[petsc-dev] problem registering a new solver
Mark Adams
mfadams at lbl.gov
Tue Mar 2 14:42:22 CST 2021
I am trying to add a band solver to PETSc (later to be moved to Cuda and
Kokkos) and I have started by adding some types and a copy of the current
LU as placeholders. I register with:
ierr = MatSolverTypeRegister(MATSOLVERPETSC, MATSEQAIJ,
MAT_FACTOR_LUBAND,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);
And that is about all that I do that can have any effect at this point. I
add a switch in MatGetFactor_seqaij_petsc on (ftype == MAT_FACTOR_LUBAND)
to set the symbolic factorization method (*B)->ops->lufactorsymbolic =
MatLUBandFactorSymbolic_SeqAIJ; But this is not called (I verified this)
because I don't know how to get MatGetFactor_seqaij_petsc to receive ftype
== MAT_FACTOR_LUBAND. (I need help on this to)
Anyway, I would hope that these changes would not do anything but I get an
error (appended).
It is failing in MatSolverTypeDestroy on this second PetscFree:
while (inext) {
ierr = PetscFree(inext->mtype);CHKERRQ(ierr);
iprev = inext;
inext = inext->next;
ierr = PetscFree(iprev);CHKERRQ(ierr);
I tried to clone LU here, but I clearly missed something.
Any ideas?
And I just made an MR for this if you want to look at the code.
Number of SNES iterations = 2
[0]PETSC ERROR: PetscTrFreeDefault() called from MatSolverTypeDestroy()
line 4513 in /Users/markadams/Codes/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: Block [id=0(48)] at address 0x7fb7fb8f7620 is corrupted
(probably write past end of array)
[0]PETSC ERROR: Block allocated in MatSolverTypeRegister() line 4382 in
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Memory corruption:
https://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
[0]PETSC ERROR: Corrupted memory
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.14.4-739-g575f931ef8
GIT Date: 2021-03-02 13:38:55 -0500
[0]PETSC ERROR: ./ex19 on a arch-macosx-gnu-g named MarksMac-302.local by
markadams Tue Mar 2 15:28:41 2021
[0]PETSC ERROR: Configure options
--with-mpi-dir=/usr/local/Cellar/mpich/3.3.2_1 COPTFLAGS="-g -O0"
CXXOPTFLAGS="-g -O0" --download-metis=1 --download-parmetis=1
--download-kokkos=1 --download-kokkos-kernels=1 --download-p4est=1
--with-zlib=1 --download-superlu_dist --download-superlu --with-make-np=4
--download-hdf5=1 -with-cuda=0 --with-x=0 --with-debugging=1
PETSC_ARCH=arch-macosx-gnu-g --with-64-bit-indices=0 --with-openmp=0
--with-ctable=0
[0]PETSC ERROR: #1 PetscTrFreeDefault() line 310 in
/Users/markadams/Codes/petsc/src/sys/memory/mtr.c
[0]PETSC ERROR: #2 MatSolverTypeDestroy() line 4513 in
[0]PETSC ERROR: #3 MatFinalizePackage() line 57 in
/Users/markadams/Codes/petsc/src/mat/interface/dlregismat.c
[0]PETSC ERROR: #4 PetscRegisterFinalizeAll() line 389 in
/Users/markadams/Codes/petsc/src/sys/objects/destroy.c
[0]PETSC ERROR: #5 PetscFinalize() line 1474 in
/Users/markadams/Codes/petsc/src/sys/objects/pinit.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/2a096980/attachment-0001.html>
