[petsc-dev] spock
Satish Balay
balay at mcs.anl.gov
Fri Dec 10 08:21:57 CST 2021
Works for me [per instructions in balay/update-spock, config/examples/arch-olcf-spock.py] with main - without these additional options
I'll go ahead and merge in balay/update-spock
Satish
1009 git fetch -p
1015 module load emacs
1016 module load rocm/4.3.0
1018 git reset --hard
1019 git checkout origin/main
1020 git merge origin/balay/update-spock
1021 ./config/examples/arch-olcf-spock.py && make
[balay at login2.spock petsc]$ MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0 MPICH_GPU_SUPPORT_ENABLED=1 MPICH_SMP_SINGLE_COPY_MODE=CMA make check
Running check examples to verify correct installation
Using PETSC_DIR=/autofs/nccs-svm1_home1/balay/petsc and PETSC_ARCH=arch-olcf-spock
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
C/C++ example src/snes/tutorials/ex3k run successfully with kokkos-kernels
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/ccs/home/balay/petsc/src/snes/tutorials ex5f
ftn -fPIC -fPIC -I/autofs/nccs-svm1_home1/balay/petsc/include -I/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/include -I/opt/rocm-4.3.0/include ex5f.F90 -Wl,-rpath,/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/lib -L/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/lib -Wl,-rpath,/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/lib -L/autofs/nccs-svm1_home1/balay/petsc/arch-olcf-spock/lib -Wl,-rpath,/opt/rocm-4.3.0/lib -L/opt/rocm-4.3.0/lib -Wl,-rpath,/opt/cray/pe/mpich/8.1.10/gtl/lib -L/opt/cray/pe/mpich/8.1.10/gtl/lib -Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib64 -L/opt/cray/pe/gcc/8.1.0/snos/lib64 -Wl,-rpath,/opt/cray/pe/libsci/21.08.1.2/CRAY/9.0/x86_64/lib -L/opt/cray/pe/libsci/21.08.1.2/CRAY/9.0/x86_64/lib -Wl,-rpath,/opt/cray/pe/mpich/8.1.10/ofi/cray/10.0/lib -L/opt/cray/pe/mpich/8.1.10/ofi/cray/10.0/lib -Wl,-rpath,/opt/cray/pe/dsmml/0.2.2/dsmml/lib -L/opt/cray/pe/dsmml/0.2.2/dsmml/lib -Wl,-rpath,/opt/cray/pe/pmi/6.0.14/lib -L/opt/cray/pe/pmi/6
.0.14/li
b -Wl,-rpath,/opt/cray/pe/cce/12.0.3/cce/x86_64/lib -L/opt/cray/pe/cce/12.0.3/cce/x86_64/lib -Wl,-rpath,/opt/cray/xpmem/2.2.40-2.1_2.44__g3cf3325.shasta/lib64 -L/opt/cray/xpmem/2.2.40-2.1_2.44__g3cf3325.shasta/lib64 -Wl,-rpath,/opt/cray/pe/cce/12.0.3/cce-clang/x86_64/lib/clang/12.0.0/lib/linux -L/opt/cray/pe/cce/12.0.3/cce-clang/x86_64/lib/clang/12.0.0/lib/linux -Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0 -L/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0 -Wl,-rpath,/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-unknown-linux-gnu/lib -L/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-unknown-linux-gnu/lib -lpetsc -lmagma -lkokkoskernels -lkokkoscontainers -lkokkoscore -lhipsparse -lhipblas -lrocsparse -lrocsolver -lrocblas -lrocrand -lamdhip64 -lstdc++ -ldl -lmpi_gtl_hsa -lmpifort_cray -lmpi_cray -ldsmml -lpmi -lpmi2 -lxpmem -lpgas-shmem -lquadmath -lmodules -lfi -lcraymath -lf -lu -lcsup -lgfortran -lpthread -lgcc_eh -lm -lclang_rt.craypg
o-x86_64
-lclang_rt.builtins-x86_64 -lquadmath -lstdc++ -ldl -lmpi_gtl_hsa -o ex5f/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld: warning: alignment 128 of symbol `$host_init$$runtime_init_for_iso_c_binding$iso_c_binding_' in /opt/cray/pe/cce/12.0.3/cce/x86_64/lib/libmodules.so is smaller than 256 in /tmp/pe_202599/ex5f_1.o
/opt/cray/pe/cce/12.0.3/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld: warning: alignment 64 of symbol `$data_init$iso_c_binding_' in /opt/cray/pe/cce/12.0.3/cce/x86_64/lib/libmodules.so is smaller than 256 in /tmp/pe_202599/ex5f_1.o
Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
Completed test examples
On Fri, 10 Dec 2021, Mark Adams wrote:
> FWIW, here is my current status.
