[petsc-dev] model for parallel ASM
Jacob Faibussowitsch
jacob.fai at gmail.com
Sat Jan 9 18:37:46 CST 2021
It is a single object that holds a pointer to every stream implementation and toggleable type so it can be universally passed around. Currently has a cudaStream and a hipStream but this is easily extendable to any other stream implementation.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: +1 (312) 694-3391
> On Jan 9, 2021, at 18:19, Mark Adams <mfadams at lbl.gov> wrote:
> Is this stream object going to have Cuda, Kokkos, etc., implementations?
>> On Sat, Jan 9, 2021 at 4:09 PM Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
>> I’m currently working on an implementation of a general PetscStream object. Currently it only supports Vector ops and has a proof of concept KSPCG, but should be extensible to other objects when finished. Junchao is also indirectly working on pipeline support in his NVSHMEM MR. Take a look at either MR, it would be very useful to get your input, as tailoring either of these approaches for pipelined algorithms is key.
>> Best regards,
>> Cell: (312) 694-3391
>>> On Jan 9, 2021, at 15:01, Mark Adams <mfadams at lbl.gov> wrote:
>>> I would like to put a non-overlapping ASM solve on the GPU. It's not clear that we have a model for this.
>>> PCApply_ASM currently pipelines the scater with the subdomain solves. I think we would want to change this and do a 1) scatter begin loop, 2) scatter end and non-blocking solve loop, 3) solve-wait and scatter begging loop and 4) scatter end loop.
>>> I'm not sure how to go about doing this.
>>> * Should we make a new PCApply_ASM_PARALLEL or dump this pipelining algorithm and rewrite PCApply_ASM?
>>> * Add a solver-wait method to KSP?
>>> Thoughts?
>>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210109/54d5d09e/attachment.html>
