[petsc-dev] Kokkos make error on Spock
Mark Adams
mfadams at lbl.gov
Sat Jul 17 09:53:29 CDT 2021
HUmm, I can not reproduce this.
10:49 jczhang/fix-cray-mpicxx-includes/main=
/gpfs/alpine/csc314/scratch/adams/petsc$ make
PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
PETSC_ARCH=arch-spock-dbg-kokkos check
Running check examples to verify correct installation
Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
gmake[3]:
[/gpfs/alpine/csc314/scratch/adams/petsc/lib/petsc/conf/rules:301:
ex19.PETSc] Error 2 (ignored)
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex19
cc -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lamdhip64 -lhsa-runtime64
-fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fstack-protector -Qunused-arguments -fvisibility=hidden -g -O0 -fPIC
-I/sw/spock/spack-envs/views/rocm-4.1.0/include
-I/gpfs/alpine/csc314/scratch/adams/petsc/include
-I/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/include
-I/sw/spock/spack-envs/views/rocm-4.1.0/include ex19.c
-Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/lib
-L/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/lib
-Wl,-rpath,/sw/spock/spack-envs/views/rocm-4.1.0/lib
-Wl,-rpath,/opt/gcc/8.1.0/snos/lib64 -L/opt/gcc/8.1.0/snos/lib64
-Wl,-rpath,/opt/cray/pe/libsci/21.04.1.1/CRAY/9.0/x86_64/lib
-L/opt/cray/pe/libsci/21.04.1.1/CRAY/9.0/x86_64/lib
-Wl,-rpath,/opt/cray/pe/mpich/8.1.4/ofi/cray/9.1/lib
-L/opt/cray/pe/mpich/8.1.4/ofi/cray/9.1/lib
-Wl,-rpath,/opt/cray/pe/mpich/8.1.4/gtl/lib
-L/opt/cray/pe/mpich/8.1.4/gtl/lib -Wl,-rpath,/opt/cray/pe/pmi/6.0.10/lib
-L/opt/cray/pe/pmi/6.0.10/lib -Wl,-rpath,/opt/cray/pe/dsmml/0.1.4/dsmml/lib
-L/opt/cray/pe/dsmml/0.1.4/dsmml/lib
-Wl,-rpath,/opt/cray/pe/cce/11.0.4/cce/x86_64/lib
-L/opt/cray/pe/cce/11.0.4/cce/x86_64/lib
-Wl,-rpath,/opt/cray/xpmem/2.2.40-2.1_2.7__g3cf3325.shasta/lib64
-L/opt/cray/xpmem/2.2.40-2.1_2.7__g3cf3325.shasta/lib64
-Wl,-rpath,/opt/cray/pe/cce/11.0.4/cce-clang/x86_64/lib/clang/11.0.0/lib/linux
-L/opt/cray/pe/cce/11.0.4/cce-clang/x86_64/lib/clang/11.0.0/lib/linux
-Wl,-rpath,/opt/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
-L/opt/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
-Wl,-rpath,/opt/cray/pe/cce/11.0.4/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib
-L/opt/cray/pe/cce/11.0.4/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib
-lpetsc -lkokkoskernels -lkokkoscontainers -lkokkoscore -lhipsparse
-lhipblas -lrocsparse -lrocsolver -lrocblas -lamdhip64 -lhsa-runtime64
-lstdc++ -ldl -lpmi -lsci_cray_mpi -lsci_cray -lmpifort_cray -lmpi_cray
-lmpi_gtl_hsa -lxpmem -ldsmml -lpgas-shmem -lquadmath -lcrayacc_amdgpu
-lopenacc -lmodules -lfi -lcraymath -lf -lu -lcsup -lgfortran -lpthread
-lgcc_eh -lm -lclang_rt.craypgo-x86_64 -lclang_rt.builtins-x86_64
-lquadmath -lstdc++ -ldl -o ex19
ld.lld: error:
/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-dbg-kokkos/lib/libpetsc.so:
undefined reference to .omp_offloading.img_start.cray_amdgcn-amd-amdhsa
[--no-allow-shlib-undefined]
ld.lld: error:
undefined reference to .omp_offloading.img_size.cray_amdgcn-amd-amdhsa
ld.lld: error:
undefined reference to .omp_offloading.img_cache.cray_amdgcn-amd-amdhsa
clang-11: error: linker command failed with exit code 1 (use -v to see
invocation)
gmake[4]: *** [<builtin>: ex19] Error 1
gmake[3]:
ex3k.PETSc] Error 2 (ignored)
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex3k
hipcc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-fvisibility=hidden -g -O0 -std=c++14
-I/sw/spock/spack-envs/views/rocm-4.1.0/include -I/opt/cray/pe/libsci/
21.04.1.1/CRAY/9.0/x86_64/include
-I/opt/cray/pe/mpich/8.1.4/ofi/cray/9.1/include
-I/opt/cray/pe/pmi/6.0.10/include -I/opt/cray/pe/dsmml/0.1.4/dsmml//include
