[petsc-dev] VecGetArrayAndMemType
    Mark Adams
    mfadams at lbl.gov
    Thu Jun 24 16:30:16 CDT 2021
OK, I see that this change is aimed at _not_ having the application keep
track of the time step and allow for incrementing the step number.
That is definitely a better design.
I will change these two tests to use this new system.
ex19 uses a Viewer. I would prefer the ViewFromOptions method. Not sure
this works.
On Thu, Jun 24, 2021 at 5:19 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Jun 24, 2021 at 3:05 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 24, 2021 at 9:58 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> OK, I tried again and deleted the arch directory every time:
>> Okay, this changes the interface for OutputSequenceNumber. It _should_ be
>> backwards compatible. The likely error I would think
>> is that it thinks you have a timestep at first but not later, however
>> that should be an HDF5 error. Maybe it think the timestep is always
>> the same and overwrites?
> * The symptom seems to be that there is only one time step in the file and
> it is the last one. So yes, it seems to overwrite one file location over
> and over.
> * I commented out the 2nd View call in ex1 and the file was only 8 bytes
> smaller (eg, the time step). The .xmf file was a bit under 2x bigger.
> * Visit "sees" all the time steps. That is, I can step through or run a
> movie of all the time steps, but the data is exactly the same at all steps.
> I've run longer problems with ex2, for each time step.
> Mark
>>   Thanks,
>>      Matt
>>> (base) 09:56 (84933e400a...)|BISECTING ~/Codes/petsc2$ git bisect good
>>> d7dd068b66a8daa3a37c9e1556b34bd8def54922 is the first bad commit
>>> commit d7dd068b66a8daa3a37c9e1556b34bd8def54922
>>> Author: Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>>> Date:   Wed Apr 14 21:22:37 2021 +0200
>>>     HDF5: Improve timestepping.
>>>     * add PetscViewerHDF5{Push,Pop,Is}Timestepping to control
>>> timestepping mode
>>>     * write timestepping attribute for datasets and check it on reading
>>>     * fail gracefully if trying to read non-timestepped dataset in
>>> timestepping mode and vice-versa (fix #425)
>>>     * rewrite src/vec/vec/tutorials/ex19.c to improve coverage for
>>> timestepping testing
>>>  doc/documentation/changes/dev.rst         |  19 ++-
>>>  include/petsc/private/viewerhdf5impl.h    |   2 +
>>>  include/petscviewerhdf5.h                 |   4 +
>>>  src/dm/impls/da/gr2.c                     |  21 ++--
>>>  src/dm/impls/plex/plexhdf5.c              |  25 +++-
>>>  src/sys/classes/viewer/impls/hdf5/hdf5v.c | 124 ++++++++++++++++++--
>>>  src/vec/is/is/impls/general/general.c     |  10 +-
>>>  src/vec/is/utils/hdf5io.c                 |  45 +++++---
>>>  src/vec/vec/impls/mpi/pdvec.c             |  14 ++-
>>>  src/vec/vec/tutorials/ex19.c              | 186
>>>  src/vec/vec/tutorials/output/ex19_2.out   |   0
>>>  src/vec/vec/tutorials/output/ex19_3.out   |   0
>>>  src/vec/vec/tutorials/output/ex19_4.out   |   0
>>>  13 files changed, 320 insertions(+), 130 deletions(-)
>>>  delete mode 100644 src/vec/vec/tutorials/output/ex19_2.out
>>>  delete mode 100644 src/vec/vec/tutorials/output/ex19_3.out
>>>  delete mode 100644 src/vec/vec/tutorials/output/ex19_4.out
>>> On Thu, Jun 24, 2021 at 7:04 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Jun 24, 2021 at 7:00 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> OK, this is what I get with bisect:
>>>>> (base) 06:54 (c3b2925bfb...)|BISECTING ~/Codes/petsc2$ git bisect good
>>>>> The merge base c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47 is bad.
>>>>> This means the bug has been fixed between
>>>>> c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47 and
>>>>> [09da24df01e50defd94bc4f7396f866a808ecea5
>>>>> c3b2925bfbe1c0a0b3a69c9a76295d0747e33d47].
>>>>> (base) 06:56 (v3.15.1) ~/Codes/petsc2$ git checkout
>>>>> Previous HEAD position was 09da24df01 Increase patchlevel to 3.15.1
>>>>> HEAD is now at c3b2925bfb Merge branch 'knepley-main-patch-78504' into
>>>>> 'release'
>>>>> (base) 06:56 (c3b2925bfb...) ~/Codes/petsc2$
>>>> I do not understand. Neither of those commits do anything.
