[petsc-dev] TSSetConvergedReason(ts,TS_CONVERGED_USER);
Matthew Knepley
knepley at gmail.com
Thu Feb 18 06:25:46 CST 2021
Stefano is right. Changes in convergence should probably go in TSPostStep.
Matt
On Thu, Feb 18, 2021 at 7:22 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Mark
> monitors are not supposed to change the TS. You can think at monitors
> being 'const' methods of the TS. Also, TSMonitor is called at the beginning
> of each step , see here
> https://gitlab.com/petsc/petsc/-/blob/master/src/ts/interface/ts.c#L4169
> Il giorno gio 18 feb 2021 alle ore 15:16 Mark Adams <mfadams at lbl.gov> ha
> scritto:
>> does not seem to stop the iteration in a user monitor function. I have
>> verified that it works from a post step method. Is this intentional?
>> Mark
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210218/d7965cdb/attachment.html>