-I/opt/cray/xpmem/2.2.40-2.1_2.7__g3cf3325.shasta/include
-L/opt/cray/pe/mpich/8.1.4/gtl/lib -L/opt/cray/pe/pmi/6.0.10/lib
-L/opt/cray/pe/dsmml/0.1.4/dsmml//lib
-L/opt/cray/pe/cce/11.0.4/cce/x86_64/lib/pkgconfig/../
-Wl,--as-needed,-lsci_cray_mpi,--no-as-needed
-Wl,--as-needed,-lsci_cray,--no-as-needed
-Wl,--as-needed,-lmpi_cray,--no-as-needed
-Wl,--as-needed,-ldsmml,--no-as-needed
-Wl,--as-needed,-lpgas-shmem,--no-as-needed -lpmi -ldl -lmpi_gtl_hsa
-lxpmem -lquadmath -lmodules -lfi -lcraymath -lf -lu -lcsup
ex3k.kokkos.cxx
-lquadmath -lstdc++ -ldl -o ex3k
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld:
undefined reference to `.omp_offloading.img_size.cray_amdgcn-amd-amdhsa'
undefined reference to `.omp_offloading.img_start.cray_amdgcn-amd-amdhsa'
undefined reference to `.omp_offloading.img_cache.cray_amdgcn-amd-amdhsa'
clang-12: error: linker command failed with exit code 1 (use -v to see
invocation)
gmake[4]: ***
[/gpfs/alpine/csc314/scratch/adams/petsc/lib/petsc/conf/test:26: ex3k]
Error 1
gmake[3]: [makefile:102: runex3k_kokkos] Error 2 (ignored)
1,25c1,4
< atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000
< Vec Object: Exact Solution 2 MPI processes
< type: mpikokkos
< Process [0]
< 0.
< 0.015625
< 0.125
< Process [1]
< 0.421875
< 1.
< Vec Object: Forcing function 2 MPI processes
< type: mpikokkos
< Process [0]
< 1e-72
< 1.50024
< 3.01563
< Process [1]
< 4.67798
< 7.
< 0 SNES Function norm 5.414682427127e+00
< 1 SNES Function norm 2.952582418265e-01
< 2 SNES Function norm 4.502293658739e-04
< 3 SNES Function norm 1.389665806646e-09
< Number of SNES iterations = 3
< Norm of error 1.49752e-10 Iterations 3
> slurmstepd: error: execve():
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials/./ex3k: No such
file or directory
file or directory
> srun: error: spock01: tasks 0-1: Exited with exit code 2
> srun: launch/slurm: _step_signal: Terminating StepId=272979.0
Possible problem with ex3k running with kokkos-kernels, diffs above
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex5f
ftn -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lamdhip64 -lhsa-runtime64
-fPIC -g -O0 -fPIC -g -O0
-I/sw/spock/spack-envs/views/rocm-4.1.0/include ex5f.F90
-lquadmath -lstdc++ -ldl -o ex5f
/opt/cray/pe/cce/11.0.4/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld:
warning: alignment 128 of symbol
`$host_init$$runtime_init_for_iso_c_binding$iso_c_binding_' in
/opt/cray/pe/cce/11.0.4/cce/x86_64/lib/libmodules.so is smaller than 256 in
/tmp/pe_30429/ex5f_1.o
warning: alignment 64 of symbol `$data_init$iso_c_binding_' in
Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
/gpfs/alpine/csc314/scratch/adams/petsc$ ll
On Fri, Jul 16, 2021 at 11:28 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Mark, I configured with Fortran binding enabled with main + MR !4175
> <https://gitlab.com/petsc/petsc/-/merge_requests/4175>
> '--with-mpiexec=srun',
> '--with-shared-libraries=1',
> '--with-cc=cc',
> '--with-cxx=CC',
> '--with-fc=ftn',
> '--with-fortran-bindings',
> '--with-hip',
> '--with-hipc=hipcc',
> '--with-debugging',
> '--CPPFLAGS=-I${ROCM_PATH}/include',
> '--CXXPPFLAGS=-I${ROCM_PATH}/include',
> '--CC_LINKER_FLAGS=-L${ROCM_PATH}/lib -lamdhip64 -lhsa-runtime64',
> '--CXX_LINKER_FLAGS=-L${ROCM_PATH}/lib -lamdhip64 -lhsa-runtime64',
> '--FC_LINKER_FLAGS=-L${ROCM_PATH}/lib -lamdhip64 -lhsa-runtime64',
> '--COPTFLAGS=-g -O0',
> '--CXXOPTFLAGS=-g -O0',
> '--FOPTFLAGS=-g -O0',
> '--download-kokkos',
> '--download-kokkos-kernels',
> '--download-kokkos-commit=3.4.01',
> '--download-kokkos-kernels-commit=3.4.01',
> '--with-kokkos-hip-arch=VEGA908',
> and 'make check' ran smoothly on a compute node
> $ make check
> Using PETSC_DIR=/ccs/home/jczhang/petsc and
