[petsc-dev] Understanding Vecscatter with Kokkos Vecs
Stefano Zampini
stefano.zampini at gmail.com
Fri Feb 19 04:41:15 CST 2021
I dont understand the issue. I assume your vecscatter is not a throw away
object but you will reuse it many times. Once the setup is done, the
indices used internally by the implementation should be on gpu , or not?
Il Ven 19 Feb 2021, 13:33 Patrick Sanan <patrick.sanan at gmail.com> ha
scritto:
> Thanks! That helps a lot.
> I assume "no," but is ISCUDA simple to add?
> More on what I'm trying to do, in case I'm missing an obvious approach:
> I'm working on a demo code that uses an external library, based on Kokkos,
> as a solver - I create a Vec of type KOKKOS and populate it with the
> solution data from the library, by getting access to the raw Kokkos view
> with VecKokkosGetDeviceView() * .
> I then want to reorder that solution data into PETSc-native ordering (for
> a velocity-pressure DMStag), so I create a pair of ISs and a VecScatter to
> do that.
> The issue is that to create this scatter, I need to use information
> (essentially, an element-to-index map) from the external library's
> mesh-management object, which lives on the device. This doesn't work (when
> host != device), because of course the ISs live on the host and to create
> them I need to provide host arrays of indices.
> Am I stuck, for now, with sending the index information information from
> the device to the host, using it to create the IS, and then having
> essentially the same information go back to the device when I use the
> scatter?
> * As an aside, it looks like some of these Kokkos-related functions and
> types are missing man pages - if you have time to add them, even as stubs,
> that'd be great (if not let me know and I'll just try to formally do it, so
> that at least the existence of the functions in the API is reflected on the
> website).
> Am 18.02.2021 um 23:17 schrieb Junchao Zhang <junchao.zhang at gmail.com>:
> On Thu, Feb 18, 2021 at 4:04 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> On Thu, Feb 18, 2021 at 1:55 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> VecScatter (i.e., SF, the two are the same thing) setup (building
>>> various index lists, rank lists) is done on the CPU. is1, is2 must be host
>>> data.
>> Just out of curiosity, is1 and is2 can not be created on a GPU device in
>> the first place? That being said, it is technically impossible? Or we just
>> did not implement them yet?
> Simply because we do not have an ISCUDA class.
>> Fande,
>>> When the SF is used to communicate device data, indices are copied to
>>> the device..
>>> --Junchao Zhang
>>> On Thu, Feb 18, 2021 at 11:50 AM Patrick Sanan <patrick.sanan at gmail.com>
>>> wrote:
>>>> I'm trying to understand how VecScatters work with GPU-native Kokkos
>>>> Vecs.
>>>> Specifically, I'm interested in what will happen in code like in
>>>> src/vec/vec/tests/ex22.c,
>>>> ierr = VecScatterCreate(x,is1,y,is2,&ctx);CHKERRQ(ierr);
>>>> (from
>>>> https://gitlab.com/petsc/petsc/-/blob/master/src/vec/vec/tests/ex22.c#L44
>>>> Here, x and y can be set to type KOKKOS using -vec_type kokkos at the
>>>> command line. But is1 and is2 are (I think), always
>>>> CPU/host data. Assuming that the scatter itself can happen on the GPU,
>>>> the indices must make it to the device somehow - are they copied there when
>>>> the scatter is created? Is there a way to create the scatter using indices
>>>> already on the GPU (Maybe using SF more directly)?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210219/7315a2c9/attachment.html>
