[petsc-dev] Petsc "make test" have more failures for --with-openmp=1
Pierre Jolivet
pierre at joliv.et
Tue Mar 2 14:50:43 CST 2021
Hello Eric,
src/mat/tests/ex237.c is a recent test with some code paths that should be disabled for “old” MKL versions. It’s tricky to check directly in the source (we do check in BuildSystem) because there is no such thing as PETSC_PKG_MKL_VERSION_LT, but I guess we can change if defined(PETSC_HAVE_MKL) to if defined(PETSC_HAVE_MKL) && defined(PETSC_HAVE_MKL_SPARSE_OPTIMIZE), I’ll make a MR, thanks for reporting this.
For the other issues, I’m sensing this is a problem with gomp + intel_gnu_thread, but this is pure speculation… sorry.
I’ll try to reproduce some of these problems if you are not given a more meaningful answer.
Pierre
> On 2 Mar 2021, at 9:14 PM, Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi,
> It all started when I wanted to test PETSC/CUDA compatibility for our code.
> I had to activate --with-openmp to configure with --with-cuda=1 successfully.
> I then saw that PETSC_HAVE_OPENMP is used at least in MUMPS (and some other places).
> So, I configured and tested petsc with openmp activated, without CUDA.
> The first thing I see is that our code CI pipelines now fails for many tests.
> After looking deeper, it seems that PETSc itself fails many tests when I activate openmp!
> Here are all the configurations I have results for, after/before activating OpenMP for PETSc:
> For petsc/master + OpenMPI 4.0.4 + MKL 2019.4.243:
> With OpenMP=1
> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_make_test.log <https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_configure.log <https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.03.02.02h00m02s_configure.log>
> # Summary
> # FAILED snes_tutorials-ex12_quad_hpddm_reuse_baij diff-ksp_ksp_tests-ex33_superlu_dist_2 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-0_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-1herm-1_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-0_conv-1 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-0 diff-ksp_ksp_tests-ex49_superlu_dist+nsize-4herm-1_conv-1 ksp_ksp_tutorials-ex50_tut_2 diff-ksp_ksp_tests-ex33_superlu_dist diff-snes_tutorials-ex56_hypre snes_tutorials-ex17_3d_q3_trig_elas snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij ksp_ksp_tutorials-ex5_superlu_dist_3 ksp_ksp_tutorials-ex5f_superlu_dist snes_tutorials-ex12_tri_parmetis_hpddm_baij diff-snes_tutorials-ex19_tut_3 mat_tests-ex242_3 snes_tutorials-ex17_3d_q3_trig_vlap ksp_ksp_tutorials-ex5f_superlu_dist_3 snes_tutorials-ex19_superlu_dist diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre diff-ksp_ksp_tutorials-ex49_hypre_nullspace ts_tutorials-ex18_p1p1_xper_ref ts_tutorials-ex18_p1p1_xyper_ref snes_tutorials-ex19_superlu_dist_2 ksp_ksp_tutorials-ex5_superlu_dist_2 diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre ksp_ksp_tutorials-ex64_1 ksp_ksp_tutorials-ex5_superlu_dist ksp_ksp_tutorials-ex5f_superlu_dist_2
> # success 8275/10003 tests (82.7%)
> # failed 33/10003 tests (0.3%)
> With OpenMP=0
> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_make_test.log <https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_configure.log <https://giref.ulaval.ca/~cmpgiref/petsc-master-debug/2021.02.26.02h00m16s_configure.log>
> # Summary
> # FAILED tao_constrained_tutorials-tomographyADMM_6 snes_tutorials-ex17_3d_q3_trig_elas mat_tests-ex242_3 snes_tutorials-ex17_3d_q3_trig_vlap tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_5
> # success 8262/9983 tests (82.8%)
> # failed 6/9983 tests (0.1%)
> For OpenMPI 3.1.x/master:
> With OpenMP=1:
> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_make_test.log <https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_configure.log <https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.03.01.22h00m01s_configure.log>
> # Summary
> # FAILED mat_tests-ex242_3 mat_tests-ex242_2 diff-mat_tests-ex219f_1 diff-dm_tutorials-ex11f90_1 ksp_ksp_tutorials-ex5_superlu_dist_3 diff-ksp_ksp_tutorials-ex49_hypre_nullspace ksp_ksp_tutorials-ex5f_superlu_dist_3 snes_tutorials-ex17_3d_q3_trig_vlap diff-snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre diff-snes_tutorials-ex19_tut_3 diff-snes_tutorials-ex56_hypre diff-snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_4 tao_constrained_tutorials-tomographyADMM_6 diff-tao_constrained_tutorials-toyf_1
> # success 8142/9765 tests (83.4%)
> # failed 16/9765 tests (0.2%)
> With OpenMP=0:
> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_make_test.log <https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_configure.log <https://giref.ulaval.ca/~cmpgiref/ompi_3.x/2021.02.28.22h00m02s_configure.log>
> # Summary
> # FAILED mat_tests-ex242_3 mat_tests-ex242_2 diff-mat_tests-ex219f_1 diff-dm_tutorials-ex11f90_1 ksp_ksp_tutorials-ex56_2 snes_tutorials-ex17_3d_q3_trig_vlap tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_4 diff-tao_constrained_tutorials-toyf_1
> # success 8151/9767 tests (83.5%)
> # failed 9/9767 tests (0.1%)
> For OpenMPI 4.0.x/master:
> With OpenMP=1:
> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_make_test.log <https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_configure.log <https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.03.01.20h00m01s_configure.log>
> # FAILED snes_tutorials-ex17_3d_q3_trig_elas snes_tutorials-ex19_hypre ksp_ksp_tutorials-ex56_2 tao_leastsquares_tutorials-tomography_1 tao_constrained_tutorials-tomographyADMM_5 mat_tests-ex242_3 ksp_ksp_tutorials-ex55_hypre ksp_ksp_tutorials-ex5_superlu_dist_2 tao_constrained_tutorials-tomographyADMM_6 snes_tutorials-ex56_hypre snes_tutorials-ex56_attach_mat_nearnullspace-0_bddc_approx_hypre ksp_ksp_tutorials-ex5f_superlu_dist_3 ksp_ksp_tutorials-ex34_hyprestruct diff-ksp_ksp_tutorials-ex49_hypre_nullspace snes_tutorials-ex56_attach_mat_nearnullspace-1_bddc_approx_hypre ksp_ksp_tutorials-ex5f_superlu_dist ksp_ksp_tutorials-ex5f_superlu_dist_2 ksp_ksp_tutorials-ex5_superlu_dist snes_tutorials-ex19_tut_3 snes_tutorials-ex19_superlu_dist ksp_ksp_tutorials-ex50_tut_2 snes_tutorials-ex17_3d_q3_trig_vlap ksp_ksp_tutorials-ex5_superlu_dist_3 snes_tutorials-ex19_superlu_dist_2 tao_constrained_tutorials-tomographyADMM_4 ts_tutorials-ex26_2
> # success 8125/9753 tests (83.3%)
> # failed 26/9753 tests (0.3%)
> With OpenMP=0
> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_make_test.log <https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_configure.log <https://giref.ulaval.ca/~cmpgiref/ompi_4.x/2021.02.28.20h00m04s_configure.log>
> # success 8174/9777 tests (83.6%)
> # failed 1/9777 tests (0.0%)
> Is that known and normal?
> In all cases, I am using MKL and I suspect it may come from there... :/
> I also saw a second problem, "make test" fails to compile petsc examples on older versions of MKL (but that's less important for me, I just upgraded to OneAPI to avoid this, but you may want to know):
> https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_make_test.log <https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_make_test.log>
> https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_configure.log <https://giref.ulaval.ca/~cmpgiref/dernier_ompi/2021.03.02.02h16m01s_configure.log>
> Thanks,
> Eric
> Eric Chamberland, ing., M. Ing
> Professionnel de recherche
> GIREF/Université Laval
> (418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/c58e8a4b/attachment.html>
