[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Tue Mar 2 23:21:19 CST 2021
Just started a discussion on the side:
https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Intel-MKL-Link-Line-Advisor-as-external-tool/m-p/1260895#M30974
Eric
On 2021-03-02 3:50 p.m., Pierre Jolivet wrote:
> Hello Eric,
> src/mat/tests/ex237.c is a recent test with some code paths that
> should be disabled for “old” MKL versions. It’s tricky to check
> directly in the source (we do check in BuildSystem) because there is
> no such thing as PETSC_PKG_MKL_VERSION_LT, but I guess we can change
> if defined(PETSC_HAVE_MKL) to if defined(PETSC_HAVE_MKL) &&
> defined(PETSC_HAVE_MKL_SPARSE_OPTIMIZE), I’ll make a MR, thanks for
> reporting this.
> For the other issues, I’m sensing this is a problem with gomp +
> intel_gnu_thread, but this is pure speculation… sorry.
> I’ll try to reproduce some of these problems if you are not given a
> more meaningful answer.
> Thanks,
> Pierre
>> On 2 Mar 2021, at 9:14 PM, Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca
>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>> Hi,
>> It all started when I wanted to test PETSC/CUDA compatibility for our
>> code.
>> I had to activate --with-openmp to configure with --with-cuda=1
>> successfully.
>> I then saw that PETSC_HAVE_OPENMP  is used at least in MUMPS (and
>> some other places).
>> So, I configured and tested petsc with openmp activated, without CUDA.
>> The first thing I see is that our code CI pipelines now fails for
>> many tests.
>> After looking deeper, it seems that PETSc itself fails many tests
>> when I activate openmp!
>> Here are all the configurations I have results for, after/before
>> activating OpenMP for PETSc:
>> For petsc/master + OpenMPI 4.0.4 + MKL 2019.4.243:
>> With OpenMP=1
>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_configure.log
>> #   Summary
>> # FAILED snes_tutorials-ex12_quad_hpddm_reuse_baij diff-ksp_ksp_tests-ex33_superlu_dist_2 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1 ksp_ksp_tutorials-ex50_tut_2 diff-ksp_ksp_tests-ex33_superlu_dist diff-snes_tutorials-ex56_hypre snes_tutorials-ex17_3d_q3_trig_elas snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij ksp_ksp_tutorials-ex5_superlu_dist_3 ksp_ksp_tutorials-ex5f_superlu_dist snes_tutorials-ex12_tri_parmetis_hpddm_baij diff-snes_tutorials-ex19_tut_3 mat_tests-ex242_3 snes_tutorials-ex17_3d_q3_trig_vlap ksp_ksp_tutorials-ex5f_superlu_dist_3 snes_tutorials-ex19_superlu_dist diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre diff-ksp_ksp_tutorials-ex49_hypre_nullspace ts_tutorials-ex18_p1p1_xper_ref ts_tutorials-ex18_p1p1_xyper_ref snes_tutorials-ex19_superlu_dist_2 ksp_ksp_tutorials-ex5_superlu_dist_2 diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre ksp_ksp_tutorials-ex64_1 ksp_ksp_tutorials-ex5_superlu_dist ksp_ksp_tutorials-ex5f_superlu_dist_2
>> # success 8275/10003 tests (82.7%)
>> #*failed 33/10003*  tests (0.3%)
>> With OpenMP=0
>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_configure.log
>> #   Summary
>> # FAILED tao_constrained_tutorials-tomographyADMM_6 snes_tutorials-ex17_3d_q3_trig_elas mat_tests-ex242_3 snes_tutorials-ex17_3d_q3_trig_vlap tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_5
>> # success 8262/9983 tests (82.8%)
>> #*failed 6/9983*  tests (0.1%)
>> For OpenMPI 3.1.x/master:
>> With OpenMP=1:
>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_configure.log
>> #   Summary
>> # FAILED mat_tests-ex242_3 mat_tests-ex242_2 diff-mat_tests-ex219f_1 diff-dm_tutorials-ex11f90_1 ksp_ksp_tutorials-ex5_superlu_dist_3 diff-ksp_ksp_tutorials-ex49_hypre_nullspace ksp_ksp_tutorials-ex5f_superlu_dist_3 snes_tutorials-ex17_3d_q3_trig_vlap diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre diff-snes_tutorials-ex19_tut_3 diff-snes_tutorials-ex56_hypre diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_4 tao_constrained_tutorials-tomographyADMM_6 diff-tao_constrained_tutorials-toyf_1
>> # success 8142/9765 tests (83.4%)
>> #*failed 16/9765*  tests (0.2%)
>> With OpenMP=0:
>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_configure.log
>> #   Summary
>> # FAILED mat_tests-ex242_3 mat_tests-ex242_2 diff-mat_tests-ex219f_1 diff-dm_tutorials-ex11f90_1 ksp_ksp_tutorials-ex56_2 snes_tutorials-ex17_3d_q3_trig_vlap tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_4 diff-tao_constrained_tutorials-toyf_1
>> # success 8151/9767 tests (83.5%)
>> #*failed 9/9767*  tests (0.1%)
>> For OpenMPI 4.0.x/master:
>> With OpenMP=1:
>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_configure.log
>> # FAILED snes_tutorials-ex17_3d_q3_trig_elas snes_tutorials-ex19_hypre ksp_ksp_tutorials-ex56_2 tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_5 mat_tests-ex242_3 ksp_ksp_tutorials-ex55_hypre ksp_ksp_tutorials-ex5_superlu_dist_2 tao_constrained_tutorials-tomographyADMM_6 snes_tutorials-ex56_hypre snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre ksp_ksp_tutorials-ex5f_superlu_dist_3 ksp_ksp_tutorials-ex34_hyprestruct diff-ksp_ksp_tutorials-ex49_hypre_nullspace snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre ksp_ksp_tutorials-ex5f_superlu_dist ksp_ksp_tutorials-ex5f_superlu_dist_2 ksp_ksp_tutorials-ex5_superlu_dist snes_tutorials-ex19_tut_3 snes_tutorials-ex19_superlu_dist ksp_ksp_tutorials-ex50_tut_2 snes_tutorials-ex17_3d_q3_trig_vlap ksp_ksp_tutorials-ex5_superlu_dist_3 snes_tutorials-ex19_superlu_dist_2 tao_constrained_tutorials-tomographyADMM_4 ts_tutorials-ex26_2
>> # success 8125/9753 tests (83.3%)
>> #*failed 26/9753*  tests (0.3%)
>> With OpenMP=0
>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_configure.log
>> # success 8174/9777 tests (83.6%)
>> #*failed 1/9777*  tests (0.0%)
>> Is that known and normal?
>> In all cases, I am using MKL and I suspect it  may come from there... :/
>> I also saw a second problem, "make test" fails to compile petsc
>> examples on older versions of MKL (but that's less important for me,
>> I just upgraded to OneAPI to avoid this, but you may want to know):
>> https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_make_test.log
>> https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_configure.log
>> Thanks,
>> Eric
>> Eric Chamberland, ing., M. Ing
>> Professionnel de recherche
>> GIREF/Université Laval
>> (418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210303/a7544a41/attachment-0001.html>
