[petsc-dev] Memory problem with OpenMP and Fieldsplit sub solvers
    Mark Adams
    mfadams at lbl.gov
    Mon Jan 18 19:04:15 CST 2021
Added this w/o luck:
#if defined(PETSC_HAVE_CUDA)
  ierr = PetscOptionsCheckCUDA(logView);CHKERRQ(ierr);
#if defined(PETSC_HAVE_THREADSAFETY)
  ierr = PetscCUPMInitializeCheck();CHKERRQ(ierr);
#endif
#endif
Do you think I should keep this in or take it out? Seems like a good idea
and when it all works we can see if we can make it lazy.
1)  Calling PetscOptions inside threads. I looked quickly at the code and
> it seems like it should be ok but perhaps not. This is one reason why
> having stuff like PetscOptionsBegin inside a low-level creation
> VecCreate_SeqCUDA_Private is normally not done in PETSc. Eventually this
> needs to be moved or reworked.
I will try this next. It is hard to see the stack here. I think I will put
it in ddt and put a breakpoint PetscOptionsEnd_Private. Other ideas welcome.
> 2) PetscCUDAInitializeCheck is not thread safe.If it is being call for the
> first timeby multiple threads there can be trouble. So edit init.c and under
> #endif
> #if defined(PETSC_HAVE_HIP)
>   ierr = PetscOptionsCheckHIP(logView);CHKERRQ(ierr);
> #endif
> put in
> #if defined thread safety
> #endif
> this will force the initialize to be done before any threads are used
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210118/f405ba4f/attachment.html>