> 08:08 main= spock:/gpfs/alpine/csc314/scratch/adams/petsc$ make
> PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
> PETSC_ARCH=arch-olcf-spock check
> Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
> 0 KSP Residual norm 0.0406612
> 1 KSP Residual norm 0.036923
> 2 KSP Residual norm 0.0191849
> 3 KSP Residual norm 0.00201589
> 4 KSP Residual norm 0.000376045
> 5 KSP Residual norm 4.2974e-05
> 6 KSP Residual norm 5.96585e-06
> 7 KSP Residual norm 4.5398e-07
> 8 KSP Residual norm 6.30474e-08
> 9 KSP Residual norm 5.55518e-09
> 10 KSP Residual norm 6.180e-10
> 11 KSP Residual norm 6.211e-11
> Linear solve converged due to CONVERGED_RTOL iterations 11
> 0 KSP Residual norm 3.32845e-06
> 1 KSP Residual norm 9.0003e-07
> 2 KSP Residual norm 1.32594e-07
> 3 KSP Residual norm 1.49857e-08
> 4 KSP Residual norm 1.31887e-09
> 5 KSP Residual norm 2.105e-10
> 6 KSP Residual norm 2.827e-11
> 7 KSP Residual norm < 1.e-11
> 8 KSP Residual norm < 1.e-11
> 9 KSP Residual norm < 1.e-11
> 10 KSP Residual norm < 1.e-11
> Linear solve converged due to CONVERGED_RTOL iterations 10
> Number of SNES iterations = 2
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> 1 KSP Residual norm 0.0281101
> 2 KSP Residual norm 0.00773873
> 3 KSP Residual norm 0.00165731
> 4 KSP Residual norm 0.000395614
> 5 KSP Residual norm 8.67655e-05
> 6 KSP Residual norm 1.69495e-05
> 7 KSP Residual norm 3.70051e-06
> 8 KSP Residual norm 5.97067e-07
> 9 KSP Residual norm 1.02242e-07
> 10 KSP Residual norm 1.75727e-08
> 11 KSP Residual norm 3.84826e-09
> 12 KSP Residual norm 6.414e-10
> 13 KSP Residual norm 1.380e-10
> Linear solve converged due to CONVERGED_RTOL iterations 13
> 0 KSP Residual norm 3.32846e-06
> 1 KSP Residual norm 8.99139e-07
> 2 KSP Residual norm 1.72893e-07
> 3 KSP Residual norm 3.733e-08
> 4 KSP Residual norm 6.67427e-09
> 5 KSP Residual norm 1.22785e-09
> 6 KSP Residual norm 2.551e-10
> 7 KSP Residual norm 5.458e-11
> 8 KSP Residual norm 1.050e-11
> 11 KSP Residual norm < 1.e-11
> 12 KSP Residual norm < 1.e-11
> Linear solve converged due to CONVERGED_RTOL iterations 12
> 3,5c3,14
> < 1 SNES Function norm 4.12227e-06
> < 2 SNES Function norm 6.098e-11
> < Number of SNES iterations = 2
> > 1 KSP Residual norm 0.21263
> > 2 KSP Residual norm 1.09192
> > 3 KSP Residual norm 6.9087
> > 4 KSP Residual norm 23.4292
> > 5 KSP Residual norm 57.7558
> > 6 KSP Residual norm 118.076
> > 7 KSP Residual norm 213.527
> > 8 KSP Residual norm 354.101
> > 9 KSP Residual norm 550.58
> > Linear solve did not converge due to DIVERGED_DTOL iterations 9
> > Number of SNES iterations = 0
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
> Possible problem with ex19 running with hypre, diffs above
> gmake[3]: [makefile:115: runex3k_kokkos] Error 134 (ignored)
> 21,25c21,26
> < 1 SNES Function norm 2.952582418265e-01
> < 2 SNES Function norm 4.502293658739e-04
> < 3 SNES Function norm 1.389665806646e-09
> < Number of SNES iterations = 3
> < Norm of error 1.49752e-10 Iterations 3
> > Memory access fault by GPU node-4 (Agent handle: 0xb08c90) on address
> 0xe17000. Reason: Page not present or supervisor privilege.
> > Memory access fault by GPU node-5 (Agent handle: 0xb0d3c0) on address
> 0xe11000. Reason: Page not present or supervisor privilege.
> > srun: error: spock25: task 0: Aborted
> > srun: launch/slurm: _step_signal: Terminating StepId=304034.3
> > slurmstepd: error: *** STEP 304034.3 ON spock25 CANCELLED AT
> 2021-12-10T08:08:40 ***
> > srun: error: spock25: task 1: Aborted (core dumped)
> Possible problem with ex3k running with kokkos-kernels, diffs above
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex5f
> ftn -fPIC -fPIC -I/gpfs/alpine/csc314/scratch/adams/petsc/include
> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-spock/include
> -I/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray/include
> -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-spock/lib
> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-spock/lib
> -Wl,-rpath,/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray/lib
> -L/gpfs/alpine/geo127/proj-shared/spock/petsc/current/arch-opt-cray/lib
> -L/opt/cray/pe/pmi/6.0.14/lib
> -lpetsc -lHYPRE -lkokkoskernels -lkokkoscontainers -lkokkoscore -lhipsparse
> -lpthread -lgcc_eh -lm -lclang_rt.craypgo-x86_64 -lclang_rt.builtins-x86_64
> /tmp/pe_46424/ex5f_1.o
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI
> process
> Linear solve converged due to CONVERGED_ATOL iterations 0
> On Fri, Dec 10, 2021 at 8:07 AM Mark Adams <mfadams at lbl.gov> wrote:
> > I am trying to get Spock working (again) and am having problems.
> > * make check seems to fail but it is hard to see what is going on. Maybe
> > we should start here, but let me continue.
> > * GAMG seems to work on the CPU
> > * I have this for configuring with Kokkos. I am guessing these versions
> > are out of data. What is current practice:
> > '--with-kokkos-hip-arch=VEGA908',
> > '--download-kokkos-commit=3.4.01',
> > '--download-kokkos-kernels-commit=3.4.01',
> > * Should I hold off (and tell my eager user to do same)?
> > Thanks,
> > Mark
