[petsc-dev] model for parallel ASM
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Mon Jan 11 10:52:14 CST 2021
Hmm I suppose this means Kokkos should accept a stream like we expect it to? According to this somewhat recent merged PR: https://github.com/kokkos/kokkos/pull/1919 <https://github.com/kokkos/kokkos/pull/1919> you can now make a "Kokkos::Cuda” object, and pass it as arg1 to range policies as an execution space. Here’s what I found on it (the cuda specific one is useless):
https://github.com/kokkos/kokkos/wiki/ExecutionSpaceConcept <https://github.com/kokkos/kokkos/wiki/ExecutionSpaceConcept>
https://github.com/kokkos/kokkos/wiki/Kokkos%3A%3AExecutionSpaceConcept <https://github.com/kokkos/kokkos/wiki/Kokkos::ExecutionSpaceConcept>
https://github.com/kokkos/kokkos/wiki/Kokkos%3A%3ACuda <https://github.com/kokkos/kokkos/wiki/Kokkos::Cuda> <—— cuda specific
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Jan 11, 2021, at 10:35, Mark Adams <mfadams at lbl.gov> wrote:
> Jacob, I'm not sure I understand this response. I could not find you on the Kokkos slack channel.
> Me: And My colleague in PETSc, Jacob Faibussowitsch, has talked to you about Kokkos taking a Cuda, Hip, etc., stream. This is something that would make it easier to deal with asynchronous GPU solvers in PETSc. We just wanted to check on this.
> Trott: Kokkos itself can do it for practically every operation
> Maybe you want to talk with him at some point, but we can worry about getting Cuda to work for now.
> On Sun, Jan 10, 2021 at 2:28 PM Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
> I would like as much as possible to pass the cuda and hip streams to Kokkos, since I can directly handle much of the annoyance with wrangling multiple streams and stream objects externally. Last I checked on this Kokkos was moving towards allowing association of streams to functions, but admittedly this was a while back.
> Best regards,
>> On Jan 10, 2021, at 13:10, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> On Sat, Jan 9, 2021 at 7:37 PM Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
>> It is a single object that holds a pointer to every stream implementation and toggleable type so it can be universally passed around. Currently has a cudaStream and a hipStream but this is easily extendable to any other stream implementation.
>> Do you have any thoughts on how this would work with Kokkos?
>> Would you want to feed Kokkos your Cuda/Hip, etc, stream or add a Kokkos backend to your object?
>> Junchao might be the person to ask. I would guess Kokkos View (vector) objects carry a stream because they block on a "deep_copy", that moves data to/from the GPU, and it is blocking.
>> Thanks,
>> Mark
>> Best regards,
>> Cell: +1 (312) 694-3391
>>> On Jan 9, 2021, at 18:19, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>> Is this stream object going to have Cuda, Kokkos, etc., implementations?
>>> On Sat, Jan 9, 2021 at 4:09 PM Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
>>> I’m currently working on an implementation of a general PetscStream object. Currently it only supports Vector ops and has a proof of concept KSPCG, but should be extensible to other objects when finished. Junchao is also indirectly working on pipeline support in his NVSHMEM MR. Take a look at either MR, it would be very useful to get your input, as tailoring either of these approaches for pipelined algorithms is key.
>>> Best regards,
>>>> On Jan 9, 2021, at 15:01, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>> I would like to put a non-overlapping ASM solve on the GPU. It's not clear that we have a model for this.
>>>> PCApply_ASM currently pipelines the scater with the subdomain solves. I think we would want to change this and do a 1) scatter begin loop, 2) scatter end and non-blocking solve loop, 3) solve-wait and scatter begging loop and 4) scatter end loop.
>>>> I'm not sure how to go about doing this.
>>>>  * Should we make a new PCApply_ASM_PARALLEL or dump this pipelining algorithm and rewrite PCApply_ASM?
>>>>  * Add a solver-wait method to KSP?
>>>> Thoughts?
>>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210111/8ed6f4c5/attachment.html>
