[petsc-dev] help on Summit
Mark Adams
mfadams at lbl.gov
Mon Aug 30 14:14:56 CDT 2021
That did not seem to work.
15:09 main<> /gpfs/alpine/csc314/scratch/adams/petsc2$ mpicc --version
gcc (GCC) 9.1.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I have read "GCC 8.x (and later) fully supports all of C++17."
On Mon, Aug 30, 2021 at 3:07 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> Yeah I suppose so, all the values we alias are integral types so static
> const should have equivalent compile-time assurance as constexpr.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Aug 30, 2021, at 13:44, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Can you use less fancy 'static const int'?
> --Junchao Zhang
> On Mon, Aug 30, 2021 at 1:02 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> No luck with C++14
>> TL;DR: you need to have host and device compiler either both using c++17
>> or neither using c++17.
>> Long version:
>> C++17 among other things changed how static constexpr member variables
>> for classes worked. Previously if I had a class with a static constexpr
>> member variable I would have to not only declare it inline within the
>> class, but also define it within an executable otherwise the variable would
>> not actually have any physical memory address:
>> // foo.hpp
>> class foo
>> static constexpr int bar = 5;
>> // foo.cpp
>> int foo::bar;
>> In c++17 however this changed because you can have static “inline”
>> variables. All this does is force the compiler define the variable for you
>> instead. The issue of course is that static constexpr implicitly makes that
>> variable inline in c++17. So to sum it up:
>> 1. The c++17 compiler (nvcc) sees the static constexpr variable, goes
>> “hmm ok I will define this in some undefined location”.
>> 2. The c++11/14 compiler comes along, sees your hand-coded definition of
>> the variable and goes “ah but I think I’ve seen this before, I’ll ignore
>> it”. This silent rejection is due to the hand-coded definition idiom being
>> deprecated from c++17 onwards. Stupid, I know.
>> 2. The linker (driven by the c++11/14 compiler since PETSc links using
>> the host compiler) comes along and now suddenly cannot find the literal
>> definition, because it doesn’t know what the c++17 did. Disaster!
>> Best regards,
>> On Aug 30, 2021, at 10:12, Mark Adams <mfadams at lbl.gov> wrote:
>> No luck with C++14
>> CUDAC
>> arch-summit-hypre-cuda-dbg/obj/vec/is/sf/impls/basic/cuda/sfcuda.o
>> CUDAC.dep
>> CLINKER arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3
>> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/impls/cupm/cuda/cupmcontext.o:(.rodata._ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE[_ZN5Petsc13CUPMInterfaceILNS_14CUPMDeviceKindE0EE21cupmStreamNonBlockingE]+0x0):
>> multiple definition of
>> `Petsc::CUPMInterface<(Petsc::CUPMDeviceKind)0>::cupmStreamNonBlocking'
>> arch-summit-hypre-cuda-dbg/obj/sys/objects/device/interface/cupminterface.o:(.rodata+0x44):
>> first defined here
>> /usr/bin/ld: link errors found, deleting executable
>> `arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3'
>> collect2: error: ld returned 1 exit status
>> gmake[3]: *** [gmakefile:113:
>> arch-summit-hypre-cuda-dbg/lib/libpetsc.so.3.015.3] Error 1
>> gmake[2]: ***
>> [/gpfs/alpine/csc314/scratch/adams/petsc2/lib/petsc/conf/rules:50: libs]
>> Error 2
>> **************************ERROR*************************************
>> Error during compile, check
>> arch-summit-hypre-cuda-dbg/lib/petsc/conf/make.log
>> Send it and arch-summit-hypre-cuda-dbg/lib/petsc/conf/configure.log to
>> petsc-maint at mcs.anl.gov
>> gmake[1]: *** [makefile:40: all] Error 1
>> On Mon, Aug 30, 2021 at 10:50 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> Stefano suggested C++14 in configure. I was using C++11.
>>> On Mon, Aug 30, 2021 at 10:46 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>> @Jacob Faibussowitsch <jacob.fai at gmail.com>
>>>> --Junchao Zhang
>>>> On Mon, Aug 30, 2021 at 9:35 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> I was running fine this AM and am bouncing between modules to help two
>>>>> apps (ECP milestone season) at the same time and something broke. I did
>>>>> update main and I get the same error in main and a hypre branch of
>>>>> Stefano's.
>>>>> I started with a clean build and checked my modules...
>>>>> Any ideas?
>>>>> Thanks,
>>>>> Mark
>>>>> CC arch-summit-hypre-cuda-dbg/obj/tao/interface/taosolver.o
>>>>> CC arch-summit-hypre-cuda-dbg/obj/ts/interface/ts.o
>>>>> CUDAC
>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/dense/seq/cuda/densecuda.o
>>>>> CUDAC.dep
>>>>> CUDAC
>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparseband.o
>>>>> CUDAC.dep
>>>>> CUDAC
>>>>> arch-summit-hypre-cuda-dbg/obj/ts/utils/dmplexlandau/cuda/landaucu.o
>>>>> CUDAC.dep
>>>>> CUDAC
>>>>> arch-summit-hypre-cuda-dbg/obj/vec/vec/impls/seq/seqcuda/veccuda2.o
>>>>> CUDAC.dep
>>>>> CUDAC
>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.o
>>>>> CUDAC.dep
>>>>> CUDAC
>>>>> arch-summit-hypre-cuda-dbg/obj/mat/impls/aij/seq/seqcusparse/aijcusparse.o
>>>>> CUDAC.dep
>>>>> CUDAC
>>>>> CUDAC.dep
>>>>> first defined here
>>>>> gmake[2]: ***
>>>>> Error 2
>>>>> to petsc-maint at mcs.anl.gov
>>>>> make: *** [GNUmakefile:9: all] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/d79a6751/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/d79a6751/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210830/d79a6751/attachment-0003.obj>
