[petsc-dev] PETSc GPU example
Matthew Knepley
knepley at gmail.com
Mon Dec 6 17:47:05 CST 2021
On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Dear PETSc team,
> I am interested in a careful evaluation of PETSc GPU performance in our
> INL cluster.
> Any example in PETSc that can show GPU speedup with solving a nonlinear
> equation?
> I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I tried
> that, but I could not find any speedup using the GPU. I could attach some
> results of "log_view" later if we would like to see that.
We should note that you will only see speedup in the solver, so that
problem has to be pretty large. I believe Mark has good results with it.
The assembly is still all on the CPU. I am working on this over break, and
hope to have a CEED version of it by the new year.
Matt
> Appreciate any instructions/comments about running a simple PETSc GPU
> example to get a speedup.
> Thanks,
> Fande
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/9f8e5f33/attachment.html>
