_ksp_tutorials-ex64_1
> ok diff-ksp_ksp_tutorials-ex64_1
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5_superlu_dist.counts
> not ok ksp_ksp_tutorials-ex5_superlu_dist # Error code: 1
> ok ksp_ksp_tutorials-ex5_superlu_dist # SKIP Command failed so no diff
> TEST
> arch-linux2-c-opt-ompi/tests/counts/ksp_ksp_tutorials-ex5f_superlu_dist_2.counts
> ok ksp_ksp_tutorials-ex5f_superlu_dist_2 # SKIP Fortran required for
> this test
>> Barry
>>> On Mar 10, 2021, at 11:03 PM, Eric Chamberland
>>> <Eric.Chamberland at giref.ulaval.ca
>>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>>> Barry,
>>> to get a some follow up on --with-openmp=1 failures, shall I open
>>> gitlab issues for:
>>> a) all hypre failures giving DIVERGED_INDEFINITE_PC
>>> b) all superlu_dist failures giving different results with initia
>>> and "Exceeded timeout limit of 60 s"
>>> c) hpddm failures "free(): invalid next size (fast)" and
>>> "Segmentation Violation"
>>> d) all tao's "Exceeded timeout limit of 60 s"
>>> I don't see how I could do all these debugging by myself...
>>> Thanks,
>>> Eric
Eric Chamberland, ing., M. Ing
Professionnel de recherche
GIREF/Université Laval
(418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210311/c816422e/attachment.html>