>>>>    Matt
>>>>> On Wed, Jun 23, 2021 at 11:14 PM Junchao Zhang <
>>>>> junchao.zhang at gmail.com> wrote:
>>>>>> Mark,
>>>>>>   I am not sure what your problem is.  If it is a regression, can you
>>>>>> bisect it?
>>>>>> --Junchao Zhang
>>>>>> On Wed, Jun 23, 2021 at 4:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> I also tried commenting out the second VecView, so there is just one
>>>>>>> step in the file, and the .h5 file is only 8 bytes smaller and the .xmf
>>>>>>> file goes from 5373  bytes to 3090 bytes.
>>>>>>> On Wed, Jun 23, 2021 at 4:01 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> It is not a device issue but it is a regression.
>>>>>>>> Landau ex1 is tiny and just calls VecView before and after the
>>>>>>>> TSsolve, which is one time step. If you add "*-dm_view hdf5:f.h5
>>>>>>>> -vec_view hdf5:f.h5::append -dm_landau_Ez 10.*" to landau/ex1 (see
>>>>>>>> below), you get an h5 file with two time steps, as it should be.
>>>>>>>> This is a huge electric field, Ez=10, which makes the electron
>>>>>>>> distribution (u_e) get visibly pulled off center.
>>>>>>>> In Visit, both time steps have identical data that is clearly after
>>>>>>>> the solve and not the initial condition (see attached).
>>>>>>>> I ran this again with -ex1_ts_max_steps 0 and get the expected
>>>>>>>> result of two steps/frames with the symmetric initial condition in both.
>>>>>>>> THis is correct behavior.
>>>>>>>> Any ideas?
>>>>>>>> Thanks
>>>>>>>> diff --git a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>>> b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>>> index 9e4c8f1b61..31dfda2fad 100644
>>>>>>>> --- a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>>> +++ b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>>>>>>>> @@ -66,6 +66,6 @@ int main(int argc, char **argv)
>>>>>>>>    test:
>>>>>>>>      suffix: 0
>>>>>>>>      requires: p4est !complex
>>>>>>>> -    args: -petscspace_degree 3 -petscspace_poly_tensor 1
>>>>>>>> -dm_landau_type p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18
>>>>>>>> -dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0
>>>>>>>> 1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14
>>>>>>>> -ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex
>>>>>>>> -ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1
>>>>>>>> -ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25
>>>>>>>> -ex1_ts_adapt_scale_solve_failed 0.75
>>>>>>>> -ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type
>>>>>>>> lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7
>>>>>>>> -dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius
>>>>>>>> 1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0
>>>>>>>> -dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2
>>>>>>>> .1 -dm_refine 1 -dm_landau_gpu_assembly false
>>>>>>>> +    args: -petscspace_degree 3 -petscspace_poly_tensor 1
>>>>>>>> .1 -dm_refine 1 -dm_landau_gpu_assembly false *-dm_view hdf5:f.h5
>>>>>>>>  TEST*/
>>>>>>>> On Wed, Jun 23, 2021 at 1:38 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> Landau ex1 should work. I will test.
>>>>>>>>> On Wed, Jun 23, 2021 at 10:47 AM Matthew Knepley <
>>>>>>>>>> On Wed, Jun 23, 2021 at 10:44 AM Junchao Zhang <
>>>>>>>>>>> Use VecGetArrayRead/Write() to get up-to-date host pointers to
>>>>>>>>>>> the vector array.
>>>>>>>>>> I think Mark is saying that those are not working. We do call
>>>>>>>>>> VecGetArrayRead() in the HDF5 code.
>>>>>>>>>> Mark, it seem like a small broken code is necessary.
>>>>>>>>>>   Thanks,
>>>>>>>>>>     Matt
>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>> On Wed, Jun 23, 2021 at 9:15 AM Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> First, there seem to be two pages for VecGetArrayAndMemType
>>>>>>>>>>>> (one has a pointer to the other).
>>>>>>>>>>>> So I need to get a CPU array for HDF5 viewing. Totally broken
>>>>>>>>>>>> for devices.
>>>>>>>>>>>> I don't find a VecGetArrayCpu[HOST] that does the right thing.
>>>>>>>>>>>> Perhaps have VecGetArrayAndMemType return a valid CPU pointer
>>>>>>>>>>>> when "mtype==NULL"?
>>>>>>>>>>>> Mark
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210624/c935224e/attachment.html>