> PETSC_ARCH=arch-spock-cray-kokkos-dbg
> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
> C/C++ example src/snes/tutorials/ex3k run successfully with kokkos-kernels
> --Junchao Zhang
> On Fri, Jul 16, 2021 at 6:04 PM Mark Adams <mfadams at lbl.gov> wrote:
>> And I find that this error, on non-Kokkos C tests, is fixed by turning
>> the fortran bindings off:
>> ld.lld: error:
>> /gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/lib/libpetsc.so:
>> ld.lld: error:
>> ld.lld: error:
>> On Fri, Jul 16, 2021 at 3:53 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Not complex. THis has some overlap with my problem w/o Kokkos.
>>> On Fri, Jul 16, 2021 at 12:54 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Do you use complex? post your configure.log.
>>>> --Junchao Zhang
>>>> On Fri, Jul 16, 2021 at 9:47 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> The simple Kokkos example is failing for me on Spock.
>>>>> Any ideas?
>>>>> Thanks,
>>>>> 10:44 main *=
>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ make
>>>>> PETSC_ARCH=arch-spock-opt-cray-kokkos ex3k
>>>>> MPICH_CXX="hipcc" OMPI_CXX="hipcc" CC
>>>>> -L/sw/spock/spack-envs/views/rocm-4.1.0/lib -lhsa-runtime64
>>>>> -fstack-protector -fvisibility=hidden -g -O2 -fPIC -Wall -Wwrite-strings
>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O3
>>>>> -std=c++14 -I/gpfs/alpine/csc314/scratch/adams/petsc/include
>>>>> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/include
>>>>> -I/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include
>>>>> -I/sw/spock/spack-envs/views/rocm-4.1.0/include ex3k.kokkos.cxx
>>>>> -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/lib
>>>>> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-spock-opt-cray-kokkos/lib
>>>>> -Wl,-rpath,/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/lib
>>>>> -L/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/lib
>>>>> In file included from ex3k.kokkos.cxx:3:
>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscdmda_kokkos.hpp:4:
>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscvec_kokkos.hpp:14:
>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscvec.h:9:
>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscsys.h:42:
>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscsystypes.h:255:
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/Kokkos_Complex.hpp:47:
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/Kokkos_Atomic.hpp:212:
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Atomic_Exchange.hpp:259:11:
>>>>> error: no member named 'lock_address_host_space' in namespace
>>>>> 'Kokkos::Impl::Kokkos::Impl'; did you mean simply 'lock_address_host_space'?
>>>>> while (!Impl::lock_address_host_space((void*)dest))
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/Kokkos_HostSpace.hpp:83:6:
>>>>> note: 'lock_address_host_space' declared here
>>>>> bool lock_address_host_space(void* ptr);
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Atomic_Exchange.hpp:261:3:
>>>>> error: no member named 'memory_fence' in namespace 'Kokkos::Impl::Kokkos';
>>>>> did you mean simply 'memory_fence'?
>>>>> Kokkos::memory_fence();
>>>>> memory_fence
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Memory_Fence.hpp:53:6:
>>>>> note: 'memory_fence' declared here
>>>>> void memory_fence() {
>>>>> /gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray-kokkos/include/impl/Kokkos_Atomic_Exchange.hpp:277:3:
>>>>> memory_fence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210717/5c78e7d0/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210717/5c78e7d0/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210717/5c78e7d0/attachment-0003.obj>
