[petsc-dev] Memory problem with OpenMP and Fieldsplit sub solvers
Mark Adams
mfadams at lbl.gov
Thu Jan 21 06:41:19 CST 2021
On Wed, Jan 20, 2021 at 6:21 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Jan 20, 2021, at 3:09 PM, Mark Adams <mfadams at lbl.gov> wrote:
> So I put in a temporary hack to get the first Fieldsplit apply to NOT use
> OMP and it sort of works.
> Preonly/lu is fine. GMRES calls vector creates/dups in every solve so that
> is a big problem.
> It should definitely not be creating vectors "in every" solve. But it
> does do lazy allocation of needed restarted vectors which may make it look
> like it is creating "every" vectors in every solve. You can
> use -ksp_gmres_preallocate to force it to create all the restart vectors up
> front at KSPSetUp().
Well, I run the first solve w/o OMP and I see Vec dups in cuSparse Vecs in
the 2nd solve.
> Why is creating vectors "at every solve" a problem? It is not thread
> safe I guess?
It dies when it looks at the options database, in a Free in the get-options
method to be exact (see stacks).
======= Backtrace: =========
/lib64/libc.so.6(cfree+0x4a0)[0x200021839be0]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(PetscFreeAlign+0x4c)[0x2000002a368c]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(PetscOptionsEnd_Private+0xf4)[0x2000002e53f0]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(+0x7c6c28)[0x2000008b6c28]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecCreate_SeqCUDA+0x11c)[0x20000052c510]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecSetType+0x670)[0x200000549664]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecCreateSeqCUDA+0x150)[0x20000052c0b0]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(+0x43c198)[0x20000052c198]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicate+0x44)[0x200000542168]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicateVecs_Default+0x148)[0x200000543820]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(VecDuplicateVecs+0x54)[0x2000005425f4]
/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-cuda-omp/lib/libpetsc.so.3.014(KSPCreateVecs+0x4b4)[0x2000016f0aec]
> Richardson works except the convergence test gets confused, presumably
> because MPI reductions with PETSC_COMM_SELF is not threadsafe.
> One fix for the norms might be to create each subdomain solver with a
> different communicator.
> Yes you could do that. It might actually be the correct thing to do
> also, if you have multiple threads call MPI reductions on the same
> communicator that would be a problem. Each KSP should get a new MPI_Comm.
OK. I will only do this.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210121/f9e3e8d5/attachment.html>
