[petsc-dev] builds of PETSc based packages should not get their own secret files
Satish Balay
balay at mcs.anl.gov
Tue Jan 5 08:28:27 CST 2021
Well we have to look at artifacts for configure.log. Why is this more of a burden for slepc or externalpackage logs?
Whatever you say for slepc log applies for configure.log. If its only CI issue - and you want all logs on STDOUT - then you can modify .gitlab-ci.yml. Perhaps:
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index 8f3d139235..f9cdd38abd 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -70,6 +70,7 @@ check-ci-settings:
after_script:
- date
- ccache --show-stats
+ - more arch-*/lib/petsc/conf/*.log |cat
artifacts:
reports:
junit: arch-*/tests/testresults.xml
Satish
On Mon, 4 Jan 2021, Barry Smith wrote:
> For packages that are built after PETSc configure (and or install is done) slepc, hpddm etc we've traditional saved the output in its own file stashed away somewhere.
> For the CI this is driving me nuts because when they fail the output is essentially "lost" and thus it is impossible to determine what has gone wrong.
> I have started to directly output in the same stream as the PETSc compiles to make debugging much easier. Generally the packages are relatively small and don't have a huge amount of output when compiling correctly. I did it for PETSc4py and SLEPc (slepc4py is a mystery yet how it get's hidden in slepc).
> Are there any large downsides to this plan?
> Barry
