[petsc-dev] [petsc-maint] Proposal to improve MatSetValuesBlocked
Frank Bramkamp bramkamp at nsc.liu.se
Mon Jan 4 06:48:21 CST 2021
Hi Mark,
then just let me know how you want to implement the blocking/ switch statements.
I can also insert it manually in the code. It probably makes sense to implement it for
row and column oriented BAIJ format, as well as for ADD_VALUES and insert values.
I took some days off around new year. This week I am back again more regularly.
Greetings,
Frank
