[petsc-dev] spock
    Mark Adams
    mfadams at lbl.gov
    Fri Dec 10 10:15:48 CST 2021
I was able to run a parallel test manually.
Do you have any thoughts on Kokkos?
'--with-kokkos-hip-arch=VEGA908',
On Fri, Dec 10, 2021 at 11:08 AM Mark Adams <mfadams at lbl.gov> wrote:
> It seems to be hanging on the 2 processor test.
> I'll try running jobs manually.
> On Fri, Dec 10, 2021 at 9:34 AM Satish Balay <balay at mcs.anl.gov> wrote:
>> Merged now. And the following now works [for me].
>>  1025  git fetch -p
>>  1026  git checkout origin/main
>>  1027  ./config/examples/arch-olcf-spock.py && make
>>  1028  MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0 MPICH_GPU_SUPPORT_ENABLED=1
>> MPICH_SMP_SINGLE_COPY_MODE=CMA make check
>> Satish
>> On Fri, 10 Dec 2021, Satish Balay via petsc-dev wrote:
>> > Works for me [per instructions in balay/update-spock,
>> config/examples/arch-olcf-spock.py] with main - without these additional
>> options
>> > I'll go ahead and merge in balay/update-spock
>> > Satish
>> >  1009  git fetch -p
>> >  1015  module load emacs
>> >  1016  module load rocm/4.3.0
>> >  1018  git reset --hard
>> >  1019  git checkout origin/main
>> >  1020  git merge origin/balay/update-spock
>> >  1021  ./config/examples/arch-olcf-spock.py && make
>> > [balay at login2.spock petsc]$ MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0
>> MPICH_GPU_SUPPORT_ENABLED=1 MPICH_SMP_SINGLE_COPY_MODE=CMA make check
>> > Running check examples to verify correct installation
>> > Using PETSC_DIR=/autofs/nccs-svm1_home1/balay/petsc and
>> PETSC_ARCH=arch-olcf-spock
>> > C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>> process
>> > C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>> processes
>> > C/C++ example src/snes/tutorials/ex3k run successfully with
>> kokkos-kernels
>> > *******************Error detected during compile or
>> link!*******************
>> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> > /ccs/home/balay/petsc/src/snes/tutorials ex5f
>> > ftn -fPIC   -fPIC    -I/autofs/nccs-svm1_home1/balay/petsc/include
>> -I/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/include
>> -I/opt/rocm-4.3.0/include     ex5f.F90
>> -Wl,-rpath,/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/lib
>> -L/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/lib
>> -Wl,-rpath,/opt/rocm-4.3.0/lib -L/opt/rocm-4.3.0/lib
>> -Wl,-rpath,/opt/cray/pe/mpich/8.1.10/gtl/lib
>> -L/opt/cray/pe/mpich/8.1.10/gtl/lib
>> -Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib64
>> -L/opt/cray/pe/gcc/8.1.0/snos/lib64 -Wl,-rpath,/opt/cray/pe/libsci/
>> 21.08.1.2/CRAY/9.0/x86_64/lib -L/opt/cray/pe/libsci/
>> -Wl,-rpath,/opt/cray/pe/mpich/8.1.10/ofi/cray/10.0/lib
>> -L/opt/cray/pe/mpich/8.1.10/ofi/cray/10.0/lib
>> -Wl,-rpath,/opt/cray/pe/dsmml/0.2.2/dsmml/lib
>> -L/opt/cray/pe/dsmml/0.2.2/dsmml/lib -Wl,-rpath,/opt/cray/pe/pmi/6.0.14/lib
>> -L/opt/cray/pe/pmi/6
>> >  .0.14/li
>> >  b -Wl,-rpath,/opt/cray/pe/cce/12.0.3/cce/x86_64/lib
>> -L/opt/cray/pe/cce/12.0.3/cce/x86_64/lib
>> -Wl,-rpath,/opt/cray/xpmem/2.2.40-2.1_2.44__g3cf3325.shasta/lib64
>> -L/opt/cray/xpmem/2.2.40-2.1_2.44__g3cf3325.shasta/lib64
>> -Wl,-rpath,/opt/cray/pe/cce/12.0.3/cce-clang/x86_64/lib/clang/12.0.0/lib/linux
>> -L/opt/cray/pe/cce/12.0.3/cce-clang/x86_64/lib/clang/12.0.0/lib/linux
>> -Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
>> -L/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
>> -Wl,-rpath,/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-unknown-linux-gnu/lib
>> -L/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-unknown-linux-gnu/lib
