[petsc-dev] Kokkos make error on Spock
Mark Adams mfadams at lbl.gov
Sun Jul 18 09:29:21 CDT 2021
Whoops, this error was just from not telling gfortran to allow long lines.
Anway, I did find that the when fortran bindings are enabled this OMP thing
gets into the library. No idea how. I'll askm ORNL.
10:26 jczhang/fix-cray-mpicxx-includes/main=
/gpfs/alpine/csc314/scratch/adams/petsc2$ nm
/gpfs/alpine/csc314/scratch/adams/petsc2/arch-spock-opt-cray-kokkos/lib/libpetsc.so
|g offload
                 U .omp_offloading.img_cache.cray_amdgcn-amd-amdhsa
                 U .omp_offloading.img_size.cray_amdgcn-amd-amdhsa
                 U .omp_offloading.img_start.cray_amdgcn-amd-amdhsa
0000000001d457b0 T vecgetoffloadmask_
On Sun, Jul 18, 2021 at 8:43 AM Mark Adams <mfadams at lbl.gov> wrote:
> Ah, your test was not on Spock ... I have something working but this is
> strange.
> I switched to the GNU ProgEnv. and it passed the Fortran test in 'check',
> but this failed:
> *08:26 2 jczhang/fix-cray-mpicxx-includes/main=
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ make
> PETSC_DIR=/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-dbg-gnu
> PETSC_ARCH="" ex40f90ftn -L/sw/spock/spack-envs/views/rocm-4.1.0/lib
> -lamdhip64 -lhsa-runtime64  -fPIC -g -O0   -fPIC -g -O0
>  -I/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-dbg-gnu/include
> -I/sw/spock/spack-envs/views/rocm-4.1.0/include     ex40f90.F90
>  -Wl,-rpath,/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-dbg-gnu/lib
> -L/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-dbg-gnu/lib
> -Wl,-rpath,/sw/spock/spack-envs/views/rocm-4.1.0/lib
> -Wl,-rpath,/opt/cray/pe/mpich/8.1.4/ofi/gnu/9.1/lib
> -L/opt/cray/pe/mpich/8.1.4/ofi/gnu/9.1/lib
> -Wl,-rpath,/opt/cray/pe/mpich/8.1.4/gtl/lib
> -L/opt/cray/pe/mpich/8.1.4/gtl/lib
> -Wl,-rpath,/opt/cray/pe/libsci/21.04.1.1/GNU/9.1/x86_64/lib
> <http://21.04.1.1/GNU/9.1/x86_64/lib>
> -L/opt/cray/pe/libsci/21.04.1.1/GNU/9.1/x86_64/lib
> -Wl,-rpath,/opt/cray/pe/pmi/6.0.10/lib -L/opt/cray/pe/pmi/6.0.10/lib
> -Wl,-rpath,/opt/cray/pe/dsmml/0.1.4/dsmml/lib
> -L/opt/cray/pe/dsmml/0.1.4/dsmml/lib
> -Wl,-rpath,/opt/cray/xpmem/2.2.40-2.1_2.7__g3cf3325.shasta/lib64
> -L/opt/cray/xpmem/2.2.40-2.1_2.7__g3cf3325.shasta/lib64
> -Wl,-rpath,/opt/gcc/10.2.0/snos/lib/gcc/x86_64-suse-linux/10.2.0
> -L/opt/gcc/10.2.0/snos/lib/gcc/x86_64-suse-linux/10.2.0
> -Wl,-rpath,/opt/gcc/10.2.0/snos/lib64 -L/opt/gcc/10.2.0/snos/lib64
> -Wl,-rpath,/sw/spock/spack-envs/views/rocm-4.1.0/llvm/lib
> -L/sw/spock/spack-envs/views/rocm-4.1.0/llvm/lib
> -Wl,-rpath,/opt/gcc/10.2.0/snos/lib -L/opt/gcc/10.2.0/snos/lib -lpetsc
> -lhipsparse -lhipblas -lrocsparse -lrocsolver -lrocblas -lamdhip64
> -lhsa-runtime64 -lstdc++ -ldl -lpmi -lmpi_gtl_hsa -lxpmem -lgfortran -lm
> -lsci_gnu_82_mpi -lsci_gnu_82 -lmpifort_gnu_91 -lmpi_gnu_91 -ldsmml
> -lgfortran -lquadmath -lpthread -lm -lgcc_s -lquadmath -lstdc++ -ldl -o
> ex40f90ex40f90.F90:35:132:   35 |       call
> DMDACreate2d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,ten,ten,PETSC_DECIDE,PETSC_DECIDE,two,one,
>        1Error:
> Line truncated at (1) [-Werror=line-truncation]ex40f90.F90:35:132:*
> But ex5f (the Fortran check test) does work manually also (sanity check).
