[petsc-dev] headsup: switch git default branch from 'master' to 'main'
Satish Balay
balay at mcs.anl.gov
Fri Feb 26 15:50:40 CST 2021
Update:
the switch (at gitlab.com/petsc/petsc) is done.
Please delete your local copy of 'master' branch and start using 'main' branch.
Satish
On Tue, 23 Feb 2021, Satish Balay via petsc-dev wrote:
> All,
> This is a heads-up, we are to switch the default branch in petsc git
> repo from 'master' to 'main'
> [Will plan to do the switch on friday the 26th]
> We've previously switched 'maint' branch to 'release' before 3.14
> release - and this change (to 'main') is the next step in this direction.
> Satish
