[petsc-dev] Kokkos build fail
Mark Adams
mfadams at lbl.gov
Wed Dec 8 08:06:19 CST 2021
Monterey.
And my serial, optimized build works but it seems to use the same compiler.
I am testing the parallel build again with debug turned off.
On Wed, Dec 8, 2021 at 9:04 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> You aren’t by chance on Catalina are you?
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Dec 8, 2021, at 08:49, Mark Adams <mfadams at lbl.gov> wrote:
> I am failing on OSX with openmpi. Kokkos is failing to build.
> I seem to be using:
> (conda_env) 08:46 1 adams/fix_mat_ex5k *= ~/Codes/petsc2$
> /usr/local/Cellar/open-mpi/4.1.1_2/bin/mpicxx --version
> Apple clang version 13.0.0 (clang-1300.0.29.3)
> Target: x86_64-apple-darwin21.1.0
> Thread model: posix
> InstalledDir:
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
> Any ideas?
> Thanks,
> Mark
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211208/21099220/attachment.html>