> Oddly I seem to have the cray compilers:
> 08:34 jczhang/fix-cray-mpicxx-includes/main=
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ which ftn
> /opt/cray/pe/craype/2.7.6/bin/ftn
> yet it is GNU:
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ ftn --version
> GNU Fortran (GCC) 10.2.0 20200723 (Cray Inc.)
> Copyright (C) 2020 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> The documentation says ftn should be here:
> $GCC_PATH/bin/gfortran --version
> Same, but the path is not the same:
> 08:39 jczhang/fix-cray-mpicxx-includes/main=
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ echo $GCC_PATH
> /opt/gcc/10.2.0
> Anyway, thanks for your help,
> Mark
> On Sat, Jul 17, 2021 at 11:26 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Mark,  I can reproduce this error with PrgEnv-cray, i.e., using the Cray
>> compiler (clang-11).  Previously I used PrgEnv-gnu, which did not have this
>> error.
>> Probably it is a problem of Spock.  But I am not sure.
>> --Junchao Zhang
>> On Sat, Jul 17, 2021 at 10:17 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> And I can run a fortran test, with warnings, but C tests fail:
>>> 11:15 jczhang/fix-cray-mpicxx-includes/main=
>>> /gpfs/alpine/csc314/scratch/adams/petsc$ make
>>> PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
>>> PETSC_ARCH=arch-spock-opt-cray-kokkos -f gmakefile test
>>> search='ts_utils_dmplexlandau_tutorials-ex1f90_0'
>>> Using MAKEFLAGS: -- search=ts_utils_dmplexlandau_tutorials-ex1f90_0
>>>           FC
>>> arch-spock-opt-cray-kokkos/tests/ts/utils/dmplexlandau/tutorials/ex1f90.o
>>>      FLINKER
>>> /opt/cray/pe/cce/11.0.4/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld:
>>> warning: alignment 128 of symbol
>>> `$host_init$$runtime_init_for_iso_c_binding$iso_c_binding_' in
>>> /opt/cray/pe/cce/11.0.4/cce/x86_64/lib/libmodules.so is smaller than 256 in
>>> warning: alignment 64 of symbol `$data_init$iso_c_binding_' in
>>>         TEST
>>> arch-spock-opt-cray-kokkos/tests/counts/ts_utils_dmplexlandau_tutorials-ex1f90_0.counts
>>>  ok ts_utils_dmplexlandau_tutorials-ex1f90_0
>>>  ok diff-ts_utils_dmplexlandau_tutorials-ex1f90_0
>>> On Sat, Jul 17, 2021 at 10:53 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> HUmm, I can not reproduce this.