>> -lpetsc -lmagma -lkokkoskernels -lkokkoscontainers -lkokkoscore -lhipsparse
>> -lhipblas -lrocsparse -lrocsolver -lrocblas -lrocrand -lamdhip64 -lstdc++
>> -ldl -lmpi_gtl_hsa -lmpifort_cray -lmpi_cray -ldsmml -lpmi -lpmi2 -lxpmem
>> -lpgas-shmem -lquadmath -lmodules -lfi -lcraymath -lf -lu -lcsup -lgfortran
>> -lpthread -lgcc_eh -lm -lclang_rt.craypg
>> >  o-x86_64
>> >   -lclang_rt.builtins-x86_64 -lquadmath -lstdc++ -ldl -lmpi_gtl_hsa -o
>> ex5f/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld:
>> warning: alignment 128 of symbol
>> `$host_init$$runtime_init_for_iso_c_binding$iso_c_binding_' in
>> /opt/cray/pe/cce/12.0.3/cce/x86_64/lib/libmodules.so is smaller than 256 in
>> /tmp/pe_202599/ex5f_1.o
>> warning: alignment 64 of symbol `$data_init$iso_c_binding_' in
>> > Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>> process
>> > Completed test examples
>> > On Fri, 10 Dec 2021, Mark Adams wrote:
>> > > FWIW,  here is my current status.
>> > > 08:08 main= spock:/gpfs/alpine/csc314/scratch/adams/petsc$ make
>> > > PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
>> > > PETSC_ARCH=arch-olcf-spock check
>> > > Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
>> > > Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI
>> process
>> > > lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>> > >     0 KSP Residual norm 0.0406612
>> > >     1 KSP Residual norm 0.036923
>> > >     2 KSP Residual norm 0.0191849
>> > >     3 KSP Residual norm 0.00201589
>> > >     4 KSP Residual norm 0.000376045
>> > >     5 KSP Residual norm 4.2974e-05
>> > >     6 KSP Residual norm 5.96585e-06
>> > >     7 KSP Residual norm 4.5398e-07
>> > >     8 KSP Residual norm 6.30474e-08
>> > >     9 KSP Residual norm 5.55518e-09
>> > >    10 KSP Residual norm 6.180e-10
>> > >    11 KSP Residual norm 6.211e-11
>> > >   Linear solve converged due to CONVERGED_RTOL iterations 11
>> > >     0 KSP Residual norm 3.32845e-06
>> > >     1 KSP Residual norm 9.0003e-07
>> > >     2 KSP Residual norm 1.32594e-07
>> > >     3 KSP Residual norm 1.49857e-08
>> > >     4 KSP Residual norm 1.31887e-09
>> > >     5 KSP Residual norm 2.105e-10
>> > >     6 KSP Residual norm 2.827e-11
>> > >     7 KSP Residual norm < 1.e-11
>> > >     8 KSP Residual norm < 1.e-11
>> > >     9 KSP Residual norm < 1.e-11
>> > >    10 KSP Residual norm < 1.e-11
>> > >   Linear solve converged due to CONVERGED_RTOL iterations 10
>> > > Number of SNES iterations = 2
>> > > Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI
>> processes
>> > >     1 KSP Residual norm 0.0281101
>> > >     2 KSP Residual norm 0.00773873
>> > >     3 KSP Residual norm 0.00165731
>> > >     4 KSP Residual norm 0.000395614
>> > >     5 KSP Residual norm 8.67655e-05
>> > >     6 KSP Residual norm 1.69495e-05
>> > >     7 KSP Residual norm 3.70051e-06
>> > >     8 KSP Residual norm 5.97067e-07
>> > >     9 KSP Residual norm 1.02242e-07
>> > >    10 KSP Residual norm 1.75727e-08
>> > >    11 KSP Residual norm 3.84826e-09
>> > >    12 KSP Residual norm 6.414e-10
>> > >    13 KSP Residual norm 1.380e-10
>> > >   Linear solve converged due to CONVERGED_RTOL iterations 13
>> > >     0 KSP Residual norm 3.32846e-06
>> > >     1 KSP Residual norm 8.99139e-07
>> > >     2 KSP Residual norm 1.72893e-07
>> > >     3 KSP Residual norm 3.733e-08
>> > >     4 KSP Residual norm 6.67427e-09
>> > >     5 KSP Residual norm 1.22785e-09
>> > >     6 KSP Residual norm 2.551e-10
>> > >     7 KSP Residual norm 5.458e-11
>> > >     8 KSP Residual norm 1.050e-11
>> > >    11 KSP Residual norm < 1.e-11
>> > >    12 KSP Residual norm < 1.e-11
