[petsc-dev] openmpi downloaded tarball broken ?
    Jed Brown
    jed at jedbrown.org
    Sun Jan  3 09:36:45 CST 2021
I don't understand.
$ wget https://download.open-mpi.org/release/open-mpi/v4.1/openmpi-4.1.0.tar.bz2
--2021-01-03 08:35:08--  https://download.open-mpi.org/release/open-mpi/v4.1/openmpi-4.1.0.tar.bz2
Resolving download.open-mpi.org (download.open-mpi.org)... 143.204.26.61, 143.204.26.76, 143.204.26.58, ...
Connecting to download.open-mpi.org (download.open-mpi.org)|143.204.26.61|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 10022171 (9.6M) [binary/octet-stream]
Saving to: ‘openmpi-4.1.0.tar.bz2’
openmpi-4.1.0.tar.bz2    100%[==================================>]   9.56M  46.6MB/s    in 0.2s
2021-01-03 08:35:08 (46.6 MB/s) - ‘openmpi-4.1.0.tar.bz2’ saved [10022171/10022171]
$ tar xf openmpi-4.1.0.tar.bz2
$ file openmpi-4.1.0/configure
openmpi-4.1.0/configure: POSIX shell script, ASCII text executable, with very long lines
Barry Smith <bsmith at petsc.dev> writes:
>   4.1 is also missing ./configure but documentation clearly states you install openMPI with ./configure !
>> On Jan 3, 2021, at 8:31 AM, Barry Smith <bsmith at petsc.dev> wrote:
>> $ wget https://download.open-mpi.org/release/open-mpi/v4.0/openmpi-4.0.3.tar.gz <https://download.open-mpi.org/release/open-mpi/v4.0/openmpi-4.0.3.tar.gz>
>> --2021-01-03 09:24:24--  https://download.open-mpi.org/release/open-mpi/v4.0/openmpi-4.0.3.tar.gz <https://download.open-mpi.org/release/open-mpi/v4.0/openmpi-4.0.3.tar.gz>
>> Resolving download.open-mpi.org <http://download.open-mpi.org/> (download.open-mpi.org <http://download.open-mpi.org/>)... 13.249.117.107, 13.249.117.91, 13.249.117.41, ...
>> Connecting to download.open-mpi.org <http://download.open-mpi.org/> (download.open-mpi.org <http://download.open-mpi.org/>)|13.249.117.107|:443... connected.
>> Length: 17418534 (17M) [binary/octet-stream]
>> Saving to: ‘openmpi-4.0.3.tar.gz’
>> 100%[=======================================================================>] 17,418,534  49.1MB/s   in 0.3s
>> 2021-01-03 09:24:26 (49.1 MB/s) - ‘openmpi-4.0.3.tar.gz’ saved [17418534/17418534]
>> ~ arch-fix-cuda-ccbin-wrong-arguments
>> $ cd petsc
>> ~/petsc (barry/2020-12-31/fix-cuda-ccbin-wrong-arguments>) arch-fix-cuda-ccbin-wrong-arguments
>> $ ./configure --download-openmpi=../openmpi-4.0.3.tar.gz  --with-cc=gcc --with-cxx=g++ --with-fc=gfortran  --with-cuda --download-slepc
>>              Configuring PETSc to compile on your system
>> =============================================================================================                          ***** WARNING: F77 (set to /nfs/apps/spacks/2020-10-22/opt/spack/linux-centos7-x86_64/gcc-7.3.0/gcc-7.3.0-l       use ./configure F77=$F77 if you really want to use that value ******                                      =============================================================================================                    =============================================================================================                          ***** WARNING: You have a version of GNU make older than 4.0. It will work,                                      but may not support all the parallel testing options. You can install the                                        latest GNU make with your package manager, such as brew or macports, or use                                      the --download-make option to get the latest GNU make *****                                                =============================================================================================                    =============================================================================================                          It appears you do not have valgrind installed on your system.                                                    We HIGHLY recommend you install it from www.valgrind.org <http://www.valgrind.org/>                                                         Or install valgrind-devel or equivalent using your package manager.                                              Then rerun ./configure        =============================================================================================                    =============================================================================================                          Running libtoolize on OPENMPI; this may take several minutes                                               =============================================================================================                    =============================================================================================                          Running autoreconf on OPENMPI; this may take several minutes                                               =============================================================================================        *******************************************************************************
>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
>> Error running libtoolize or autoreconf on OPENMPI: Could not execute "[['/usr/bin/autoreconf', '--force', '--install']]":
>> autoreconf: 'configure.ac' or 'configure.in' is required
