[petsc-dev] Memory problem with OpenMP and Fieldsplit sub solvers
Mark Adams
mfadams at lbl.gov
Fri Jan 22 17:43:49 CST 2021
> No, you can't remove this because it initializes the device etc. You can't
> have all the threads trying to initialize the device.
OK, I am now running everything once w/o threads so it is fine for me, but
I added it back in.
Also, I see there are a lot of cached handles in aijcusparse.cu. If they
get set w/o threads (thread 0) and then get used later in OMP that could
be a problem. My code runs fine and it first runs without threads and then
runs with 10 threads/solves using cuSparse ILU solves. So it seems OK.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210122/1e30b044/attachment.html>