>> > >   Linear solve converged due to CONVERGED_RTOL iterations 12
>> > > 3,5c3,14
>> > > <   1 SNES Function norm 4.12227e-06
>> > > <   2 SNES Function norm 6.098e-11
>> > > < Number of SNES iterations = 2
>> > > >     1 KSP Residual norm 0.21263
>> > > >     2 KSP Residual norm 1.09192
>> > > >     3 KSP Residual norm 6.9087
>> > > >     4 KSP Residual norm 23.4292
>> > > >     5 KSP Residual norm 57.7558
>> > > >     6 KSP Residual norm 118.076
>> > > >     7 KSP Residual norm 213.527
>> > > >     8 KSP Residual norm 354.101
>> > > >     9 KSP Residual norm 550.58
>> > > >   Linear solve did not converge due to DIVERGED_DTOL iterations 9
>> > > > Number of SNES iterations = 0
>> > > /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
>> > > Possible problem with ex19 running with hypre, diffs above
>> > > gmake[3]: [makefile:115: runex3k_kokkos] Error 134 (ignored)
>> > > 21,25c21,26
>> > > <   1 SNES Function norm 2.952582418265e-01
>> > > <   2 SNES Function norm 4.502293658739e-04
>> > > <   3 SNES Function norm 1.389665806646e-09
>> > > < Number of SNES iterations = 3
>> > > < Norm of error 1.49752e-10 Iterations 3
>> > > > Memory access fault by GPU node-4 (Agent handle: 0xb08c90) on
>> address
>> > > 0xe17000. Reason: Page not present or supervisor privilege.
>> > > > Memory access fault by GPU node-5 (Agent handle: 0xb0d3c0) on
>> address
>> > > 0xe11000. Reason: Page not present or supervisor privilege.
>> > > > srun: error: spock25: task 0: Aborted
>> > > > srun: launch/slurm: _step_signal: Terminating StepId=304034.3
>> > > > slurmstepd: error: *** STEP 304034.3 ON spock25 CANCELLED AT
>> > > 2021-12-10T08:08:40 ***
>> > > > srun: error: spock25: task 1: Aborted (core dumped)
>> > > Possible problem with ex3k running with kokkos-kernels, diffs above
>> > > /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex5f
>> > > ftn -fPIC   -fPIC    -I/gpfs/alpine/csc314/scratch/adams/petsc/include
>> > > -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-spock/include
>> -I/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray/include
>> -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-spock/lib
>> > > -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-spock/lib
>> -Wl,-rpath,/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray/lib
>> -L/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray/lib
>> > > -L/opt/cray/pe/pmi/6.0.14/lib
>> > > -lpetsc -lHYPRE -lkokkoskernels -lkokkoscontainers -lkokkoscore
>> -lhipsparse
>> -lstdc++
>> -lxpmem
>> -lgfortran
>> > > -lpthread -lgcc_eh -lm -lclang_rt.craypgo-x86_64
>> > > -lquadmath -lstdc++ -ldl -lmpi_gtl_hsa -o ex5f
>> 256 in
>> > > /tmp/pe_46424/ex5f_1.o
>> 256 in
>> > > Possible error running Fortran example src/snes/tutorials/ex5f with 1
>> MPI
>> > > process
>> > >   Linear solve converged due to CONVERGED_ATOL iterations 0
>> > > On Fri, Dec 10, 2021 at 8:07 AM Mark Adams <mfadams at lbl.gov> wrote:
>> > > > I am trying to get Spock working (again) and am having problems.
>> > > > * make check seems to fail but it is hard to see what is going on.
>> Maybe
>> > > > we should start here, but let me continue.
>> > > > * GAMG seems to work on the CPU
>> > > > * I have this for configuring with Kokkos. I am guessing these
>> versions
>> > > > are out of data. What is current practice:
>> > > >     '--download-kokkos-commit=3.4.01',
>> > > >     '--download-kokkos-kernels-commit=3.4.01',
>> > > > * Should I hold off (and tell my eager user to do same)?
>> > > > Thanks,
>> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211210/57e41dfb/attachment-0001.html>
