[petsc-dev] navigating gitlab
    Mark Adams
    mfadams at lbl.gov
    Mon Jan 18 07:22:52 CST 2021
BTW, how do you get that URL? I searched commits for it and did not find it.
Anyway, that bisect failed because I had an error in my verification test
(that has since been fixed). I now get this.
Barry: This commit seems to break my cuda Landau code. I'm guessing that I
need to change my configure script attached. Any ideas?
08:06 (7ba7a81...)|BISECTING /gpfs/alpine/csc314/scratch/adams/petsc$ git
bisect bad
7ba7a8179202d83658a309df68e2ebc2037284d4 is the first bad commit
commit 7ba7a8179202d83658a309df68e2ebc2037284d4
Author: Barry Smith <bsmith at mcs.anl.gov>
Date:   Thu Dec 31 00:28:23 2020 -0500
    The previous code passed options for the PETSc C, C preprocessor and
CXX compiler to the
    ccbin compiler used by nvcc even if it was a completely different
compiler and the arguments
    caused the compiler to error with unknown arguments.
    This has been an outstanding problem for years, this is the first crude
attempt to fix it by
    not passing the arguments unless the compiler is identical to the PETSc
compiler
    TODO: have a better check that the compilers are the same
    TODO: provide a systematic way for the user to provide the compiler
used by nvcc, perhaps default to the compiler used by PETSc?
    /spend 3.5h
    Thanks-to: Jose E. Roman <jroman at dsic.upv.es>
    Fix typo in list of c99 flags
    Add error message regarding Intel compilers breaking Gnu compilers when
c99 test fails with gcc.
    Eventually we may want more systematic checks of Intel compilers
    /spend 15m
:040000 040000 b4d44a220b09ceebb8020979eebf1b98da41e3ab
f24913d3614f54de6dfa49a789325f2c71c9983f M config
:100644 100644 9e53e76f9a4960cd943304f56bd1a8a10a3ae516
5309077a5a107b3f553b7875ad2a19c17741655b M gmakefile.test
:040000 040000 717c9a395a53442fe6917c0aa033b61d3427fbb2
aa365576e1efa7f29d8817c69d03e1983612caa1 M lib(base) 08:16  ~$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210118/c2abb7e5/attachment.html>
Type: text/x-python-script
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210118/c2abb7e5/attachment.bin>
