[petsc-dev] "Search" does not work in the testing system?
Fande Kong
fdkong.jd at gmail.com
Wed Jan 27 17:21:19 CST 2021
Hi All,
I want to run one particular SNES test using the following command-line:
"make PETSC_DIR=/Users/kongf/projects/moose4/petsc
PETSC_ARCH=arch-darwin-c-debug -f gmakefile test
search='snes_tutorials-ex1'"
I got the following output:
"Using MAKEFLAGS: search=snes_tutorials-ex1% PETSC_ARCH=arch-darwin-c-debug
PETSC_DIR=/Users/kongf/projects/moose4/petsc"
But I did not see any useful test information.
Could you kindly let me know what I did wrong?
Fande
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210127/7930cb4d/attachment.html>
