[petsc-dev] Memory problem with OpenMP and Fieldsplit sub solvers
    Matthew Knepley
    knepley at gmail.com
    Thu Jan 21 09:45:57 CST 2021
On Thu, Jan 21, 2021 at 10:34 AM Mark Adams <mfadams at lbl.gov> wrote:
> It looks like PETSc is just too clever for me. I am trying to get a
> different MPI_Comm into each block, but PETSc is thwarting me:
It looks like you are using SELF. Is that what you want? Do you want a
bunch of comms with the same group, but independent somehow? I am confused.
   Matt
>   if (jac->use_openmp) {
>     ierr          = KSPCreate(MPI_COMM_SELF,&ilink->ksp);CHKERRQ(ierr);
> PetscPrintf(PETSC_COMM_SELF,"In PCFieldSplitSetFields_FieldSplit with
> -------------- link: %p. Comms %p
> %p\n",ilink,PetscObjectComm((PetscObject)pc),PetscObjectComm((PetscObject)ilink->ksp));
>   } else {
>     ierr          =
> KSPCreate(PetscObjectComm((PetscObject)pc),&ilink->ksp);CHKERRQ(ierr);
> produces:
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x7e9cb4f0.
> Comms 0x660c6ad0 0x660c6ad0
> In PCFieldSplitSetFields_FieldSplit with -------------- link: 0x7e88f7d0.
> How can I work around this?
> On Thu, Jan 21, 2021 at 7:41 AM Mark Adams <mfadams at lbl.gov> wrote:
>> On Wed, Jan 20, 2021 at 6:21 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> On Jan 20, 2021, at 3:09 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> So I put in a temporary hack to get the first Fieldsplit apply to NOT
>>> use OMP and it sort of works.
>>> Preonly/lu is fine. GMRES calls vector creates/dups in every solve so
>>> that is a big problem.
>>>   It should definitely not be creating vectors "in every" solve. But it
>>> does do lazy allocation of needed restarted vectors which may make it look
>>> like it is creating "every" vectors in every solve.  You can
>>> use -ksp_gmres_preallocate to force it to create all the restart vectors up
>>> front at KSPSetUp().
>> Well, I run the first solve w/o OMP and I see Vec dups in cuSparse Vecs
>> in the 2nd solve.
>>>   Why is creating vectors "at every solve" a problem? It is not thread
>>> safe I guess?
>> It dies when it looks at the options database, in a Free in the
>> get-options method to be exact (see stacks).
>> ======= Backtrace: =========
>> /lib64/libc.so.6(cfree+0x4a0)[0x200021839be0]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(PetscFreeAlign+0x4c)[0x2000002a368c]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(PetscOptionsEnd_Private+0xf4)[0x2000002e53f0]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(+0x7c6c28)[0x2000008b6c28]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecCreate_SeqCUDA+0x11c)[0x20000052c510]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecSetType+0x670)[0x200000549664]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecCreateSeqCUDA+0x150)[0x20000052c0b0]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(+0x43c198)[0x20000052c198]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicate+0x44)[0x200000542168]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicateVecs_Default+0x148)[0x200000543820]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicateVecs+0x54)[0x2000005425f4]
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(KSPCreateVecs+0x4b4)[0x2000016f0aec]
>>> Richardson works except the convergence test gets confused, presumably
>>> because MPI reductions with PETSC_COMM_SELF is not threadsafe.
>>> One fix for the norms might be to create each subdomain solver with a
>>> different communicator.
>>>    Yes you could do that. It might actually be the correct thing to do
>>> also, if you have multiple threads call MPI reductions on the same
>>> communicator that would be a problem. Each KSP should get a new MPI_Comm.
>> OK. I will only do this.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210121/b61ba5fb/attachment-0001.html>
