[petsc-dev] kokkos test fail in branch
    Junchao Zhang
    junchao.zhang at gmail.com
    Sat Jun  5 21:52:11 CDT 2021
This problem was fixed in
https://gitlab.com/petsc/petsc/-/merge_requests/4056, and is waiting for
!3411 <https://gitlab.com/petsc/petsc/-/merge_requests/3411> :)
--Junchao Zhang
On Sat, Jun 5, 2021 at 9:42 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Looks like the MPI libraries are not being passed to the NVCC internal
> compiler (gcc). This would normally be setup in MPI.py, please send
> configure.log
>   Barry
> On Jun 5, 2021, at 1:18 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Ah, there was an old one there. I removed it and I can not compile ex3k. I
> thought check always rebuilt executables. Now I get a link error:
> 14:12 barry/2020-11-11/cleanup-matsetvaluesdevice *=
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ make
> PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
> PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 ex3k
> PATH=/sw/sources/lsf-tools/2.0/summit/bin:/sw/summit/xalt/1.2.1/bin:/sw/summit/forge/20.0.1/bin:/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/bin:/sw/summit/gcc/6.4.0/bin:/sw/summit/cuda/10.1.243/bin:/autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/cmake-3.20.2-24ualfzy6em6ws5sbiu7rlgcuionodrm/bin:/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/darshan-runtime-3.1.7-cnvxicgf5j4ap64qi6v5gxp67hmrjz43/bin:/sw/sources/hpss/bin:/opt/ibm/spectrumcomputing/lsf/
> 10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/etc:/opt/ibm/spectrumcomputing/lsf/10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/bin:/opt/ibm/csm/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/ibm/flightlog/bin:/opt/ibutils/bin:/opt/ibm/spectrum_mpi/jsm_pmix/bin:/opt/puppetlabs/bin:/usr/lpp/mmfs/bin:`dirname
> <http://10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/etc:/opt/ibm/spectrumcomputing/lsf/10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/bin:/opt/ibm/csm/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/ibm/flightlog/bin:/opt/ibutils/bin:/opt/ibm/spectrum_mpi/jsm_pmix/bin:/opt/puppetlabs/bin:/usr/lpp/mmfs/bin:%60dirname>
> nvcc` NVCC_WRAPPER_DEFAULT_COMPILER=gcc
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/bin/nvcc_wrapper
> --expt-extended-lambda -Xcompiler -rdynamic -lineinfo -DLANDAU_DIM=2
> -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4
> -Xcompiler -fPIC -O3  -gencode arch=compute_70,code=sm_70
>  -I/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/include
> -Wno-deprecated-gpu-targets
>  -I/gpfs/alpine/csc314/scratch/adams/petsc/include
> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include
> -I/sw/summit/cuda/10.1.243/include
>   -fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC
> -DLANDAU_MAX_Q=4 -Werror=maybe-uninitialized -O0   ex3k.kokkos.cxx
>  -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib
> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib
> -L/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/netlib-lapack-3.8.0-wcabdyqhdi5rooxbkqa6x5d7hxyxwdkm/lib64
> -Wl,-rpath,/sw/summit/cuda/10.1.243/lib64 -L/sw/summit/cuda/10.1.243/lib64
> -lpetsc -lkokkoskernels -lkokkoscontainers -lkokkoscore -lp4est -lsc -lblas
> -llapack -ltriangle -lm -lz -lcudart -lcufft -lcublas -lcusparse -lcusolver
> -lcurand -lstdc++ -ldl -o ex3k
> nvcc_wrapper - *warning* you have set multiple optimization flags (-O*),
> only the last is used because nvcc can only accept a single optimization
> setting.
> */usr/bin/ld: /tmp/tmpxft_0000e0c2_00000000-10_ex3k.kokkos.o: undefined
> reference to symbol 'ompi_mpi_comm_self'*/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/lib/libmpi_ibm.so.3:
> error adding symbols: DSO missing from command line
> collect2: error: ld returned 1 exit status
> make: *** [ex3k] Error 1
> On Sat, Jun 5, 2021 at 12:16 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> $rm ex3k
>> $make ex3k
>> and run again?
>> --Junchao Zhang
>> On Sat, Jun 5, 2021 at 10:25 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> This is posted in Barry's MR, but I get this error with Kokkos-cuda on
>>> Summit. Failing to open a shared lib.
>>> Thoughts?
>>> Mark
>>> 11:15 barry/2020-11-11/cleanup-matsetvaluesdevice=
>>> /gpfs/alpine/csc314/scratch/adams/petsc$ make
>>> PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check
>>> Running check examples to verify correct installation
>>> Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>> processes
>>> C/C++ example src/snes/tutorials/ex19 run successfully with cuda
>>> gmake[3]: [runex3k_kokkos] Error 127 (ignored)
>>> 1,25c1,2
>>> < atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000
>>> < Vec Object: Exact Solution 2 MPI processes
>>> <   type: mpikokkos
>>> < Process [0]
>>> < 0.
>>> < 0.015625
>>> < 0.125
>>> < Process [1]
>>> < 0.421875
>>> < 1.
>>> < Vec Object: Forcing function 2 MPI processes
>>> <   type: mpikokkos
>>> < Process [0]
>>> < 1e-72
>>> < 1.50024
>>> < 3.01563
>>> < Process [1]
>>> < 4.67798
>>> < 7.
>>> <   0 SNES Function norm 5.414682427127e+00
>>> <   1 SNES Function norm 2.952582418265e-01
>>> <   2 SNES Function norm 4.502293658739e-04
>>> <   3 SNES Function norm 1.389665806646e-09
>>> < Number of SNES iterations = 3
>>> < Norm of error 1.49752e-10 Iterations 3
>>> *> ./ex3k: error while loading shared libraries: libpetsc.so.3.015:
>>> cannot open shared object file: No such file or directory> ./ex3k: error
>>> while loading shared libraries: libpetsc.so.3.015: cannot open shared
>>> object file: No such file or directory*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210605/0e19398d/attachment-0001.html>
