[petsc-dev] Memory problem with OpenMP and Fieldsplit sub solvers
    Barry Smith
    bsmith at petsc.dev
    Thu Jan 21 20:30:13 CST 2021
> On Jan 21, 2021, at 5:37 PM, Mark Adams <mfadams at lbl.gov> wrote:
> This did not work. I verified that MPI_Init_thread is being called correctly and that MPI returns that it supports this highest level of thread safety.
> I am going to ask ORNL.
> And if I use:
> -fieldsplit_i1_ksp_norm_type none
> -fieldsplit_i1_ksp_max_it 300
> for all 9 "i" variables, I can run normal iterations on the 10th variable, in a 10 species problem, and it works perfectly with 10 threads.
> So it is definitely that VecNorm is not thread safe.
> And, I want to call SuperLU_dist, which uses threads, but I don't want SuperLU to start using threads. Is there a way to tell superLU that there are no threads but have PETSc use them?
  My interpretation and Satish's for many years is that SuperLU_DIST has to be built with and use OpenMP in order to work with CUDA.
  def formCMakeConfigureArgs(self):
    args = config.package.CMakePackage.formCMakeConfigureArgs(self)
    if self.openmp.found:
      self.usesopenmp = 'yes'
    else:
      args.append('-DCMAKE_DISABLE_FIND_PACKAGE_OpenMP=TRUE')
    if self.cuda.found:
      if not self.openmp.found:
        raise RuntimeError('SuperLU_DIST GPU code currently requires OpenMP. Use --with-openmp=1')
But this could be ok. You use OpenMP and then it uses OpenMP internally, each doing their own business (what could go wrong :-)).
Have you tried it?
  Barry
> Thanks,
> Mark
> On Thu, Jan 21, 2021 at 5:19 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> OK, the problem is probably:
> PetscMPIInt PETSC_MPI_THREAD_REQUIRED = MPI_THREAD_FUNNELED;
> There is an example that sets:
> PETSC_MPI_THREAD_REQUIRED = MPI_THREAD_MULTIPLE;
> This is what I need.
> On Thu, Jan 21, 2021 at 2:26 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> On Thu, Jan 21, 2021 at 2:11 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Thu, Jan 21, 2021 at 2:02 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> On Thu, Jan 21, 2021 at 1:44 PM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Thu, Jan 21, 2021 at 11:16 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> Yes, the problem is that each KSP solver is running in an OMP thread (So at this point it only works for SELF and its Landau so it is all I need). It looks like MPI reductions called with a comm_self are not thread safe (eg, the could say, this is one proc, thus, just copy send --> recv, but they don't)
> Instead of using SELF, how about Comm_dup() for each thread?
> OK, raw MPI_Comm_dup. I tried PetscCommDup. Let me this.
> Thanks,
> You would have to dup them all outside the OMP section, since it is not threadsafe. Then each thread uses one I think.
> Yea sure. I do it in SetUp.
> Well that worked to get different Comms, finally, I still get the same problem. The number of iterations differ wildly. This two species and two threads (13 SNES its that is not deterministic). Way below is one thread (8 its) and fairly uniform iteration counts.
> Maybe this MPI is just not thread safe at all. Let me look into it.
