[petsc-dev] Questions around benchmarking and data loading with PETSc
Matthew Knepley
knepley at gmail.com
Sat Dec 11 19:30:41 CST 2021
On Sat, Dec 11, 2021 at 8:25 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> I expected TACO was better since its website says "It uses novel compiler
> techniques to get performance competitive with hand-optimized kernels"
I would not. SpMV is just a bandwidth test. There is almost nothing else
going on.
As Barry says, if you run a stencil matrix, I don't think you could
outperform the naive PETSc by more than 15%. That is what
the thousands of SpMV papers also show. If you use one of these small-world
graph matrices, there can be larger gaps.
Matt
> --Junchao Zhang
> On Sat, Dec 11, 2021 at 5:56 PM Rohan Yadav <rohany at alumni.cmu.edu> wrote:
>> Sorry, what’s surprising about this? 40 mpi ranks on a single node should
>> be similar performance as 40 threads. Both petsc and taco are doing a
>> row-based parallelism strategy so it should line up.
>> Rohan Yadav
>> On Dec 11, 2021, at 6:44 PM, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>> On Sat, Dec 11, 2021 at 5:09 PM Rohan Yadav <rohany at alumni.cmu.edu>
>> wrote:
>>> > Did you mean with 1 rank or 40 mpi ranks, petsc's performance is close
>>> to 1 thread or 40 threads of TACO?
>>> The 1 rank time is the same as taco 1 thread, and the 40 rank time is
>>> the same as taco 40 threads.
>> Interesting. TACO is supposed to give an optimized SpMV.
>>> Rohan
>>> On Sat, Dec 11, 2021 at 6:07 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> On Sat, Dec 11, 2021, 4:22 PM Rohan Yadav <rohany at alumni.cmu.edu>
>>>> wrote:
>>>>> Thanks all for the help, the main problem was the lack of optimization
>>>>> flags in the default build provided by my system. A manual installation
>>>>> with optimization flags delivers performance equal to the single node
>>>>> benchmark I discussed before.
>>>>> Rohan
>>>>> On Sat, Dec 11, 2021 at 4:04 PM Rohan Yadav <rohany at alumni.cmu.edu>
>>>>> wrote:
>>>>>> > The matrix market file in text format is not good for load. One
>>>>>> should convert it to petsc binary format (only once), and use the new
>>>>>> binary file afterwards.
>>>>>> Yes, I understand this. The point I'm trying to make is that using
>>>>>> PETSc to even perform the initial conversion from matrix market to the
>>>>>> binary format was prohibitively slow using `MatSetValues`.
>>>>>> > I meant 10 lines of code without any function call, which can be
>>>>>> thought of as a textbook implementation of SpMV. As a baseline, one can
>>>>>> apply optimizations to it. PETSc does not do sophisticated sparse matrix
>>>>>> optimization itself, instead it relies on third-party libraries. I
>>>>>> remember we had OSKI from Berkeley for CPU, and on GPU we use cuSparse,
>>>>>> hipSparse, MKLSparse or Kokkos-Kernels. If TACO is good, then petsc can add
>>>>>> an interface to it too.
>>>>>> Yes, this is what I expected. Given that PETSc uses high-performance
>>>>>> kernels for for the sparse matrix operation itself, I was surprised to see
>>>>>> that the single-thread performance of PETSc to be closer to a baseline like
>>>>>> TACO. This performance will likely improve when I compile PETSc with
>>>>>> optimization flags.
>>>>>> Rohan
>>>>>> On Sat, Dec 11, 2021 at 1:04 PM Junchao Zhang <
>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>> On Sat, Dec 11, 2021 at 10:28 AM Rohan Yadav <rohany at alumni.cmu.edu>
>>>>>>> wrote:
>>>>>>>> Hi Junchao,
>>>>>>>> Thanks for the response!
>>>>>>>> > You can use https://petsc.org/main/src/mat/tests/ex72.c.html to
>>>>>>>> convert a Matrix Market file into a petsc binary file. And then in
>>>>>>>> your test, load the binary matrix, following this example
>>>>>>>> https://petsc.org/main/src/mat/tutorials/ex1.c.html
>>>>>>>> I tried an example like this, but the performance was too slow (it
>>>>>>>> would process ~2000-3000 calls to `SetValue` a second), which is not
>>>>>>>> reasonable for loading matrices with millions of non-zeros.
>>>>>>>> > I don't know what "No Races" means, but it seems you'd better
>>>>>>>> also verify the result of SpMV.
>>>>>>>> This is a correct implementation of SpMV. The no-races is fine as
>>>>>>>> it parallelizes over the rows of the matrix, and thus does not need
>>>>>>>> synchronization between writes to the output.
>>>>>>>> > You can think petsc's default CSR spmv is the baseline, which
>>>>>>>> is done in ~10 lines of code.
