[petsc-dev] help on Summit
Mark Adams
mfadams at lbl.gov
Mon Aug 30 14:32:47 CDT 2021
I am in a branch of Stefano's and a user wants this for a milestone asap.
Maybe you can send me the fix and I can add it manually.
My branch is in a funny "main<>" state and I'm not sure how to pull, etc.,
without Stefano.
On Mon, Aug 30, 2021 at 3:28 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> That did not seem to work.
> So gcc didn’t ignore the hand-coded definitions in
> src/sys/objects/device/interface/cupminterface.cxx
> See https://gitlab.com/petsc/petsc/-/merge_requests/4271 where I swap
> constexpr for const and see if it works.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> 15:09 main<> /gpfs/alpine/csc314/scratch/adams/petsc2$ mpicc --version
> gcc (GCC) 9.1.0
> Copyright (C) 2019 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions. There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> I have read "GCC 8.x (and later) fully supports all of C++17."
> On Mon, Aug 30, 2021 at 3:07 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> Yeah I suppose so, all the values we alias are integral types so static
>> const should have equivalent compile-time assurance as constexpr.
>> Best regards,
>> On Aug 30, 2021, at 13:44, Junchao Zhang <junchao.zhang at gmail.com> wrote:
>> Can you use less fancy 'static const int'?
>> --Junchao Zhang
>> On Mon, Aug 30, 2021 at 1:02 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> No luck with C++14
>>> TL;DR: you need to have host and device compiler either both using c++17
>>> or neither using c++17.
>>> Long version:
>>> C++17 among other things changed how static constexpr member variables
>>> for classes worked. Previously if I had a class with a static constexpr
>>> member variable I would have to not only declare it inline within the
>>> class, but also define it within an executable otherwise the variable would
>>> not actually have any physical memory address:
>>> // foo.hpp
>>> class foo
>>> static constexpr int bar = 5;
>>> // foo.cpp
>>> int foo::bar;
>>> In c++17 however this changed because you can have static “inline”
>>> variables. All this does is force the compiler define the variable for you
>>> instead. The issue of course is that static constexpr implicitly makes that
>>> variable inline in c++17. So to sum it up:
>>> 1. The c++17 compiler (nvcc) sees the static constexpr variable, goes
>>> “hmm ok I will define this in some undefined location”.
>>> 2. The c++11/14 compiler comes along, sees your hand-coded definition of
>>> the variable and goes “ah but I think I’ve seen this before, I’ll ignore
>>> it”. This silent rejection is due to the hand-coded definition idiom being
>>> deprecated from c++17 onwards. Stupid, I know.
>>> 2. The linker (driven by the c++11/14 compiler since PETSc links using
>>> the host compiler) comes along and now suddenly cannot find the literal
>>> definition, because it doesn’t know what the c++17 did. Disaster!
>>> Best regards,
>>> On Aug 30, 2021, at 10:12, Mark Adams <mfadams at lbl.gov> wrote:
>>> No luck with C++14
>>> CUDAC
>>> arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o
>>> CUDAC.dep
>>> CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3
>>> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0):
>>> multiple definition of
>>> `Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking'
>>> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44):
>>> first defined here
>>> /usr/bin/ld: link errors found, deleting executable
>>> `arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3'
>>> collect2: error: ld returned 1 exit status
>>> gmake[3]: *** [gmakefile:113:
>>> arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1
>>> gmake[2]: ***
>>> [/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs]
>>> Error 2
>>> **************************ERROR*************************************
>>> Error during compile, check
>>> arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log
>>> Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to
>>> petsc-maint at mcs.anl.gov
>>> gmake[1]: *** [makefile:40: all] Error 1
>>> On Mon, Aug 30, 2021 at 10:50 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> Stefano suggested C++14 in configure. I was using C++11.
>>>> On Mon, Aug 30, 2021 at 10:46 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>>> @Jacob Faibussowitsch <jacob.fai at gmail.com>
>>>>> --Junchao Zhang
>>>>> On Mon, Aug 30, 2021 at 9:35 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> I was running fine this AM and am bouncing between modules to help
>>>>>> two apps (ECP milestone season) at the same time and something broke. I did
>>>>>> update main and I get the same error in main and a hypre branch of
>>>>>> Stefano's.
>>>>>> I started with a clean build and checked my modules...
>>>>>> Any ideas?
>>>>>> Thanks,
>>>>>> Mark
>>>>>> CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o
>>>>>> CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o
>>>>>> CUDAC
>>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o
>>>>>> CUDAC.dep
>>>>>> CUDAC
>>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o
>>>>>> CUDAC.dep
>>>>>> CUDAC
>>>>>> arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o
>>>>>> CUDAC.dep
>>>>>> CUDAC
>>>>>> arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o
>>>>>> CUDAC.dep
>>>>>> CUDAC
>>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
>>>>>> CUDAC.dep
>>>>>> CUDAC
>>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o
>>>>>> CUDAC.dep
>>>>>> CUDAC
>>>>>> CUDAC.dep
>>>>>> first defined here
>>>>>> gmake[2]: ***
>>>>>> Error 2
>>>>>> to petsc-maint at mcs.anl.gov
>>>>>> make: *** [GNUmakefile:9: all] Error 2
>> <make.log><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/c86e6857/attachment-0001.html>
