[petsc-dev] 32 bit compilers and PETSc
Barry Smith
bsmith at petsc.dev
Thu Mar 4 12:37:01 CST 2021
Not really bad compilers. Just 32 bit compilers. 640k is all anyone will ever need.
> On Mar 4, 2021, at 10:13 AM, Scott Kruger <kruger at txcorp.com> wrote:
> On 2021-03-04 08:58, Satish Balay via petsc-dev did write:
>> On Wed, 3 Mar 2021, Barry Smith wrote:
>>> Can we make ./configure ban 32 bit compilers unless a special flag is used? And just have one CI test that uses 32 bit where we turn off examples that overflow 32 bits?
>> We could add another linux test where 32bit part is more obvious.
>> And we have "requires: defined(FLAG)" but not sure if we can check for "PETSC_SIZEOF_VOID_P 8" this way. Perhaps we can add to configure:
>> requires: defined(PETSC_USING_64BIT_PTR)
>> or
>> requires: !defined(PETSC_USING_32BIT_PTR)
> This sounds like a lot of work just to figure out which tests overflow,
> and then clutter up the tests just to fix bad compilers. For example,
> does the "medium" test matrix cause overflow? Perhaps we could just
> turn off any external file reading?
> Scott
>> Satish
>> diff --git a/config/BuildSystem/config/types.py b/config/BuildSystem/config/types.py
>> index 39eda33099..d35adae503 100644
>> --- a/config/BuildSystem/config/types.py
>> +++ b/config/BuildSystem/config/types.py
>> @@ -268,6 +268,8 @@ char petsc_max_path_len[] = xstr(PETSC_MAX_PATH_LEN);
>> 'enum': (4, 8),
>> 'size_t': (8, 4)}.items():
>> self.executeTest(self.checkSizeof, args=[t, sizes])
>> + if self.sizes['void-p'] == 8:
>> + self.addDefine('USING_64BIT_PTR',1)
>> self.executeTest(self.checkVisibility)
>> self.executeTest(self.checkMaxPathLen)
>> return
>> ./configure CFLAGS=-m32 CXXFLAGS=-m32 FFLAGS=-m32 --with-mpi=0 && make && make check
> Scott Kruger
> Tech-X Corporation kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
> Boulder, CO 80303 Fax: (303) 448-7756