>>>>>>>> I'm sorry, but I don't think that is a reasonable statement w.r.t
>>>>>>>> to the lines of code making it a good baseline. The TACO compiler also can
>>>>>>>> be used in 10 lines of code to compute an SpMV, or any other
>>>>>>>> state-of-the-art library could wrap an SpMV implementation behind a single
>>>>>>>> function call. I'm wondering if this performance I'm seeing using PETSc is
>>>>>>>> expected, or if I've misconfigured or am misusing the system in some way.
>>>>>>>> Rohan
>>>>>>>> On Fri, Dec 10, 2021 at 11:39 PM Junchao Zhang <
>>>>>>>>> On Fri, Dec 10, 2021 at 8:05 PM Rohan Yadav <rohany at alumni.cmu.edu>
>>>>>>>>> wrote:
>>>>>>>>>> Hi, I’m Rohan, a student working on compilation techniques for
>>>>>>>>>> distributed tensor computations. I’m looking at using PETSc as a baseline
>>>>>>>>>> for experiments I’m running, and want to understand if I’m using PETSc as
>>>>>>>>>> it was intended to achieve high performance, and if the performance I’m
>>>>>>>>>> seeing is expected. Currently, I’m just looking at SpMV operations.
>>>>>>>>>> My experiments are run on the Lassen Supercomputer (
>>>>>>>>>> https://hpc.llnl.gov/hardware/platforms/lassen). The system has
>>>>>>>>>> 40 CPUs, 4 V100s and an Infiniband interconnect. A visualization of the
>>>>>>>>>> architecture is here:
>>>>>>>>>> https://hpc.llnl.gov/sites/default/files/power9-AC922systemDiagram2_1.png
>>>>>>>>>> As of now, I’m trying to understand the single-node performance
>>>>>>>>>> of PETSc, as the scaling performance onto multiple nodes appears to be as I
>>>>>>>>>> expect. I’m using the arabic-2005 sparse matrix from the SuiteSparse matrix
>>>>>>>>>> collection, detailed here:
>>>>>>>>>> https://sparse.tamu.edu/LAW/arabic-2005. As a trusted baseline,
>>>>>>>>>> I am comparing against SpMV code generated by the TACO compiler (
>>>>>>>>>> http://tensor-compiler.org/codegen.html?expr=y(i)%20=%20A(i,j)%20*%20x(j)&format=y:d:0;A:ds:0,1;x:d:0&sched=split:i:i0:i1:32;reorder:i0:i1:j;parallelize:i0:CPU%20Thread:No%20Races)
>>>>>>>>> I don't know what "No Races" means, but it seems you'd better also
>>>>>>>>>> My experiments find that PETSc is roughly 4 times slower on a
>>>>>>>>>> single thread and node than the kernel generated by TACO:
>>>>>>>>>> PETSc: 1 Thread: 5694.72 ms, 1 Node 40 threads: 262.6 ms.
>>>>>>>>>> TACO: 1 Thread: 1341 ms, 1 Node 40 threads: 86 ms.
>>>>>>>>> You can think petsc's default CSR spmv is the baseline, which is
>>>>>>>>>> My code using PETSc is here:
>>>>>>>>>> https://github.com/rohany/taco/blob/9e0e30b16bfba5319b15b2d1392f35376952f838/petsc/benchmark.cpp#L38
>>>>>>>>>> Runs from 1 thread and 1 node with -log_view are attached to the
>>>>>>>>>> email. The command lines for each were as follows:
>>>>>>>>>> 1 node 1 thread: `jsrun -n 1 -c 1 -r 1 -b rs ./bin/benchmark -n
>>>>>>>>>> 20 -warmup 10 -matrix $TENSOR_DIR/arabic-2005.petsc -log_view`
>>>>>>>>>> 1 node 40 threads: `jsrun -n 40 -c 1 -r 40 -b rs ./bin/benchmark
>>>>>>>>>> -n 20 -warmup 10 -matrix $TENSOR_DIR/arabic-2005.petsc -log_view`
>>>>>>>>>> In addition to these benchmarking concerns, I wanted to share my
>>>>>>>>>> experiences trying to load data from Matrix Market files into PETSc, which
>>>>>>>>>> ended up 1being much more difficult than I anticipated. Essentially, trying
>>>>>>>>>> to iterate through the Matrix Market files and using `write` to insert
>>>>>>>>>> entries into a `Mat` was extremely slow. In order to get reasonable
>>>>>>>>>> performance, I had to use an external utility to basically construct a CSR
>>>>>>>>>> matrix, and then pass the arrays from the CSR Matrix into
>>>>>>>>>> `MatCreateSeqAIJWithArrays`. I couldn’t find any more guidance on PETSc
>>>>>>>>>> forums or Google, so I wanted to know if this was the right way to go.
>>>>>>>>>> Thanks,
>>>>>>>>>> Rohan Yadav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211211/1377a65c/attachment.html>
