[petsc-dev] error with flags PETSc uses for determining AVX
Barry Smith bsmith at petsc.dev
Sun Feb 14 11:56:53 CST 2021
> On Feb 14, 2021, at 10:09 AM, Pierre Jolivet <pierre at joliv.et> wrote:
>> On 14 Feb 2021, at 4:52 PM, Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
> This is a reasonable message to print on the screen, but I don’t think this is a reasonable flag to impose by default.
> You are basically asking all package managers to add a new flag (-march=generic) which was previously not needed.
  This is a tough constraint, package managers should not have to do anything to get portability but users get great performance without needing to be sophisticated. Seems to put the burden on the unsophisticated folks (all users) and not on the sophisticated folks (packages).
  What about a configure option --with-package-system which packagers would add that insures portability and packager rules and it not set configure is free to make better optimization choices? Or is there some environmental variable etc that configure can check that we know is always around when package building?
  Barry
> I’m crossing my fingers Jed has a clever way of "making portable binaries that run-time detected when to use newer instructions where it matters”, because -march=native by default is just not practical when deploying software.
> Thanks,
> Pierre
>> We should also inform users that tuning -march options may enable vectorization instructions such as SSE(3 and above) and AVX but generate nonportable binaries.
>> If we add -march=native to the configure test, we will need to run executables to make sure the specified instruction sets are supported by the CPU where the code is running. For PETSc, the executables should cover all the intrinsics we use in the code ideally; otherwise, users will get run-time errors when there is a mismatch in vectorization instructions between compiler support and CPU support.
>> Hong
>>> None of the examples in config/examples actually use -march=native, and this is a very common thing to do that, as you point out, isn't obvious until you know you have to do it, so it seems to be worth the screen space.
>>>>  Barry
>>>>> Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> writes:
>>>>>> Shouldn't configure be setting something appropriate for this automatically? This is nuts, it means when users do a ./configure make unless they pass weird arguments they sure as heck don't know about to the compiler they won't get any of the glory that they expect and that has been in almost all Intel systems forever.
>>>>>> Barry
>>>>>> I run ./configure --with-debugging=0 and I get none of the stuff added by Intel for 15+ years?
>>>>>>> On Feb 13, 2021, at 11:26 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>>>>>> Use -march=native or similar. The default target is basic x86_64, which has only SSE2.
>>>>>>>> PETSc source has code like defined(__AVX2__) in the source but it does not seem to be able to find any of these macros (icc or gcc) on the petsc-02 system
>>>>>>>> Are these macros supposed to be defined? How does on get them to be defined? Why are they not define? What am I doing wrong?
>>>>>>>> Keep reading
>>>>>>>> $ lscpu
>>>>>>>> Architecture:        x86_64
>>>>>>>> CPU op-mode(s):      32-bit, 64-bit
>>>>>>>> Byte Order:          Little Endian
>>>>>>>> CPU(s):              64
>>>>>>>> On-line CPU(s) list: 0-63
>>>>>>>> Thread(s) per core:  2
>>>>>>>> Core(s) per socket:  16
>>>>>>>> Socket(s):           2
>>>>>>>> NUMA node(s):        2
>>>>>>>> Vendor ID:           GenuineIntel
>>>>>>>> CPU family:          6
>>>>>>>> Model:               85
>>>>>>>> Model name:          Intel(R) Xeon(R) Gold 5218 CPU @ 2.30GHz
>>>>>>>> Stepping:            7
>>>>>>>> CPU MHz:             1000.603
>>>>>>>> CPU max MHz:         2301.0000
>>>>>>>> CPU min MHz:         1000.0000
>>>>>>>> BogoMIPS:            4600.00
>>>>>>>> Virtualization:      VT-x
>>>>>>>> L1d cache:           32K
>>>>>>>> L1i cache:           32K
>>>>>>>> L2 cache:            1024K
>>>>>>>> L3 cache:            22528K
>>>>>>>> NUMA node0 CPU(s):   0-15,32-47
>>>>>>>> NUMA node1 CPU(s):   16-31,48-63
>>>>>>>> Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb cat_l3 cdp_l3 invpcid_single intel_ppin ssbd mba ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid cqm mpx rdt_a avx512f avx512dq rdseed adx smap clflushopt clwb intel_pt avx512cd avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local dtherm ida arat pln pts pku ospke avx512_vnni md_clear flush_l1d arch_capabilities
>>>>>>>> Test program
>>>>>>>> #if defined(__FMA__)
>>>>>>>> #error FMA
>>>>>>>> #endif
>>>>>>>> #if defined(__AVX512F__)
>>>>>>>> #error AVX512F
>>>>>>>> #endif
>>>>>>>> #if defined(__AVX2__)
>>>>>>>> #error AVX2
>>>>>>>> #endif
>>>>>>>> icc mytest.c
>>>>>>>> /usr/lib/gcc/x86_64-linux-gnu/7/../../../x86_64-linux-gnu/Scrt1.o: In function `_start':
>>>>>>>> (.text+0x20): undefined reference to `main'
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210214/39ce28d2/attachment-0001.html>
