[petsc-dev] Is this a bug in test generation?
    Scott Kruger
    kruger at txcorp.com
    Fri Aug 20 11:02:36 CDT 2021
Separate tests require separate names.  Requiring the suffix to be in
the tests is not a bug or a limitation, but rather a requirement.
This does require an `output_file:` at the testset level.
Scott
On 2021-08-20 12:57, Pierre Jolivet did write:
> That’s a long-standing issue that I personally bypass by setting the suffix in the test instead of at the testset scope.
> But maybe that’s not working for you either?
> Thanks,
> Pierre
> > On 20 Aug 2021, at 12:43 PM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> > Scott
> > This test is specified as
> >    testset:
> >       suffix: expl
> >       nsize: {{1 2}}
> >       filter: grep -v "MPI processes" | grep -v " type:" | grep -v "Mat Object"
> >       args: -ksp_converged_reason -view_explicit_mat -pc_type none -ksp_type {{cg gmres}}
> >       test:
> >         args: -mat_type aij
> >       test:
> >         requires: hypre
> >         args: -mat_type hypre
> > It triggers an error here https://gitlab.com/petsc/petsc/-/jobs/1519558357 <https://gitlab.com/petsc/petsc/-/jobs/1519558357>, with a  CI configuration without hypre.
> > Other testset instances works fine if any “require:" is both specified in the testset body and in the specific test.
> > Is this supposed to work?
> > Thanks
> > Stefano
Scott Kruger
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
Boulder, CO 80303                Fax:   (303) 448-7756