>>>> 10:49 jczhang/fix-cray-mpicxx-includes/main=
>>>> PETSC_ARCH=arch-spock-dbg-kokkos check
>>>> Running check examples to verify correct installation
>>>> Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
>>>> gmake[3]:
>>>> [/gpfs/alpine/csc314/scratch/adams/petsc/lib/petsc/conf/rules:301:
>>>> ex19.PETSc] Error 2 (ignored)
>>>> *******************Error detected during compile or
>>>> link!*******************
>>>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex19
>>>> cc -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lamdhip64
>>>> -lhsa-runtime64  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>>> -Wno-unknown-pragmas -fstack-protector -Qunused-arguments
>>>> -fvisibility=hidden -g -O0  -fPIC -Wall -Wwrite-strings
>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
>>>> -Qunused-arguments -fvisibility=hidden -g -O0
>>>> -I/gpfs/alpine/csc314/scratch/adams/petsc/include
>>>> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/include
>>>>  -I/sw/spock/spack-envs/views/rocm-4.1.0/include    ex19.c
>>>>  -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/lib
>>>> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/lib
>>>> -Wl,-rpath,/opt/gcc/8.1.0/snos/lib64 -L/opt/gcc/8.1.0/snos/lib64
>>>> -Wl,-rpath,/opt/cray/pe/libsci/21.04.1.1/CRAY/9.0/x86_64/lib
>>>> -L/opt/cray/pe/libsci/21.04.1.1/CRAY/9.0/x86_64/lib
>>>> -Wl,-rpath,/opt/cray/pe/mpich/8.1.4/ofi/cray/9.1/lib
>>>> -L/opt/cray/pe/mpich/8.1.4/ofi/cray/9.1/lib
>>>> -L/opt/cray/pe/mpich/8.1.4/gtl/lib -Wl,-rpath,/opt/cray/pe/pmi/6.0.10/lib
>>>> -L/opt/cray/pe/pmi/6.0.10/lib -Wl,-rpath,/opt/cray/pe/dsmml/0.1.4/dsmml/lib
>>>> -Wl,-rpath,/opt/cray/pe/cce/11.0.4/cce/x86_64/lib
>>>> -L/opt/cray/pe/cce/11.0.4/cce/x86_64/lib
>>>> -Wl,-rpath,/opt/cray/pe/cce/11.0.4/cce-clang/x86_64/lib/clang/11.0.0/lib/linux
>>>> -L/opt/cray/pe/cce/11.0.4/cce-clang/x86_64/lib/clang/11.0.0/lib/linux
>>>> -Wl,-rpath,/opt/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
>>>> -L/opt/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
>>>> -Wl,-rpath,/opt/cray/pe/cce/11.0.4/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib
>>>> -L/opt/cray/pe/cce/11.0.4/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib
>>>> -lpetsc -lkokkoskernels -lkokkoscontainers -lkokkoscore -lhipsparse
>>>> -lhipblas -lrocsparse -lrocsolver -lrocblas -lamdhip64 -lhsa-runtime64
>>>> -lstdc++ -ldl -lpmi -lsci_cray_mpi -lsci_cray -lmpifort_cray -lmpi_cray
>>>> -lmpi_gtl_hsa -lxpmem -ldsmml -lpgas-shmem -lquadmath -lcrayacc_amdgpu
>>>> -lopenacc -lmodules -lfi -lcraymath -lf -lu -lcsup -lgfortran -lpthread
>>>> -lgcc_eh -lm -lclang_rt.craypgo-x86_64 -lclang_rt.builtins-x86_64
>>>> -lquadmath -lstdc++ -ldl -o ex19
>>>> ld.lld: error:
>>>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/lib/libpetsc.so:
>>>> undefined reference to .omp_offloading.img_start.cray_amdgcn-amd-amdhsa
>>>> [--no-allow-shlib-undefined]
>>>> ld.lld: error:
>>>> undefined reference to .omp_offloading.img_size.cray_amdgcn-amd-amdhsa
>>>> ld.lld: error:
>>>> undefined reference to .omp_offloading.img_cache.cray_amdgcn-amd-amdhsa
>>>> clang-11: error: linker command failed with exit code 1 (use -v to see
>>>> invocation)
>>>> gmake[4]: *** [<builtin>: ex19] Error 1
>>>> gmake[3]:
>>>> ex3k.PETSc] Error 2 (ignored)
>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex3k
>>>> hipcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>>> -Wno-unknown-pragmas -fvisibility=hidden -g -O0 -std=c++14
>>>>  -I/sw/spock/spack-envs/views/rocm-4.1.0/include    -I/opt/cray/pe/libsci/
>>>> 21.04.1.1/CRAY/9.0/x86_64/include
>>>> -I/opt/cray/pe/mpich/8.1.4/ofi/cray/9.1/include
>>>> -I/opt/cray/pe/pmi/6.0.10/include -I/opt/cray/pe/dsmml/0.1.4/dsmml//include
>>>> -I/opt/cray/xpmem/2.2.40-2.1_2.7__g3cf3325.shasta/include
>>>> -L/opt/cray/pe/mpich/8.1.4/gtl/lib -L/opt/cray/pe/pmi/6.0.10/lib
