[petsc-dev] obscure changes in TSGetStages_Theta
Zhang, Hong
hongzhang at anl.gov
Sun Jan 24 10:48:36 CST 2021
Some TS methods such as TSRK do have an array of vectors like this to store the stage values. But not all TS methods have it. I am fine adding the scratch for TSTheta and any other method missing it. A little drawback is that it is used only by TSGetStages and the TSStep implementation does not necessarily need it. So I like the idea to return a temporary array with GetStages and free it with RestoreStages when the TS method does not have an array for stages internally.
Hong
On Jan 24, 2021, at 1:08 AM, Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>> wrote:
You actually do not need a RestoreStages if you use a scratch
Vec stages[2];
in TS_theta, and pass it back with TSGetStages_Theta. I understand PETSc philosophy is that every Get should have a Restore method, but is this really necessary for TSGetStages?
Il giorno sab 23 gen 2021 alle ore 21:05 Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> ha scritto:
Done. Please check https://gitlab.com/petsc/petsc/-/merge_requests/3583
Sorry for any disturbance it caused. It was for the convenience of the adjoint implementation. The stages returned by TSGetStages_Theta currently do not reflect the true stages associated with these methods. The endpoint variant actually has two stages. This will be changed in a separate forthcoming MR, where TSRestoreStages() will be added and TSGetStages will return an array of vectors for the endpoint variant.
Hong
On Jan 21, 2021, at 4:16 AM, Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>> wrote:
Hong,
I do not understand why you changed the behavior of TSGetStages_Theta https://gitlab.com/petsc/petsc/-/merge_requests/3500/diffs#a582bbaec75f4ae14bbf97d1d0404073ca89ff09_1194_1209 with this MR https://gitlab.com/petsc/petsc/-/merge_requests/3500
Now, the non-endpoint variant does no longer use th->X as stage!
Please revert this change
Thanks
Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210124/f5e5e15c/attachment.html>
