[petsc-dev] headsup: switch git default branch from 'master' to 'main'
Pierre Jolivet
pierre at joliv.et
Fri Feb 26 13:32:06 CST 2021
What about https://www.mcs.anl.gov/petsc/petsc-master <https://www.mcs.anl.gov/petsc/petsc-master> ? Will it be moved to https://www.mcs.anl.gov/petsc/petsc-main <https://www.mcs.anl.gov/petsc/petsc-main> or will only https://www.mcs.anl.gov/petsc/petsc-dev <https://www.mcs.anl.gov/petsc/petsc-dev> remain online?
Pierre
> On 26 Feb 2021, at 6:06 PM, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> I plan to delete 'master' immediately - so that folk don't assume it still exits and work with it [assuming its the latest, creating MRs against it etc..]
> Satish
> On Fri, 26 Feb 2021, Patrick Sanan wrote:
>> The answers to these were probably stated already, but the reminder might be useful to others, as well.
>> What will happen to "master" after today? Will it be deleted immediately or at some planned time? If not immediately deleted, will it be updated to match main?
>>> Am 23.02.2021 um 18:19 schrieb Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov>:
>>> All,
>>> This is a heads-up, we are to switch the default branch in petsc git
>>> repo from 'master' to 'main'
>>> [Will plan to do the switch on friday the 26th]
>>> We've previously switched 'maint' branch to 'release' before 3.14
>>> release - and this change (to 'main') is the next step in this direction.
>>> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210226/4547b7a4/attachment.html>