>>>> -L/opt/cray/pe/dsmml/0.1.4/dsmml//lib
>>>> -L/opt/cray/pe/cce/11.0.4/cce/x86_64/lib/pkgconfig/../
>>>> -Wl,--as-needed,-lsci_cray_mpi,--no-as-needed
>>>> -Wl,--as-needed,-lsci_cray,--no-as-needed
>>>> -Wl,--as-needed,-lmpi_cray,--no-as-needed
>>>> -Wl,--as-needed,-ldsmml,--no-as-needed
>>>> -Wl,--as-needed,-lpgas-shmem,--no-as-needed  -lpmi -ldl -lmpi_gtl_hsa
>>>> -lxpmem -lquadmath -lmodules -lfi -lcraymath -lf -lu -lcsup
>>>>  ex3k.kokkos.cxx
>>>> -lquadmath -lstdc++ -ldl -o ex3k
>>>> /usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld:
>>>> undefined reference to `.omp_offloading.img_size.cray_amdgcn-amd-amdhsa'
>>>> undefined reference to `.omp_offloading.img_start.cray_amdgcn-amd-amdhsa'
>>>> undefined reference to `.omp_offloading.img_cache.cray_amdgcn-amd-amdhsa'
>>>> clang-12: error: linker command failed with exit code 1 (use -v to see
>>>> invocation)
>>>> gmake[4]: ***
>>>> [/gpfs/alpine/csc314/scratch/adams/petsc/lib/petsc/conf/test:26: ex3k]
>>>> Error 1
>>>> gmake[3]: [makefile:102: runex3k_kokkos] Error 2 (ignored)
>>>> 1,25c1,4
>>>> < atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000
>>>> < Vec Object: Exact Solution 2 MPI processes
>>>> <   type: mpikokkos
>>>> < Process [0]
>>>> < 0.
>>>> < 0.015625
>>>> < 0.125
>>>> < Process [1]
>>>> < 0.421875
>>>> < 1.
>>>> < Vec Object: Forcing function 2 MPI processes
>>>> <   type: mpikokkos
>>>> < Process [0]
>>>> < 1e-72
>>>> < 1.50024
>>>> < 3.01563
>>>> < Process [1]
>>>> < 4.67798
>>>> < 7.
>>>> <   0 SNES Function norm 5.414682427127e+00
>>>> <   1 SNES Function norm 2.952582418265e-01
>>>> <   2 SNES Function norm 4.502293658739e-04
>>>> <   3 SNES Function norm 1.389665806646e-09
>>>> < Number of SNES iterations = 3
>>>> < Norm of error 1.49752e-10 Iterations 3
>>>> > slurmstepd: error: execve():
>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials/./ex3k: No such
>>>> file or directory
>>>> file or directory
>>>> > srun: error: spock01: tasks 0-1: Exited with exit code 2
>>>> > srun: launch/slurm: _step_signal: Terminating StepId=272979.0
>>>> Possible problem with ex3k running with kokkos-kernels, diffs above
>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex5f
>>>> ftn -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lamdhip64
>>>> -I/sw/spock/spack-envs/views/rocm-4.1.0/include     ex5f.F90
>>>> -lquadmath -lstdc++ -ldl -o ex5f
>>>> /tmp/pe_30429/ex5f_1.o
>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>>> process
>>>> Completed test examples
>>>> /gpfs/alpine/csc314/scratch/adams/petsc$ ll
>>>> On Fri, Jul 16, 2021 at 11:28 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> Mark, I configured with Fortran binding enabled with main + MR !4175
>>>>> <https://gitlab.com/petsc/petsc/-/merge_requests/4175>
>>>>> '--with-mpiexec=srun',
>>>>> '--with-shared-libraries=1',
>>>>> '--with-cc=cc',
>>>>> '--with-cxx=CC',
>>>>> '--with-fc=ftn',
>>>>> '--with-fortran-bindings',
>>>>> '--with-hip',
>>>>> '--with-hipc=hipcc',
>>>>> '--with-debugging',
>>>>> '--CPPFLAGS=-I${ROCM_PATH}/include',
>>>>> '--CXXPPFLAGS=-I${ROCM_PATH}/include',
>>>>> '--CC_LINKER_FLAGS=-L${ROCM_PATH}/lib -lamdhip64 -lhsa-runtime64',
>>>>> '--CXX_LINKER_FLAGS=-L${ROCM_PATH}/lib -lamdhip64 -lhsa-runtime64',
>>>>> '--FC_LINKER_FLAGS=-L${ROCM_PATH}/lib -lamdhip64 -lhsa-runtime64',
>>>>> '--COPTFLAGS=-g -O0',
>>>>> '--CXXOPTFLAGS=-g -O0',
>>>>> '--FOPTFLAGS=-g -O0',
>>>>> '--download-kokkos',
>>>>> '--download-kokkos-kernels',
>>>>> '--download-kokkos-commit=3.4.01',
>>>>> '--download-kokkos-kernels-commit=3.4.01',
>>>>> '--with-kokkos-hip-arch=VEGA908',
>>>>> and 'make check' ran smoothly on a compute node
>>>>> $ make check
>>>>> Using PETSC_DIR=/ccs/home/jczhang/petsc and
>>>>> PETSC_ARCH=arch-spock-cray-kokkos-dbg
>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>> process
