[petsc-dev] Help tracking down unexpected Fortran behavior
Patrick Sanan
patrick.sanan at gmail.com
Mon Dec 6 04:20:26 CST 2021
I ran into an unexpected seg fault, which took me too long to realize was
because of the old-school "you forgot the ierr" mistake! I was expecting
the compiler to complain, since we've had better checking for a while. E.g.
as in the attached code to reproduce, my compiler indeed errors on this
call PCSetType(pc, PCLU)
but not this
call PCFactorSetMatOrderingType(pc, MATORDERINGEXTERNAL)
I'm not yet seeing what the difference is, but there is still plenty I
don't understand about how the custom fortran interfaces work. E.g. both of
those functions have custom interfaces in ftn-custom directories, accepting
an additional "len" argument to be used with FIXCHAR(), but I'm not sure
how that argument is ultimately populated.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/cf22c0cc/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211206/cf22c0cc/attachment.obj>
