[petsc-dev] segv in fortran
    Mark Adams
    mfadams at lbl.gov
    Fri Dec 10 15:54:20 CST 2021
Not setting "filename" seems to have fixed this (MR)
On Fri, Dec 10, 2021 at 2:59 PM Mark Adams <mfadams at lbl.gov> wrote:
> whoops ...
> This code is here.
>            if (filename .ne. PETSC_NULL_CHARACTER) then
>               filename = trim(filename)
>            endif
> Maybe filename should not be used as the destination?
> On Fri, Dec 10, 2021 at 2:56 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I am getting a segv when calling a Fortran subrouting from C, where
>> PetscInit is called in the Fortran code only with a string for the rc file.
>> We have seen this on multiple platforms.
>> I got it in totalview and the segv was on the trim(filename) method
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211210/0f5663e6/attachment.html>