> Thanks anyway,
>    0 SNES Function norm 4.974994975313e-03
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x80017c60. Comms pc=0x67ad27c0 ksp=0x7ffe1600 newcomm=0x8014b6e0
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x7ffdabc0. Comms pc=0x67ad27c0 ksp=0x7fff70d0 newcomm=0x7ffe9980
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 282
>     1 SNES Function norm 1.836376279964e-05
>       Linear fieldsplit_e_ solve converged due to CONVERGED_ATOL iterations 19
>     2 SNES Function norm 3.059930074740e-07
>       Linear fieldsplit_e_ solve converged due to CONVERGED_ATOL iterations 15
>     3 SNES Function norm 4.744275398121e-08
>       Linear fieldsplit_e_ solve converged due to CONVERGED_ATOL iterations 4
>     4 SNES Function norm 4.014828563316e-08
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 456
>     5 SNES Function norm 5.670836337808e-09
>       Linear fieldsplit_e_ solve converged due to CONVERGED_ATOL iterations 2
>     6 SNES Function norm 2.410421401323e-09
>       Linear fieldsplit_e_ solve converged due to CONVERGED_ATOL iterations 18
>     7 SNES Function norm 6.533948191791e-10
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 458
>     8 SNES Function norm 1.008133815842e-10
>       Linear fieldsplit_e_ solve converged due to CONVERGED_ATOL iterations 9
>     9 SNES Function norm 1.690450876038e-11
>    10 SNES Function norm 1.336383986009e-11
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 463
>    11 SNES Function norm 1.873022410774e-12
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 113
>    12 SNES Function norm 1.801834606518e-13
>    13 SNES Function norm 1.004397317339e-13
>   Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 13
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x6e265010. Comms pc=0x56450340 ksp=0x6e2168d0 newcomm=0x6e265090
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x6e25bc40. Comms pc=0x56450340 ksp=0x6e22c1d0 newcomm=0x6e21e8f0
>     1 SNES Function norm 1.836376279963e-05
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 380
>     2 SNES Function norm 3.018499983019e-07
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 387
>     3 SNES Function norm 1.826353175637e-08
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 391
>     4 SNES Function norm 1.378600599548e-09
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 392
>     5 SNES Function norm 1.077289085611e-10
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 394
>     6 SNES Function norm 8.571891727748e-12
>       Linear fieldsplit_e_ solve converged due to CONVERGED_RTOL iterations 395
>     7 SNES Function norm 6.897647643450e-13
>     8 SNES Function norm 5.606434614114e-14
>   Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 8
>    Matt
>   Matt
> On Thu, Jan 21, 2021 at 10:46 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Thu, Jan 21, 2021 at 10:34 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> It looks like PETSc is just too clever for me. I am trying to get a different MPI_Comm into each block, but PETSc is thwarting me:
> It looks like you are using SELF. Is that what you want? Do you want a bunch of comms with the same group, but independent somehow? I am confused.
>    Matt
>   if (jac->use_openmp) {
>     ierr          = KSPCreate(MPI_COMM_SELF,&ilink->ksp);CHKERRQ(ierr);
> PetscPrintf(PETSC_COMM_SELF,"In PCFieldSplitSetFields_FieldSplit with -------------- link: %p. Comms %p %p\n",ilink,PetscObjectComm((PetscObject)pc),PetscObjectComm((PetscObject)ilink->ksp));
>   } else {
>     ierr          = KSPCreate(PetscObjectComm((PetscObject)pc),&ilink->ksp);CHKERRQ(ierr);
> produces:
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x7e9cb4f0. Comms 0x660c6ad0 0x660c6ad0
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x7e88f7d0. Comms 0x660c6ad0 0x660c6ad0
> How can I work around this?
> On Thu, Jan 21, 2021 at 7:41 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> On Wed, Jan 20, 2021 at 6:21 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> On Jan 20, 2021, at 3:09 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> So I put in a temporary hack to get the first Fieldsplit apply to NOT use OMP and it sort of works.
>> Preonly/lu is fine. GMRES calls vector creates/dups in every solve so that is a big problem.
>   It should definitely not be creating vectors "in every" solve. But it does do lazy allocation of needed restarted vectors which may make it look like it is creating "every" vectors in every solve.  You can use -ksp_gmres_preallocate to force it to create all the restart vectors up front at KSPSetUp().
> Well, I run the first solve w/o OMP and I see Vec dups in cuSparse Vecs in the 2nd solve.
>   Why is creating vectors "at every solve" a problem? It is not thread safe I guess?
> It dies when it looks at the options database, in a Free in the get-options method to be exact (see stacks).
> ======= Backtrace: =========
> /lib64/libc.so.6(cfree+0x4a0)[0x200021839be0]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(PetscFreeAlign+0x4c)[0x2000002a368c]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(PetscOptionsEnd_Private+0xf4)[0x2000002e53f0]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(+0x7c6c28)[0x2000008b6c28]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecCreate_SeqCUDA+0x11c)[0x20000052c510]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecSetType+0x670)[0x200000549664]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecCreateSeqCUDA+0x150)[0x20000052c0b0]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(+0x43c198)[0x20000052c198]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicate+0x44)[0x200000542168]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicateVecs_Default+0x148)[0x200000543820]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicateVecs+0x54)[0x2000005425f4]
> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(KSPCreateVecs+0x4b4)[0x2000016f0aec]
>> Richardson works except the convergence test gets confused, presumably because MPI reductions with PETSC_COMM_SELF is not threadsafe.
>> One fix for the norms might be to create each subdomain solver with a different communicator.
>    Yes you could do that. It might actually be the correct thing to do also, if you have multiple threads call MPI reductions on the same communicator that would be a problem. Each KSP should get a new MPI_Comm.
> OK. I will only do this.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210121/d6594fb0/attachment-0001.html>