>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>> processes
>>>>> C/C++ example src/snes/tutorials/ex3k run successfully with
>>>>> kokkos-kernels
>>>>> process
>>>>> --Junchao Zhang
>>>>> On Fri, Jul 16, 2021 at 6:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> And I find that this error, on non-Kokkos C tests, is fixed by
>>>>>> turning the fortran bindings off:
>>>>>> ld.lld: error:
>>>>>> /gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/lib/libpetsc.so:
>>>>>> ld.lld: error:
>>>>>> ld.lld: error:
>>>>>> On Fri, Jul 16, 2021 at 3:53 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> Not complex. THis has some overlap with my problem w/o Kokkos.
>>>>>>> On Fri, Jul 16, 2021 at 12:54 PM Junchao Zhang <
>>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>>> Do you use complex? post your configure.log.
>>>>>>>> --Junchao Zhang
>>>>>>>> On Fri, Jul 16, 2021 at 9:47 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> The simple Kokkos example is failing for me on Spock.
>>>>>>>>> Any ideas?
>>>>>>>>> Thanks,
>>>>>>>>> 10:44 main *=
>>>>>>>>> PETSC_ARCH=arch-spock-opt-cray-kokkos ex3k
>>>>>>>>> MPICH_CXX="hipcc" OMPI_CXX="hipcc" CC
>>>>>>>>> -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lhsa-runtime64
>>>>>>>>> -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lamdhip64 -lhsa-runtime64
>>>>>>>>>  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>>>>>>>>> -fstack-protector -fvisibility=hidden -g -O2   -fPIC -Wall -Wwrite-strings
>>>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O3
>>>>>>>>> -std=c++14  -I/gpfs/alpine/csc314/scratch/adams/petsc/include
>>>>>>>>> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/include
>>>>>>>>> -I/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include
>>>>>>>>>  -I/sw/spock/spack-envs/views/rocm-4.1.0/include    ex3k.kokkos.cxx
>>>>>>>>>  -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/lib
>>>>>>>>> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/lib
>>>>>>>>> -Wl,-rpath,/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/lib
>>>>>>>>> -L/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/lib
>>>>>>>>> In file included from ex3k.kokkos.cxx:3:
>>>>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscdmda_kokkos.hpp:4:
>>>>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscvec_kokkos.hpp:14:
>>>>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscvec.h:9:
>>>>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscsys.h:42:
>>>>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscsystypes.h:255:
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/Kokkos_Complex.hpp:47:
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/Kokkos_Atomic.hpp:212:
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Atomic_Exchange.hpp:259:11:
>>>>>>>>> error: no member named 'lock_address_host_space' in namespace
>>>>>>>>> 'Kokkos::Impl::Kokkos::Impl'; did you mean simply 'lock_address_host_space'?
>>>>>>>>>   while (!Impl::lock_address_host_space((void*)dest))
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/Kokkos_HostSpace.hpp:83:6:
>>>>>>>>> note: 'lock_address_host_space' declared here
>>>>>>>>> bool lock_address_host_space(void* ptr);
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Atomic_Exchange.hpp:261:3:
>>>>>>>>> error: no member named 'memory_fence' in namespace 'Kokkos::Impl::Kokkos';
>>>>>>>>> did you mean simply 'memory_fence'?
>>>>>>>>>   Kokkos::memory_fence();
>>>>>>>>>   memory_fence
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Memory_Fence.hpp:53:6:
>>>>>>>>> note: 'memory_fence' declared here
>>>>>>>>> void memory_fence() {
>>>>>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Atomic_Exchange.hpp:277:3:
>>>>>>>>>   memory_fence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210718/450d5a53/attachment-0001.html>
