[petsc-dev] plan to transition to new documentation and webpages?
Patrick Sanan patrick.sanan at gmail.com
Sun Mar 7 12:47:01 CST 2021
Here's my WIP on having the sphinx build include a consistent set of HTML pages from the "classic" docs build.
https://gitlab.com/petsc/petsc/-/merge_requests/3684 <https://gitlab.com/petsc/petsc/-/merge_requests/3684>
> Am 07.03.2021 um 08:37 schrieb Patrick Sanan <patrick.sanan at gmail.com>:
> I'm working on this right now - I think I have a workable way, where we just use the "classic" docs system to build the man pages and HTML sources for each version on RTD, and then specify those HTML files as "extra" to Sphinx, so it just copies them over in the build and we can refer to them with local links (and their internal relative links work). Hopefully I can have a demo in the next couple of days.
>> Am 06.03.2021 um 19:33 schrieb Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov>:
>> This is partly due to the complexity of having some docs from 'release' and some from 'main' branches.
>> We had a way to manage this when all docs were on petsc website - but its not clear how to do this properly with readthedocs
>> Satish
>> On Fri, 5 Mar 2021, Barry Smith wrote:
>>> What is the plan to transition to the new documentation and webpages?
>>> I go to https://www.mcs.anl.gov/petsc/index.html <https://www.mcs.anl.gov/petsc/index.html> and mostly see the old stuff etc. Our next release is coming up soon and it would be nice to have transitioned out of the old material and to the new material by/at the new release.
>>> What do we need to do to make this happen?
>>>  Thanks
>>>  Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210307/3f9472cf/attachment.html>
