[petsc-dev] false positive test
Barry Smith
bsmith at petsc.dev
Sun Jan 3 11:10:41 CST 2021
There is MR to fix this problem. https://gitlab.com/petsc/petsc/-/merge_requests/3531 <https://gitlab.com/petsc/petsc/-/merge_requests/3531> I have added you as a reviewer. Other reviewers have been ignoring this crucial fix.
Barry
> On Jan 3, 2021, at 10:49 AM, Mark Adams <mfadams at lbl.gov> wrote:
> My test will fail if the gold output file is missing but otherwise it seems to always succeed. I just branched this from master.
> Any ideas?
> (base) 11:37 adams/landau-cleanup *= ~/Codes/petsc$ rm src/ts/utils/dmplexlandau/tutorials/output/ex2_0.out
> remove src/ts/utils/dmplexlandau/tutorials/output/ex2_0.out? y
> (base) 11:37 adams/landau-cleanup *= ~/Codes/petsc$ touch /Users/markadams/Codes/petsc/src/ts/utils/dmplexlandau/tutorials/output/ex2_0.out
> (base) 11:45 2 adams/landau-cleanup *= ~/Codes/petsc$ make -f gmakefile --debug test search='ts_utils_dmplexlandau_tutorials-ex2_0'
> GNU Make 3.81
> Copyright (C) 2006 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.
> There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> PARTICULAR PURPOSE.
> This program built for i386-apple-darwin11.3.0
> Reading makefiles...
> Updating goal targets....
> File `test' does not exist.
> File `report_tests' does not exist.
> File `starttime' does not exist.
> File `pre-clean' does not exist.
> Must remake target `pre-clean'.
> Using MAKEFLAGS: --debug=basic -- search=ts_utils_dmplexlandau_tutorials-ex2_0
> Successfully remade target file `pre-clean'.
> Must remake target `starttime'.
> Successfully remade target file `starttime'.
> File `ts_utils_dmplexlandau_tutorials-ex2_0' does not exist.
> File `arch-macosx-gnu-g/tests/counts/ts_utils_dmplexlandau_tutorials-ex2_0.counts' does not exist.
> Must remake target `arch-macosx-gnu-g/tests/counts/ts_utils_dmplexlandau_tutorials-ex2_0.counts'.
> TEST arch-macosx-gnu-g/tests/counts/ts_utils_dmplexlandau_tutorials-ex2_0.counts
> ok ts_utils_dmplexlandau_tutorials-ex2_0
> ok diff-ts_utils_dmplexlandau_tutorials-ex2_0
> Successfully remade target file `arch-macosx-gnu-g/tests/counts/ts_utils_dmplexlandau_tutorials-ex2_0.counts'.
> Must remake target `ts_utils_dmplexlandau_tutorials-ex2_0'.
> Successfully remade target file `ts_utils_dmplexlandau_tutorials-ex2_0'.
> Must remake target `report_tests'.
> # Summary
> # success 2/2 tests (100.0%)
> # failed 0/2 tests (0.0%)
> # todo 0/2 tests (0.0%)
> # skip 0/2 tests (0.0%)
> # Wall clock time for tests: 7 sec
> # Approximate CPU time (not incl. build time): 6.97 sec
> # Timing summary (actual test time / total CPU time):
> # ts_utils_dmplexlandau_tutorials-ex2_0: 6.45 sec / 6.97 sec
> Successfully remade target file `report_tests'.
> Must remake target `test'.
> Successfully remade target file `test'.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210103/eb85e4e0/attachment-0001.html>
